Question about Bosch PB10-CD Radio/CD Boombox
Wont work when its cold
When the temp drops inside or out the unit does not work until it gets warmed up
  • 3 Answers
Its not the temprature its losing in wiring check the main grip behind player make sure its tight.
Posted on Jan 09, 2009
The display comes up with UnCal when the ambient temp drops below say 15 degrees celsius then when it warms up it works normally.
I'd try to locate the problem using freeze mist. Spray each component for a second or two to see if the unit acts up. Repeat with each component until you find the one that is causing the problem.
Apr 28, 2015 | Fluke 789 Process Meter loop Calibrator
Unit alternates cold, warm, cold, warm etc..
in high temps AC units undergo whats called thermal inversion. This is when it blows hot inside and cold outside. I do not believe there is a fix for this. Maybe it is not properly sized for you room? If your unit is too small, it may be working too hard and inverting.
Jul 30, 2014 | Kenmore 75184 Air Conditioner
Kegerator gets cold but will not not stay cold. its like unit shuts off after it reaches cold
You may need to replace the thermostat. Sound like it works until the low temp setting is reached and then can't maintain that temperature. Given that it will turn the machine on when the refrigerated compartment is warm this implies that the thermostat works until it breaks the connection when the low temperature target is reached.
Jan 07, 2014 | EdgeStar KC2000 Beverage Cooler Commercial
P2285 code 6.0 litre ford deisel long cranking before starting after starts runs great but oil pressure gauge drops at idle
bad bearings on crank or worn oil pump. Pressure will be up when cold, but will drop when engine warms up. Check for knock in lower end. If so, bad crank bearings.
Jan 16, 2013 | 2004 Ford Super Duty F 550
My mistral reverse cycle mss25ss model does not work at all in heat mode. what would be broken?
firstly is the air comming from the outdoor unit cold or warm? if it is cold then the 3way valve is working and it has changed to heating. If it stays warm then it is still in cooling mode. The indoor fan wont come on until the coil temp gets warm enough, ( so it doesnt blow cold air on you straight up). If it is changing into heat mode then the larger of the pipes connected to the outdoor unit should get warm/ hot. If this is not happening then the unit is either out of gas or the compressor is on hollidays and wont come back to work.
May 22, 2012 | Heating & Cooling
I am not sure if it is a problem.....we recently bought a house with the above heatpump in it. We have noticed lately that the inside unit (not the outside unit) developes a layer of ice on it on really...
If it works fine during the heat of the day, but as soon as it cools down, it freezes up, then you may have a low refrigerant charge. The other things you may check are the indoor filters to make sure they are clean, and check if you are getting good air flow through the vents. Bad air flow can mean you have a dirty evaporator coil if the filters are clean. If the above checks out ok, then you will have a low refrigerant charge and need a technician to come out and charge the unit. What happens is the low charge will cause the pressures/temps to drop inside the unit. When its hot enough outside and warm enough on the inside of the house, its enough to keep it from freezing, but as soon as the outside/inside temps drop, the refrigerant drops below the freezing point and starts to freeze. As for asking if its a problem, definitely. Hope this helps and good luck!
Jul 02, 2011 | Heating & Cooling
Digital readout says eaaf
The unit will not turn on if the internal temp sensor is below 40 degrees. Warm it with a hot rag or hair dryer, or bring the unit inside to warm up and it will turn on. Once the unit turns on for a minute or so, it will work fine outside.
This isn't the ideal solution, but it will work. I don't know why they don't want the smoker to turn on when it is cold out (unless they are worried that the quick change in temp will damage the heating coil).
Nov 26, 2009 | Masterbuilt 20070106 Electric Smoker
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
Ford mondeo mk3, intermitent dumping of water from cooing system,found crack in header tank, changed same,ran car at idle, temp guage at normal & heater blowing hot , took car for run , temp guage off...
You may have an air pocket in your system which some times happens.  One way to get rid of it is to take the upper hose off on the engine side,  fill your system with water until it runs out from your engine block, replace the hose, start your car turn you heater on and set to hi keep the radiator cap loose until the temp start to rise then close tight.  Once the air pocket had been remover you can drain some of the water from the radiator using the lower drain plug and add antifreeze.
Mar 09, 2009 | 2001 Ford Taurus
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
Bosch PB10-CD Radio/CD Boombox Logo
88 people viewed this question
Top Bosch Audio Players & Recorders Experts
Bill Boyd
Are you a Bosch Audio Player and Recorder Expert? Answer questions, earn points and help others
