I am unable to watch anything other than what I wish to record and pressing the vct/tv button on the right hand side of the remote does not change me back to tv.
Comment by JAYMAC, posted on Jun 03, 2007
i am not using a universal remote.i do not have a cable box but i have cable tv. the cable from the wall antengoes to rf in. rf out on vcr goes to cable/ant on tv. the red/white/black cables are connected to the vcr area that says dvd/vhs common out and run to the back of my tv to corresponding color input lines. i found in my operating instructions book since i posted this problem,in fine print on pg 8 that "you cannot change the channel or recording mode during recording". I did go back to the stote and pose my problem to the sales associates and they said that none of the new vcr/dvd combos allow one to change channels by remote-they said i could mannually go to my tv and change the channel and i tried that and it works that way. I thank you for your help.
Panasonic DMR-EZ47VEB.TV Toshiba 2987DB * Sky digibox model 2200.
On set up the DMR cannot perform 'Auto Setup', it says check aerias. Have tried numerous changes of scart and aerial to no effect. Comments appreciated.
Solution #1
posted on Jun 16, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
suddenly all dvds i put in do not play and the machine eiother says there is no disc there or that it cannot read it - so i can see what i am due to record but not the playback list at all
HHHHHHHHHHHEEEEELLLLLLLLLPPPPPP
Was this solution helpful? Show your Appreciation by rating it:
In order to view one channel and record another, you have to have (and be using) two tuners and also have a way to bypass the signal to one tuner into the other. The only time you're using the tuner of a device is when coaxial is connected - everything else is an input mode.
1. You could have a 2-way splitter with the signal connected on one end to RF IN of the DMR and on ANT IN of the TV, then the DMR connected to the TV via composite, S-Video or component cables.
2. You could connect coaxial all the way through to the television from the wall. Wall to DMR to TV - all coax would allow you to view one channel and watch another. Tune the DVD recorder to the channel you wish to record and start the recording. Use the TV/VCR button to bypass that signal to the TV and tune the station you want to watch on your television.
When it says "you cannot change the channel or recording mode while recording" that is referring to the tuner on the DVD recorder, not your television. I think the issue here is that you're keeping your TV in the input mode and trying to change the channel on the recorder after you've started recording - but I could be wrong. You need to change the channel on the TV ITSELF.
Show your appreciation by commenting on watching tv while recording onto vhs or dvd:
Solution #3
posted on Jun 29, 2007
Guest
Had a very similar problem with a slightly different Panasonic model yesterday. On autosetup it insisted on recognising the analogue satellite decoder as AV1. Problem was that in AV1 mode, any channel selected on TV was channel on AV1 (even if changed manually on TV by hand). Solution was to delve deeper into tuning setup,find this channel & give it a different reference number (your choice). Works perfectly now. Sounds like your problem is similar.
This could be a couple of problems. I'm not trying to make you feel dumb or anything but sometimes people miss the obvious. Do you have an universal remote? How is your vct wired to your tv? Does your cable go to your vct or your tv first? These sound like silly questions but they are important.
Comment by guygould, posted on Jun 03, 2007
Also make sure that the channels on your vct and your tv are set to the same channel.
