Question about Orion Car Audio & Video
An Orion car amplifier that blows fuses when CD palyer turned on
I have an Orion Extreme 2 channel 375-2 car amplifier that keeps blowing fuses when I turn on the CD player. What can be my problem and how do I fix it? It has an internal crossover configuration which is called intelliq. It has left and right phase control switches, high pass and low pass switches. Each channel puts out 98.75 watts/channel. Equipped with remote gain capabilities and is capable of 3, 2, or 1 channel operations with a maximum power capability of 375 watts into 4 ohms mono.
  • Orion Master
  • 19,396 Answers
Running Inline fuse to battery suggested by CRTN can be a solution to the AMP overloading and blowing fuse in the box, this also requires new wirings and you bypass fuse box, therefore can sort out also wiring problems. If not done properly the wiring job can mess up your car and damage more device, the job can be more complicate then you expect, and it is better done by a technician.
Moreover your unit is blowing fuse when you turn on the CD, therefore it is not necessarily a charge load problem, even if this is the most likely eventuality, as when you turn on CD, the power absorbtion from unit, and therefore the load on fuse increases.
Before running a direct inline, check all the wirings, paying particular attention to the connectors at the back of the units.
A lose fibre that is shorting can easily be cause for the problem.
Posted on Jan 10, 2009
    Sergeant:
  • 378 Answers
Its definately the connection issue as the circuit is getting over loaded current from its connections.just check out the wires properly either they r connected loose or they r having a small cut in between so its blowing the fuse as the circuit becomes incomplete.in such casses just replace the wires and that will be fine.
Posted on Jan 09, 2009
  • 1,800 Answers
Ur facing a shorting out in the board
chek it using multimeter.
then remove it
most likely it would be in the disk player system.
  • 716 Answers
You Need To Run An Inline Fuse Directly To The Battery.
You Can Buy Them At Radio Shack Cheap. This Is Your Fix As The Power Surges On Start Up. The Amp Needs Its Own Inline Fuse. Directly From The Positive Battery Terminal To The Amp. The Other Negative Can Just Be Grounded. Heres A Picture Also You Can Buy Them At Best Buy Circuit City And Wal-mart. Happy Fixing
http://www.radioshack.com/product/index.jsp?productId=2103778
    Genius:
  • 1,847 Answers
Mostly all amps have a relay against short circuit and all have a fuse on the output stage.But i guess yours is very cheap or very old that would explain for no protection circuit.
But I suggest you first, fit a relay on the just before the output stage on each channel and then replace all the transistors.
  • Legin Varghese
    Legin Varghese Jan 12, 2009
    let me know if you need further assistance. Thanks kevin
  • 15,935 Answers
What size fuse is it, and is it in the main power line, or on the amplifier?
  • 3 more comments
  • blueextc3221
    blueextc3221 Jan 09, 2009
    Step one : isolate the amplifier
    remove all wires and only attach Pos, Neg, and rem.
    If the fuse blows, the problem is internal and needs to be serviced.
    If the fuse is good... check with a voltmeter set to ohms that the voicecoils register the proper resistance.
    Hook one up... then the other....
    If the amplifier is STILL on without blowing fuse, attach one RCA and then the other (while powered on.)
    A fuse blown here indicates the other end is hitting bare metal. Remove the radio and tape up the used and non-used rca jacks.
  • blueextc3221
    In the above comment i made, it is the speaker's voicecoils you are checking resistance for.
  • blueextc3221
  • blueextc3221
    it would also help to know the components attached to this amplifier... subs, coaxials... factory speakers... etc
  • blueextc3221
    Let me know, and i will help you further.
    The amplifier is seeing something it doesnt like. Most of the time it is a ground thru the power supply. Indicating blown speakers, or bare wires touching metal.
Amc amp fuse keeps blowing
Fuses blow when there's an overload. Suspect a faulty semi-conductor device somewhere.
Dec 14, 2012 | AMC Multimedia 2N100-2 2-Channel Amplifier
Fuse apx200m
HI,
If the fuse is blowing of then there is problem with the inverter stage of amplifier. There is an inverter stage in the amplifier to boost the 12V to + or - 30 to 40V normally. Its a switching circuit normally uses Mosfets and ferrite core transformer and a driving IC. If the mosfet is shot then the fuse will blow off immediately after power is connected.
Check on thing remove the REM connection and then connect the power. If the fuse blows the there is fault with the Mosfet Its short.
If the fuse blows only when you connect the REM then the amplifier stage is faulty.
Also check by disconnecting the speakers. if any of the speaker is faulty then there is a chance for fuse blow off.
Ajin
Apr 27, 2012 | Clarion APX280M 2-Channel Car Amp
Sonance ASAP1 2 channel amp/switcher keeps blowing fuses. I'm using the 1A-250V slow burn fuses like it states on the rear panel. I plug it in and it instantly blows the fuse.
If fuzes burn out at connection to computer , that necessary to check:
1 Presence of the earth between body PC and amplifier.
2 Levels of the signal at the input amplifier must be minimum.
Jan 03, 2011 | Sonance ASAP1 2-Channel Amplifier
It keeps blowing a fuse
Generally, if you are using the manufactures fuse rating you can use a slightly higher rating and it will resolve the blowing fuses. Fuses supply resistance, if there isn't enough resistance you'll fry the system board in the amplifier. But if you have 25 amp fuses installed, install 30 amp, if you have 30 install 35 amp, 35 install 40. Anything higher will damage the amp.
Hope this helps.
A rare chance, something may be internally wrong with the amp and shorting it out which will blow the fuse.
Use the incorrect wiring of subs to the amp, you'll blow fuses and damage the amp from it turning off consistently. The amp should be running at 2 ohm stereo stable or 4 ohm mono stable.
Very few amps are designed to run at 1 ohm or less. Not to mention the subs can't handle it.
Jul 28, 2010 | Power Acoustik TS980-2 2 Channel 980W...
I have a orion hcca-d1200 and it keeps shutting off and blinking protect light and the esp indicator light. what could be wrong with it?
Possibly a shorted output transistor. If it was the power supply you would be blowing fuses, which I assume you aren't.
Nov 23, 2009 | Orion HCCA-D1200 Car Audio Amplifier
The fuse keeps blowing in my marantz pm-57 amplifier. It says it takes a T 2.5A 250V fuse. I can only find 2.5A 250V fuses. What relevance is the ''T''.
Goo day sir, the T on the fuse has nothing to do on you marantz fuse blowing up, chances are you amplifier is shorted, check you IC amplifier/power transistor for shorts. Check also your speaker impedance. usually they are 8 ohms. You can use a technician's multitester device to check the impeadance. An imbalance or mismatch speaker can cause a fuse to blow and destroy your amplifier. hope this helps.
Jul 31, 2009 | Marantz PM-15S1 2-Channel Amplifier
Amp blowing fuses
Your amp is blowing fuses to protect your circuit. The type of 12V battery does not matter. For whatever reason you are over driving the amp. 2 Ohms sounds like a very low impedance for a car amplifier output. I am assuming you have the two 12" speakers wired in parallel. Most are rated at 4 Ohms which means you are pulling twice the current with the 2 Ohm load. Also, the bigger the speaker, the bigger the magnet, the bigger the coil, the larger the inductance, the heavier the load. Make sure these speakers are matched with your amp. A small amp driving large speakers will shut down at high volumes. Try putting them in different channels. Good Luck.
Jun 17, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Power wire keep blowing fuses
you need to go tho a block fuse which will be able to handle more load but will still give way before the amp its self would get fried i recommend a 75 fuse or higher
Feb 21, 2009 | Orion HCCA 275G4 Car Audio Amplifier
Wondering why im blowing fuses
The most common reason for an amp (in good working order) to blow fuses is a speaker load that's impedance is too low. You may need to rewire your speakers.
Let me know if you have any other questions.
Aug 21, 2008 | Legend LA1490 - American Legacy Series 2 -...
Car Audio & Video Logo
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
