Question about JVC THC5 Home Theater System with 5-Disc DVD Changer System
How to connect my JVC ThC5 Home Theater System to my TV?
I have connected all the Cables and everything. I have a Sony Vega TV(early 2000s) but all that comes up is the static.
5 Suggested Answers
SOURCE:
  • 34 Answers
SOURCE: home theater
Just go into your sat box setup menu and under setup system option select audio and make sure to go to the dolby digital option and turn it on. This feature is turned off by default from the factory. You will always get 2 channel sound unless that is on. Also remember to go to a hd channel as they are broadcast in surround sound and non hd channels are broadcast in 2 channel.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Posted on Nov 09, 2008
SOURCE: home theater system jvc th-d60
This is from the TH-D50 User Manual:
The connected TV is not HDCP-compatible. (“HDCP ERR” appears on the display.)
Disconnect the HDMI cable and connect it again, or use a shorter cable.
Posted on Dec 31, 2008
  • 22 Answers
SOURCE: Connect IPOD to JVC TH-M505 Theater System
http://www.superwarehouse.com/Cables_to_Go_iPod_Audio_Cable/35508/p/1492128
the above cable will allow you to plug your ipod into the audio in on the stereo
Posted on Jun 13, 2009
  • 65 Answers
SOURCE: i have a JVC, Home Theater system. It is a TH-C30.
I think there may be a possible chord disconnected or the fuse may be bad!
Posted on Apr 26, 2010
Getting tv sound from home theater speakers
Connect your sound from the cable box out to the JVC theater audio in jacks. This will give you sound through the speakers.
Jan 29, 2014 | JVC TH-C50 System
Home theater system jvc th-d60
have you used a different connector cable?
if not try that first
Aug 22, 2008 | JVC THD-50 System
Connecting HT-ct 150 to cable box, and tv with HDMI cables
The user manual for the device should contain a schematic of the various cable sockets:
Sony HT CT150 manual
Feb 05, 2013 | Sony HT-CT150 Theater System
I HAVE A JVC HOME THEATER SYSTEM MODEL NUMBER TH-C5 THAT THE RECEIVER POWERS UP BUT THE SUB WILL NOT AND THE SPEAKERS ARE NOT WORKING.
Page 42:
No sound. The system cord and/or speaker cord is not connected. Check the connection.
The audio cord is not connected to AUDIO IN (VCR)
and/or DIGITAL IN (DBS) correctly.
Connect the cord correctly. (A pg. 13)
An incorrect source has been selected. Select the correct source. (Apg. 17)
The decode mode is not set correctly. Select the proper decode mode. (A pg. 35)
http://www.retrevo.com/support/JVC-TH-C5J-Home-Theater-Systems-manual/id/318ag518/t/2/
Do you think the powered subwoofer itself might have a power problem? Check its cord.
Dec 26, 2010 | JVC THC5 Home Theater System with 5-Disc...
Running my tv sound though the home theater
Depending on the type of connection your TV has, you would either connect RCA type cables or an HDMI cable from your TV to the Samsung unit. If you hook up and still don't get any sound, check you cabling ti ensure it is plugged in the correct way. If you don't have the manual, you can go to the following URL to get one:
http://www.samsung.com/ca/consumer/detail/support.do?group=audiovideo&type=hometheatre&subtype=hometheatresystems&model_cd=HT-BD1250T/XAC&mode=C
Jul 10, 2009 | JVC THG31 Theater System
How to get 5.1 sound from plasma tv to home theater system?
You just need to connect an Audio Out port on the back of your TV to an Audio In port on the back of your JVC box. See what connections you have, I'm sure there are lots of options for you such as HDMI or just normal 2-cord audio cables.
Mar 18, 2009 | Sony VAIO VGP-WKB1 Keyboard
Can't eject dvd's.It says"LOCKED'How do you unlock to eject dvds
To unlock the JVC TH-C5 disc tray is by having the system off and at the same time hold the stop button and eject button until it says, "Unlocked".
Jan 10, 2009 | JVC THC5 Home Theater System with 5-Disc...
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
247 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
