Question about Microsoft Windows XP Home Edition
Windows 98 won't boot up
I have two operating systems Windows 98 and Windows Xp. Windows 98 was working fine then it just quit booting up. It gives an error message- "A fatal exception OD has occurred at 0028:c005981c in V*D vmcpd(01) +0000035C. XP is partitioned. I tryed a 98 boot disc but it did not solve the problem. I have a lot of business stuff on 98 that I had intended to transfer but hadn't gotten around to it. I know you are going to say that I can still get to the data: and I can, but it is a great chore. If I could get 98 to boot it would be a lot easier to tranfer everything.
Create a recovery directory of your system by connecting to other system and then reboot with help of that
Posted on Jan 09, 2009
  • 827 Answers
Can you run Win98 in Safe Mode? Just tap F8-F10 or Del or Esc on booting (It's different buttons on different machines) to enter Advanced Settings and run Win98 in Safe Mode. You can get access to your files, and maybe even System Restore back to a point before you had the problem?
Worth a try..
Hope this helps
Chris (ziraffa)
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Somehow your MBR (Master Boot Record) likely got corrupted or possibly your hard drive went bad coincidentally.
Simply, you will start your computer from your Windows CD/DVD install disk, then when at a DOS prompt ( D:\ ) you will then type: FDISK /MBR (press enter).
Find your Operating System install DVD and start your computer with it, then follow instructions within this discussion:
Restore Windows XP MBR without Windows XP disc
Alternatively, review my search results for other instructions:
fdisk mbr windows xp Google Search
Nov 22, 2017 | Gateway MP8708 Notebook
I have Windows XP on my computer mow but have one older program, Cadkey 97, that will not work on XP and requires Windows 98. What I need is a work around to use CK with XP or a way to have XP and 98 on...
Try using the XP compatibility wizard. Start > Programs > Accessories > Program Compatibility Wizard. There are ways to dual boot 98 and XP, but there are a lot of details involved. It requires a lot of research. Best to do a Google search for "dual boot windows 98 and XP". Here is one result:
http://vlaurie.com/computers2/Articles/dualboot.htm
Feb 16, 2011 | Computers & Internet
Hard drive full running xp ,drive is paritionedc,d
To delete a partiition is quite easy in windows. but you will need a third party application like "partition magic" to merge two partitions together, this could be costly
The best advice I could give you is to back up all your information and reinstall your windows straight onto one partition. This will improve your overall speed and also probly also free more space by deleting unwanted programs, spam etc.
Regards
Dec 05, 2009 | Dell Dimension E310 PC Desktop
Have dual boot system,W98SE/XP. Resised both partitions with Easeus to make room for Windows 7 RC. XP is fine but 98 won't boot up. Black screen/white cursor top left. Use 98 a lot for my work.
Windows 7 cannot be installed on FAT 32 system, which is required by 98. Windows 7 needs NTFS which may actually cause the issue as it is not compatible with FAT32.
Are all of the O/s are in different partitions?
Regards,
Shrey
Oct 10, 2009 | Computers & Internet
Plz help me ..regarding uninstallation
go to start then select run and type msconfig the hit enter key
when a window pop up click on the boot.ini then delete the boot partition where windows 98 located then restart your unit
Aug 14, 2008 | Microsoft Computers & Internet
Computer won`t boot
u will have to reformat the hard drive and load win 98 or win xp whichever u want to fix this
you can have more detailed info at
http://www.computerhope.com/issues/ch000474.htm
Jan 31, 2008 | Computers & Internet
When I boot up my computer before windows xp loads it asks which operating system I want to run,and it gives me 2 choices WINDOWS XP HOME, or, WINDOWS XP HOME. You use the up and down arrows to select...
simply you can remove the second option in the boot.ini.
go to the or right click the my computer at the desktop and the properties. and then click"advance TAb" in the start up and recovery, click "setting" and then "edit"
you will see this:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
Timeout=30 change to: 0
and then delete this:
after deleting you must save it.
and then restart the system
Please leave a comment b4 your rate, Thanks!
Jan 28, 2008 | Computers & Internet
How to install os
This is a little difficult but it can B done :) Firstly I dunno if ya need to re-format ya drive? perhaps first ya could try to "Repair" of Win98? If that doesn't work,then, perhaps ya may have to re-format. If the Win98 is on a SEPARATE drive or Partition this also makes a difference.... Basically ... repair/re-install win98, then do a repair of ya Boot menu for XP, as Win98 sets up an incorrect Boot up for XP, and thus must be "Fixed" so XP will boot & show a Dual boot menu.. here are some links to help you step by step... http://pcworld.about.com/magazine/2109p156id111652.htm http://www.thehindubusinessline.com/ew/2004/08/30/stories/2004083000250400.htm
Aug 21, 2007 | Microsoft Windows 98 for PC
Microsoft Windows XP Home Edition Logo
81 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
