Question about Mitsubishi VS-45603 45" Rear Projection Television
No picture or sound on Mitsubishi VS-45603
HELP!! When I turned my tv off one night, it was working fine. When I tried to turn it on the following day, I got nothing...no picture, no sound. The green light on the front does light up though. I have been told it could be the bulb(s - ??), a power converter or a leaking D980. What are your thoughts and what kind of prices am I looking at for repair?
  • peachy4263 Jan 09, 2009
    I have the back off of the TV. I can see no evidence of a leak, but can you tell me what specific area I should be looking?
  • 108 Answers
You may want to inspect it for a fluid leak. Look on the signal pcb first. look for any signs of liquid on the connectors. If the leak is found and has been there for awhile before it finally shorted out a connector then chances are that it corroded the pcb
Posted on Jan 09, 2009
  • Chuck Jan 09, 2009
    look from the front of the set, remove the speaker grill and you will see a kick panel, remove it and inspect the circuit board to the right of you. It should be green. Inspect it for black spots, or gooey residue.
No picture only sound
This old tv likely has lots of capacitor problems by now !! JUNK it and save yourself as SERIOUS headache !!
Apr 11, 2014 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-45603
You will need to go into the menu, setup, a/v connection, then make sure the locked to input is selected to no..
Good luck..
Sep 17, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Hello I have a mitsubishi vs-45603 with what appears to be a convergence problem.
You may have bought bad chips or your soldering...
This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Mar 22, 2012 | Mitsubishi VS-45603 45" Rear Projection...
After big storm the tv only shows small picture in upper right corner. Will not allow to go to full screen. VS-45603
You are in pip mode, and if itwill not let show on regular mode, then your tuner is out,and youcan bypass it and go directly into the video input with RCA cables from your recieever,and put your set in video mode,better picture, and save you 500 dollars on a new tuner.
Jul 07, 2011 | Mitsubishi VS-45603 45" Rear Projection...
No picture
make sure the tv is in the correct input, either tuner channel 3 or an a/v input
Dec 16, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
NO picture
If you go to the following link. we have the service manual for your tv for 10.99 and we provide unlimited chat support to help diagnose and repair your TV. Just click on mitubishi and you will see your manual. then click on the contact us link and provide your email address we will email your manual and instructions on how to enter into the chat sessions. Hope this helps.
http://servicemanuals.vstore.ca/
Jan 12, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Only Picture in Picture Works...????
Its possible some of the surface mount capactors has failed on the pip board is so the unit will need to be replace or repaired.
Mar 18, 2007 | Mitsubishi VS-45603 45" Rear Projection...
Televison & Video Logo
249 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
