Netpassage 18a Setup problem.
I have netpassge 18a wireless router but don't have any installation cd or manual can any body help me to install this?
The above link doesn't work... redirect?
Posted on Aug 06, 2009
  • 154 Answers
Hi, paste this link into the browsre and you'll get the manual in PDF format.
www.compex.com.sg/home/Datasheet/NP18A_DSv1.1.pdf
Posted on Jan 12, 2009
Nstallation cd is missing for DIR-600...Hello, If you don't have the installation disc anymore, you can...
open the setup page of the router and change the settings manually.
Like other routers, you can install wireless router without installation CD also,
Read how to setup router without installation CD
Jul 04, 2012 | D-Link DIR-600 Router
Wrt120bn wireless router cd installation
Are you trying to setup Linksys router?
You can run the installation CD to setup Linksys router or you can do it without installation CD also.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router.
Change the Internet connection settings.
Create a new wireless network.
Connect to the network.
I will suggest you a website that you can try to setup your Linksys wireless router without installation CD.
May 21, 2012 | Linksys Wireless-G WRT54G Router
Hi! I am a computer professional working to
Hi Kavin,
What I feel after reading your issue is that you are making some mistakes while configuring the router.I am sharing a link below, please go through the pdf document before you configure the Netpassage 18.
http://www.nowire.se/produktblad/Compex/NP18v1.2C-manual.pdf
This is a very good guide to know how the device can be configured.Remember few things.1) Disable all the security measures like Firewall,NAT etc. before configuration.2)Enable SSID broadcast3)Under Basic configuration of PPPoe where you are asked that "Your internet connection require a login"go through this area very carefully.This is where you are making the mistake. Here you have to make changes as per your Internet service provider. Whether it is a login type or not you know that better.It should be always on mode4)Your wireless settings should have a SSID and Security Options (WPA-PSK ) and this key will be your password.5)GO through Chapter 7 very carefully.6) Enable Wireless Router Radio7)Enable SSID Broadcast8)I hope after going through this you will be able to configure the router.Please revert back incase you face any difficulty.Thank you,Avishek
Jan 12, 2012 | Compex NETPassage 16A (NP16A) Wireless...
Where to download the installation disk
Are you trying to setup router?
You can install your router manually.
You don't even need to run the CD>
Just open the setup page of the router and change the Internet connection settings manually.
See Linksys router setup
Jan 07, 2012 | Linksys Wireless-G WRT54G Router
I lost my belkin installation cd
You do not need the installation CD to use the router. Check this link to download the user manual and quick install manual. As well you can download an updated firmware for your router along with installation instructions.
Good Luck.
May 06, 2011 | Belkin F5D8236-4 Router
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
Can you give me a step-by-step tutorial to install my wireless router to my desktop computer?
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready! Here's the manual: http://static.highspeedbackbone.net/pdf/Netgear-WNR2000-manual.pdf
Dec 22, 2010 | NetGear WNR2000 Wireless Router
No cd to help install router
ya without ch u can install
open ur browser type 192.168.0.1 means do in manual way by click on router icon in my network place
Jun 26, 2010 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
191 people viewed this question
David Payne
David Payne
