The ink cartridge is not properly fitted or installed or does not detect the ink catridge, remove again and fitted it correctly.
Also, clean with alcohol the gold chips of the ink cartridge and maybe there is sticky residue when you remove the sticker. Turnoff your printer and plug it on again to refresh the memory.
Go to Control Panel->Printers. Then right click on your printer and select printing preferences. There you will see an option like Print in Grayscale or Black and White only.
However, please note that some printers although they are set to print in grayscale they also use the color cartridge and some even don't allow you to print in grayscale if the color cartridge is empty. Why is that? Manufacturer's way of charging you more money.
no both are different Here are the list of cartridges u can use MP210 PG-30 Pigment Black PG-30 Pigment Black Ink Cartridge PG-40 BLACK CL-31 Color FINE Ink Cartridge CL-41 Color MP240 PG-210 Black Cartridge CL-211XL Color Cartridge CL-211 Color Cartridge PG-210 XL Black Cartridge
the ink or toner is contrammed with foreign liqued like oils, water, bad ink, bad toner cartridge,
oil, water, ink toner inside the ink itself
oil from a human skin my have came in contact with refill of ink or toner cartridge, cleaning solvent to clean the cartridge, needles for hte ink or toner cartridge, water in the ink or toner cartridge, steam or vapors of some kind, compress air can or air compressor will spread water solution, the freon is used in compressed air can thats way they get so cold when you spray the can.
paper may also be wet some how try new and different brand of paper.
How I can fix the U051 problem with my conno : MP470 printer ? It says the print head is not installed. Install the print head. Where is the it , and how I can fix it?
please e-mail to [email protected]
I figured it out! For all those who have problems clicking it into place it's probably the printer's not on. Turn it on an the top half of the cartridge holder which is connected to the printing head should slide to the left part of the printer when it's on, then slide the cartridges in an click in.
