Question about Panasonic KX-T7630 Corded Phone
Changing Names on Extention Numbers from Main Phone
How do I changing Names for the Extention Numbers already stored from Main Phone?
  • Dakoda_lee Jan 16, 2009
    This doesn't seem to work on my phone... is there another way? am I missing something?
  • malibu_birdi Feb 03, 2009
    How do I change the name only on an extension?
    Problem Solver:
  • 9 Answers
Program,**,004,enter,(type in name using number keypad)enter, end.
Posted on Jan 11, 2009
  • comms109 Jan 11, 2009
    program,**,1234,004,enter,(type in name using number keypad)enter, end.
    sorry missed the login code.
Changing names on phone
I have the software console on my desktop. open, go to LAN tab (need pswd) click connect, go to extension tab, press 4, then 1, then 1, then enter. Should see list of names and their ext #'s. make changes as you see fit. remember to press Apply for changes to take place.
Apr 04, 2014 | Panasonic KX T7436 Corded Phone KX-T7436
How do I change the extention names on KX-T7730?
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ).
3. Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change.
4. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered.
5. Press PROGRAM to exit program mode and you are done.
Mar 23, 2010 | Panasonic KX-T7730 Corded Phone
Extention Names?
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system -
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234).
2. Now press 004 and then ENTER.
3. Enter the extension number you want to change.
4. Enter the name (the same way as texting on a cellphone.)
5. To save the changes press AUTO DIAL / STORE.
6. To go to the next extension press NEXT on the screen.
7. Lift the handset and put it down to exit program mode.
Feb 18, 2010 | Panasonic KX-T7630 Corded Phone
How do i Names to Extention numbers on the Panasonic KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Nov 09, 2009 | Panasonic KX-T7636W Corded Phone
How do I save telephone numbers to a uniden powermax 5.8 ghz cordless telephone
Phonebook (Storing Phone Numbers, Names, Distinctive
Rings and Speed Dial)
You can store names and numbers in your phone’s phonebook, search for names
alphabetically, and dial phonebook entries with just a few key presses. You can
store up to 100 numbers in the base and up to 100 additional numbers in each
registered handset.
The phone uses the same memory to store phonebook entries and Caller ID
messages. If the shared memory is already full, the phone will not store any more
phonebook entries. You will have to delete some of the Caller ID messages before
you can store a new phonebook entry.
1) When the phone is in standby mode, press phonebook.
2) Press the STORE soft key, S t o r e / E d i t N a m e appears.
3) Enter the name (up to 16 characters) by using the
number keypad (see the "Steps for Entering Names and
Special Characters" on page 44).
If a name is not required, go to step 4. <No Name> will
be used as the name.
4) Press the OK soft key to store the name;
S t o r e / E d i t N o . appears.
5) Use the number keypad, */tone/<, or #/> to enter the
phone number (up to 20 digits).
If you make an error, use the DELETE soft key to erase
the incorrect digits. When you are finished, press the
OK soft key to store the number.
6) If you store the phonebook entry from the handset,
D i s t i n c t i v e R i n g appears. Press volume up/down to
move the pointer to one of the Distinctive Ring options
and then press the OK soft key.
7) S p e e d D i a l appears. Press volume up/down to move the
pointer to select the Speed Dial location (10 locations:
SPD1-SPD0).
8) Press the OK soft key. You will hear a confirmation tone, and D o n e ! appears in the
display. EASY DOES IT! :)
Jul 08, 2009 | Uniden TRU9466 Cordless Phone
Changing the names fixed to internal extension numbers
If you can not log into the programing tool to change it that way then you will still need the Installer password. However from the main ext typically the first ext or 101
hit the Program soft key just below the LCD
push * then #
password
004
ext number you wish to change
type in new name
ENTER
END
Apr 14, 2009 | Panasonic KX-T7633 Corded Phone
I am new at a company that has NEC phones (I have the main line)
you would need to enter program mode and in MB 4-18 enter the correct names for each port(extension). ldtsnj.com
Mar 12, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Names won't display in inbox
Hi!
In my many years of using Nokia phones, I noticed that when there are duplicate entries on both SIM card and Phone memory, the names will not appear when they send you messages. You may try to check your phone and sim memory if the numbers are stored on both and delete the duplicate or choose just one memory to use, whether it be the SIM or phone memory to avoid conflicts.
Happy Holidays!
Dec 24, 2008 | Cell Phones
D1232 extension programming issue
Welcome to Panasonic TD programming....
Even though the hardware doesn't exist, the numbers do. The universe of 101-164 and 201-264 are already taken. Oops, 200 might be available, 100 might be available. 167 and 168 and the 80's might work.
It's a 3 step process. Change 210 to 200 change 225 to 210 and change 200 to 225. There's your "swap".
Now, keep in mind that the XDP port for 110 is 210 and if your voice mail is analog.....Ah, but that's another thread.
Carl
Sep 19, 2008 | Panasonic KX-T7453 Corded Phone
How do ichange the time on Panasonic KX-T7431??
MUST BE DONE FROM EXT.101
1.leave handset in the cradle
2.Press "Program" button
3.Dial *#1234 (star pound 1 2 3 4)
4.Press Sp-phone button 3 times
5.enter the correct hour on the dial (2 digits)
6.press the button (in the lcd window to advance to minutes)
7.enter the correct minutes
8.press auto dial/store button
9.pick up hand set/ hang up hand set.
Oct 29, 2007 | Panasonic KX-T7456 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
243 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
