Question about Acer Aspire 4315 Notebook
My LCD monitor is blinking very frequent.
My acer aspire 4315 is just 11 mnths old.windows XP is my operating system...what seems to be the problem?.i hope hope you can help me..thanks
  • bustanil Jan 16, 2009
    Have the same problem, Windows reinstallation didn't fix this.
  • 741 Answers
When the refresh rate changes then the screen will flicker. Change your refresh rate to above 75.
Here is how: Click on Start>Control Panel>Display>Settings>Advanced>Monitor>and you will see screen refresh rate. Change to higher rate.
Rate this solution.
Posted on Jan 09, 2009
I have no driver for ACER ASPIRE ONE ZG5
Hi, welcome to FixYa.
First, what is your operating system. I assume you are using either Windows XP or Windows 7.
Get the driver from here:
http://www.notebook-driver.com/acer/acer-aspire-one-netbook-windows-xp-drivers/
I hope this can help.
Mar 06, 2011 | Acer Aspire One PC Notebook
How can i install windows xp in acer aspire m5641 can u tell me plz yours best regrds zakir
The acer aspire M5641 , usually ships with windows Vista. If you are planning to install windows Xp. You would have to source the windows xp cd. You cannot buy the XP cd from microsoft as windows xp is now and end of life operating system and not sold off the shelf. However if you already have the XP cd with you , you can use the same cd. Note hardware on your acer may not work , because of driver unavailability for XP operating system. However if your system was shipped with , refer to the following video links to guide through the reinstall process
Link 1
Thanks for using Fixya
Proton
Oct 06, 2010 | Acer Aspire M5641 PC Desktop
My Acer Aspire one screen flicker, I am running windows xp with 1 GB ram, I try to connect a external lcd monitor, the monitor display do not flicker. It seems that if I don't use full screen, the flicker...
Please check the refresh rate of the display. If it is more than 60Mhz, it could cause your LCD to flicker.
Go to your display options and adjust the refresh rate.
If that does not fix it, it could be a possible problem with video card.
Try updating the driver software for the integrated video card.
Good Luck Kumpadre!
Sep 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
My operating system is XP. the driver for this
To the best of my knowledge this is a pnp device witch stands for plug and play you should not have to download any drivers but you should only have to go in to your properties and adjust the settings
Right click on the desktop and go to properties then in the next window click on settings adjust them to this
Maximum Resolution & Refresh Rate
  • 1440 x 900 @ 75Hz AND in 32bit color
that should salvo your problem :)
Apr 22, 2010 | Acer X193W LCD Monitor
My PC is assembled one and i have a new Acer LCD monitor. The Operating Systems is Windows XP. Now when i am opening my computer it shows "empowering Technololgy" on the screen. Why its shows the message...
Check the system start up and try removing the programs from running during start up.
Also get a system optimization software to help you manage your system processes
Thanks i hope this helps..
Please don't forget to rate my solution if it helps you.
Thanks
Apr 12, 2010 | Acer Aspire 4315 Notebook
Acer ASPIRE 6530
You cannot uninstall Windows Vista, but you can reinstall your previous operating system, which then replaces Windows Vista. To reinstall your old operating system, you must have the original installation disc. Back up your programs and files, insert the installation disc into your computer, and then reinstall the old operating system. To regain the hard disk space used by Windows Vista, reformat the disk during the reinstallation process. After reinstalling your previous operating system, reinstall your programs and files.
More information is here:
http://support.microsoft.com/kb/978788
You may want to consider upgrading rather than downgrading.
Jan 15, 2010 | Acer Aspire 6530-5143 Notebook PC
Acer laptop stuck on Aspire screen
i/run operatin disk take prompt comman and type chkdsk/rr 2-3 times it can be repair your system 2/ repair by operating disk if not work by two methode reinstal operating system.
Oct 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
LCD screen of my Acer Laptop aspire 4315 is blinking vigrously.
you should be a frequent traveller, and might be having very rough with the laptop. anyway acer is a genuine brand and never shows such problems, and this should be the mistake of yours in using it. just try the following, remove o.s from system completely and reload the o.s. (genuine windows vista reccomended) if this not corrects the problems, you should sell it for the cost they are bidding for, because if the above said hint does't sorts out the problem, then it should be a technical error,and this requires service by a qualifies proffesional.and since you can't afford it, better sell it when its working properly. get back me for any assistance @ deepuunni1985@gmail.com
Aug 22, 2009 | Acer Aspire 4315 Notebook
Drivers for the Acer LCD monitor X193W under Windows XP Pro.
The acer LCD monitor is plug and play.You don't need a driver.But unless you have a graphics card that supports at least 1440x900 you have problems. Also if your card has a div connection, use that instead of the analog connector, The monitor comes with that connector. Use the old one to connect a second CRT monitor if you want. Don't connect both to the lcd monitor and to the computer unless you are using a second monitor. Like everything these days, every purchase seems to need an upgrade of sorts, On board graphics **** anyway. Buy at least a 128 MB graphic card with a digital connector and more RAM never goes astray.....
Ron
Nov 09, 2008 | Acer X193W LCD Monitor
LCD problem
ok just go to Start- Settings -Control Panel - Power options -click on it inside that turn off monitor option Never u say and system stand by u make it as Never apply and say ok it will not go to stand by mode
Jul 30, 2008 | Computers & Internet
Acer Aspire 4315 Notebook Logo
300 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
