Question about Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ...
KITCHEN FAUCET (single handle PRICE Phister ) suddenly quit flow
I had water on and suddenly water stopped coming out of faucet and now no water at all..all other water in house works...must be in guts of faucet...I WILL CONTACT Price Phister , but what do I TELL THEM i need ? ..tc
  • 2 more comments
  • t_colby Jan 09, 2009
    This stopped too suddenly to be rust or calcium?..tc
  • daytoncapri Feb 02, 2009
    I have the identical story - it happened to me yesterday (Feb 1). At first it was reduced to a trickle. Now, NOTHING flows out of the faucet hot, cold or mix. It is not the aerator - removing that piece was the first thing I did. As the previous poster wrote, it must be in the guts. Now what?
    Now, I am trying to remove this faucet
    1) the mounting piece is rusted - not sure how that will work out
    2) CAN ANYONE TELL ME HOW TO remove the quick-connectors that join the sprayer, the faucet and the blended water together? There's a trick to it - slips in easy. How does it slip out?
  • Anonymous Feb 15, 2009
    help, the same thing happened to me!
  • ParkingLotB Apr 01, 2009
    I think I have the same problem with a similar model. It usually happends, when I first turn on the water; it sounds like a water hammer; "chungk!", and water immediately stops flowing. What I found is that the water has been diverted to the spray hose. With the handle still in the "on" position; I pull the spray out, point it down, and press the spray trigger. Water comes out of the spray, I release the spray trigger and water re-flows out of the main nozzle. Others have told me that it might be air in the system. That can't be, because it happens several times a day, for the past 6 months. I've flushed the system for air 2 times already. I think I need to take this apart and see if any of the parts need replacing.
  • 686 Answers
Take it apart and clean out calcium lime or rust build-up. Also check to be sure your shut-offs are clear and running well
Posted on Jan 09, 2009
Heater takes more than 1 minute to get water to kit faucet , then temp fluctuates
1) Guesses: Sounds like a bad single-handled faucet cartridge, or low water flow at faucet, or clogged water filter.
Replace faucet cartridge, clean the aerator, and/or clean sediment out of pipes below sink, and clean water filter at tankless unit each month.
2) For exact measure of problem:
Typical faucet can have 2 gallon per minute flow rate.
2 gpm flow rate means faucet fills 1 gallon container in 30 seconds. Test faucet using 1 gallon container and a cooking timer to get flow rate.
Clean aerator to improve flow rate. Compare kitchen flow rate with other faucets in home.
http://waterheatertimer.org/Low-hot-water-pressure.html
Most homes have 1/2" diameter pipe running to kitchen faucet.
100 feet of 1/2" diameter pipe holds 1.2 gallons of water. This assumes no sediment build-up inside pipes.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Assuming only hot is turned on: If faucet is 100 feet away from water heater, and pipe diameter is unobstructed 1/2" diameter, and faucet has 2 gallon per minute water flow, then hot water should arrive in 36 seconds.
50 feet away, and hot water should arrive in 18 seconds.
If kitchen has single handled faucet, and the handle is raised in the middle, then equal amounts of hot and cold water are drawn at same time. This doubles amount of time for hot water to arrive.
If single handle faucet has a bad cartridge, then faucet can have crossover.
Crossover means that cold water can enter the faucet even if faucet is turned to hot.
Bad single-handled faucet cartridge can delay or stop the arrival of hot water.
http://waterheatertimer.org/Crossover.html
Tankless require maintenance including cleaning combustion parts yearly, de-lime heat exchanger frequently, and clean water filter each month.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 15, 2011 | Rheem Direct Vent Natural Gas Tankless...
Water quits flowing
There is a little popper in the spout area. You need to remove the top handle and slide the spout off. The popper is in the main tube coming up. It.s a standard part at most big box hardware stores and it costs less than $10.
May 19, 2010 | Delta 2402 Classic Single Handle Kitchen...
Pressure surging thru Delta single handle faucet. The water flow starts and stops suddenly when the faucet is more than half way on. Same for hot and cold.
I don't know if this is your problem or not, But I had a new faucet and it did the same thing. I found little tiny pieces of polishing media stuck in side the faucet. Every time you turn on the water it comes out fast , then trickles, drove me nuts, I took it back and got another, no problem, hope this helps.
Apr 21, 2010 | Delta 2402 Classic Single Handle Kitchen...
Why did my moen faucet stop working? I have water flow throughout the house but the flow at the kitchen faucet just suddenly stopped!
Rubber gasket on the water shut off valve under the sink has come off and traveled up into the faucet. It's pretty difficult to get it out. If you have access to an air compressor you may get lucky by taking the faucet completely off the sink and blowing air back from the faucet outlet back into the internal piping to dislodge the rubber piece. If that doesn't work, or you can't use the air compressor method, then it's a trip to the hardware store for a new faucet.
Jan 11, 2010 | Moen 87530 Touch Control Single Handle...
Water running in Moen single-handle kitchen faucet suddenly stops
There is a small diverter valve on the faucet underneath where the hose connects too it needs to be replaced depending on the age of the faucet I usually recommend replacing the entire faucet with another Moen product
Oct 18, 2009 | Moen Plumbing
Delta Kitchen Single Faucet 470 suddenly would not give water
Debris in the valve is a fairly common cause for stopping water flow in single lever valves. You can first check the aereator and remove any debris that may be there at the faucet itself. Then you can try to remove the ball at the control lever. You have to be careful and make sure that you do not drop any parts. Especially if this is a recent installation, you may find a large piece of something there.
Jun 15, 2009 | Delta Faucet Delta 470-BL-DST Signature...
No water flow in gooseneck faucet
Sounds like the diverter part (insode the faucet) is clogged or broken.
May 27, 2009 | Price Pfister J103-BC 100 Series Kitchen...
The hot water stops coming out of faucet
if this is the faucet in picture, turn off water, pull out cartridge and inspect for any debris in cartridge or valve body, if not, turn on hot water to see if water is getting through valve body. May have kinked line or debris from or in angle stop line.
Apr 12, 2009 | American Standard Kitchen Faucet 6310 020...
My price pfister bathroom faucet wont shut off.
you may need a new fucet...the manifold opening for the cold has probably craked or split
contct price Pfisterrdirectly they may send you a new faucet
Price Phister is more about looks than function they want to keep their marketing sales
when I built my house I ut rice phister in because of the looks ..function was marginal
Jan 30, 2009 | Price Pfister Marielle Kitchen Faucet with...
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
447 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
