Question about Kyocera Finecam SL400R Digital Camera
Image on camera freezes
The screen on the camera freezes two or three times in a few minutes. I have to turn the camera of and on again to re-start, missing the moment. please help, Steve.
  • steve mcbride Jun 04, 2007
    thanks for your help
  • steve mcbride Jun 06, 2007
    Thanks for the advice,Ill try this, Ta.
    Genius:
  • 2,985 Answers
This look like an connection problem. You could try squeezing the casing here and there to see in the connector[s] resets- but failing that it is a repair shop job
Posted on Jun 03, 2007
  • john ash
    john ash Jun 04, 2007
    Hang on there I have had a thought
    You see I don't use the screen to compose - in fact I can not as my camera is an SLR.
    So check the Battery save setting'- some cameras- one of mine did- went to Sleep in no to flat if it was on and waiting for something to happen.
    I missed a whole bunch of whales in the Antarctic because of this - stabbed the button and by the time the camera 'woke up' they were gone.
Sony vaio nb laptop touch screen freeze
Hello Adnan eickov
Pls go to start menu and select screen calibration option. and re calibrated.
Mar 05, 2014 | Computers & Internet
My Sony DSC-w55 turns on and reads on ACCESS on black screen.
try to remove the battery for a few minutes this should refresh its system once you power it up again.
Aug 10, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Won't stay on
I just posted a few minutes ago with the same problem. I fixed it myself with no one telling me what I needed to do. What I did was as soon as it starts turning on smack it on your hand a couple times. Make sure you use a bit of pressure. It showed a camera view for 3 seconds then shut off so I did it a couple more times and now It's working again just fine. If you have any questions feel free to email me. Yes it can be a crappy camera. But hit it against your hand a few times and it'll work. Let me know if it does for you.
jadedragon123091@yahoo.com
May 12, 2009 | DCS Norcent Technologies XIAS DCS-1050...
Freezing and three n two rings
you need to go over the mainboard with a heatgun in a circular motion 2-3 inches away from it. pay attention to around the cpu, gpu and memory chips and you will end up re-seating the solder and should fix this better for you. i dont know what you did to fix it in the first place but i can say that errors like the 3rrod really benefit from taking your time when doing the fix and making sure everything is covered.
www.fixmyconsole.co.uk
Jan 31, 2009 | Microsoft Xbox 360 Console
Xbox 360 Freezing Problems
Shutting off the Xbox corrupted the Hard Drive... Have you ever got a Live System Update? You can also reset your Xbox without shutting it off using the controller. You probably have the Three Red Rings of Death... Go to this...
http://www.fix3redlights.com/?p=bfy&m=1&gclid=CKTS1MGEmpcCFRlRagodpD9H-A
Nov 29, 2008 | Microsoft Xbox 360 Console
Blank screen on camera when turned on...cannot take picture
Though there may be an alternate reason, It sounds as though you may be experiencing a failed CCD image sensor with your camera.
Try pressing the display (DISP) button on the back of your camera several times to see if your image returns at any time. One of the three display modes is "off" to preserve battery life. Your problem may be as simple as inadvertently pressing this button into the off mode.
If that doesn't work, try doing a reset and then removing your batteries from the camera for a few minutes, reinstalling them and turning the camera on to test the LCD screen.
If your screen is still black, but you can clearly see pictures taken previous to the problem, and you can clearly see the menu system when you press the MENU button, then you likely have the CCD sensor problem. Contact Canon Tech Support at 1-800-828-4040 to have the camera repaired.
Hope this helps.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon Cameras
Canon Power Shot A710 is
The hand with parenthesis is your image stabilization. It sounds like if your images are turning out black, you may need service.
Try hitting your display button a few times and see if anything shows up on the screen.
May 29, 2008 | Canon PowerShot A710 IS Digital Camera
My xbox 360 keeps freezing!!
wrap your 360 in a towel (Completely Covered), turn on the system for about 10 minutes, turn it off, then back on again and and it should work.Although this fix only works fr about three hours it works over and over but the problem you have can also be fixed by replacing the thermal compound on the heat syncs and it should only cost about $5.00 to fix your 360. But my second solution should only be used if the warranty is void
Apr 02, 2008 | Microsoft Xbox 360 Console
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Image on the screen freezes and camera won't respond.
I require the software to enable to download pictures for my
finepix fuji f601z
Nov 17, 2006 | Fuji FinePix F601 Zoom Digital Camera
Kyocera Finecam SL400R Digital Camera Logo
50 people viewed this question
Top Kyocera Cameras Experts
Harrie
Tony Parsons
Tony Parsons
Are you a Kyocera Camera Expert? Answer questions, earn points and help others
