Question about Hamilton Beach Water Cooler with Storage Cabinet
Water Cooler - Water has mildew taste
Hamilton Beach - Model 87308
We drained tank and cleaned with bleach several times and cannot get rid of the mildew taste.
We even drained out through the drain holes in the back of the cooler.
  • 1 more comment
  • Anonymous Jan 10, 2009
    I have the same problem.. no clue what is causing this..
  • phdbrown2000 Jan 21, 2009
    I have the same problem. Any solution as to why the water taste like mildew?
  • Anonymous Jan 31, 2009
    have the same problem ,only when you use the cold
I just put about six cups of white vinegar (not diluted) into the reservoir and let it sit for about an hour. Then I emptied that out and flushed a few pitchers of very hot water through. It seems to have worked quite well.
Posted on Nov 25, 2009
  • VMD011 Oct 20, 2010
    do you still have this unit? I am looking to buy one for parts. Will pay for shipping too. pls email me at vmd011@hotmail.com
    thanks!
How to clean and sanitize a Kentwood water cooler?
Using one cup of bleach Per 5 gallon jug. Find the drain plugs on the bottom of the unit there are two. Drain unit of any water that is in it now. Replaced drain plugs. Place 5 gallon jug on top of unit and allow unit to fill. Be sure that heated water is off. Open spigots and allow a gallon of water to drain. After about 15 minutes open the drain plugs and allow all of the solution to drain out. Proceed to fill the 5 gallon jug with clean Clear filtered water and allow that to drain thru the unit, do this five more times.
Oct 29, 2013 | Hamilton Beach Water Cooler with Storage...
I have a Hamilton Beach Aroma Elite, but i hate a coffee. How can I boil only the water? It may do it or not?
You can actually just fill up the pot with with water and pour it into the back without adding coffee with practically all coffee machines.
If it tastes like leftover coffee, then here's what you do to fix it:
1.)Fill your pot with 10% bleach.
2.)Fill the rest of the pot with water.
3.)Fill the machine.
4.)Switch on and wait for it to run a full cycle.
5.)When it's done, run it again 3 or 4 more times without bleach until you can no longer smell the bleach in cup of hot water that you pour.
6.)Ta-da, your coffee maker has been successfully turned into a hotwater machine and it's been cleaned from any coffee.
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Hamilton Beach Aroma Elite 48101
Need to find thermostat for hot water tank for hamilton beach water cooler
Is this model 87307? I want to buy this model. My e-mail is vmd011@hotmail.com
Nov 04, 2010 | Hamilton Beach Water Cooler with Storage...
Hamilton beach water cooler has mildew taste
Hi, your post is showing a photo of a vacuume cleaner? Don't think so,lol. If you water cooler has a mildew taste in the air, you need to go to a hardware store, just about any, and buy a roll of evaporative water cooler tablets that you add to the water to prevent this from happening. They are the size of a quarter and come in a roll or other container depending on the amount you buy. They have different names, so just ask for the tablet additive for your water cooler and they will no what you need. I hope this has helped you.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Oct 23, 2010 | Vacuums
Model 87307 Hamilton Beach/Proctor Silex Needs insert and knob for the drains in the back. Filters??
I am looking to buy this model 87307. If you want to sell, please email me at vmd011@hotmail.com - thanks
Mar 03, 2010 | Hamilton Beach Water Cooler with Storage...
Water taste and smells like mildew
Hi and welcome to FixYa. I am Kelly.
How about the house tap water same odor and taste or just the fridge?
If it is just the Fridge I am assuming your unit has been around for a while.
If you have a mildew build up in the plastic tubing of your ref it can be a tedious cleaning procedure to get it all out of the system The stuff ends up sticking to all of the plastic tubing inside the unit and is so hard to get rid of. What you can do is have all of the plastic lines changed out in the Refridgerator from the water valve outlet to the the water in door and icemaker. It is just time consuming to do it.
Water supply to unit off for the steps below.
You can try using a small baster (I use a hair dye applicator bottle) and a bleached water mix that is not too strong. I would recommend that you start AFTER the water valve in the bottom of the unit. You have got to be able to introdue enough pressure through the system so that when the water in door switch is activate that the bleached mixture will flow out of the spout. You will have to introduce the water until you can smell it in the water you get from the glass you used to catch the water. Then let it stand for an hour. Re-intorduce the same amount of bleached water as before and wait another hour. After the second mixed water bleaching reconnect the water supply and purge it at the water in door outlet with a glass.
Probably sounds a bit much but this is from experience and believe me it does take lots of time.
I am sure this is not what you were expecting but it really is the only way your going to rid yourself of the bad smelling and tasting water CURSE.
Thanks for using FixYa!
Kelly
Feb 18, 2010 | Pds GE Profile Bottom-Freezer Drawer...
Hamilton Beach Water Cooler Model 2202 cold water does not get cold. How can I fix the problem
No Cold Water
Hi. I have a Hamilton Beach Model 2202 and it's been working fine until last week. Now I have no cold water.
Aug 15, 2009 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach water cooler dysfunction.
Check to see if the dispenser has an integral water filter. If yes, replace it to improve the taste of the water. If no, then unplug and remove the top panel and shut off the water supply line to the unit.
You'll want to drain the cooling tank and clean it with some white vinegar to remove any mineral deposits that could be affecting the taste of the water. You'll want to lightly scrub the inside of the chilling/cooling tank with a mixture of at least 2/3 white vinegar and warm water to help dissolve any residue in the tank.
After you've gotten it as clean as possible, turn on the water supply line and flush the tank by filling a pitcher from the cold water dispenser. Do this for at least 2-3 gallons of water to completely clear out the vinegar mixture.
You'll also want to remove and sanitize the dispenser valves on the front of the unit, as there could be some gunk inside the spout that is adding to the foul taste and odor.
I would also suggest you install an inline charcoal water filter to the supply line serving this cooler, as that will only help improve the taste and clarity of your drinking water.
You should be able to adjust the temp of the cold water with a thermostat controler located inside the cabinent. You might want to contat Hamilton Beach to obtain an owner's manual for your unit to get more detailed information about use and operation recommendations.
Hope you found this info very helpful and best regards!
Aug 06, 2009 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach Water Cooler with Storage Cabinet Logo
1,182 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
fixits
Level 1 Expert
Dan Webster
Dan Webster
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
