Question about MTX RT2200 Car Audio Amplifier
Constant sound from subs
I have an old MTX RT2200 amp powering 2 10" kicker comps.  When I plug the RCA cables are in and the you move either the gain or the bass knobs up, the subs just start pounding, Not with the music or anything, just pounding. When you turn the gain down, the pounding stops and the subs just barely output music.  When you pull the RCA Cables out the pounding stops and the amp doesn't do anything when you mess with the gain and bass knobs.  I don't know if its the amp or the head unit. Any suggestions on figuring out what it is, or solutions?
PS that RCA Cable is brand new.
  • thomaspatric Jan 09, 2009
    I tried that and it didn't work, I went to a local car audio store and talked to the guys there and the amp bad, I got a new Alpine Amp and its pounding beautifully, Thanks for your help!
    Problem Solver:
  • 6 Answers
I Had the Same Problem I just unplugged my amplifier changed the fuse, also i had a fuse in the battery cable and changed that, unconnected the RCA wires and plugged them back in and then put new fuses in and plugged everything back into the amplifier and it worked again. If that doesnt work get back to me i will try to help you.
Posted on Jan 09, 2009
  • Anthony Michaels
    Anthony Michaels Jan 09, 2009
    ok if you have any other questions feel free to ask ok?
Amp and sub have been working great together then all of a sudden the amp is not putting out enough power to push the sub. MTX Thunder 311D
check to see if one of the RCA cables is unplugged or bad. check the gain check the sub level control on the deck if yours has one.
May 19, 2010 | MTX Thunder 311D Car Audio Amplifier
How do i wire a 8 ohm kicker comp 10" sub inside the box? and what is the best way to get more bump with a 600 w mtx amp and kicker comp 10" sub?
Ok, for an 8 Ohm sub, it is advisable to get another 8 Ohm sub. wire them in parallel down to a 4 Ohm load. You would wire both + wires together, and both - wires together to yield a 4 Ohm load at the amp. Majority of the amplifiers on the market are designed to give more power at a lower impedence, or Ohm load. You just have to make sure that your amp will take a 4 Ohm load. Without knowing the model of the MTX amp, I can't give more advise. However, this should be able to give you and idea of where to start. The main problem is that you have a single 8 Ohm sub in the Kicker Comp.
Apr 30, 2010 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
Had the subwoofer tested at an audio shop but they wanted to sell me a woofer. It makes no sound at all. A power issue? there was no problems with the 300 watt Kicker amp.
if the speaker cone moves it should produce some sound if it doesn't move when power is applied then the voice coil is frozen.
not really a power issue unless its a "powered sub" and if that's the case then you should not be running in high level sound using speaker wire (especially off a 300 w amp) but instead a low level signal via RCA cable.
Dec 28, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Constant pounding of subwoofer
Have you tried another pair of RCA's? Sounds like you have a bad pair of them.
Feb 07, 2009 | MTX RT2200 Car Audio Amplifier
Subs dont beat like they should
you've spent alot of money on **** by the sounds of it!!. you should only ever run multiple subs the same brand, power and resistance you can just connect any old subs to a system you need to wire them depending on the load that the amp needs to see. first thing is to try the amp/s on a individual sub to check your amps still work once done check the subs 1 by 1.
Jan 20, 2009 | Jl Audio 500/1 Car Audio Amplifier
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Sep 30, 2008 | MTX Thunder 3401 Car Audio Amplifier
Kicker zx1500.1: no sound output
Does it make the same noise if the RCA cables aren't plugged in?
Apr 10, 2008 | Kicker ZX10001 Car Audio Amplifier
Mtx 895 trouble
check your fuse up front first. some amps will turn the light on with only the remote wire (the 12 volt signal from the head unit). That may be your issue. If not you need to check your signal input. try hooking the rca's to a diffrent source, i.e. other radio your tv anything with Rca out put. If still you get nothing then pull your subs out and take a regular 9 volt battery and touch the leads to the positive and negative of the sub. Just for a moment though if the subs move when they come in contact with the charge from the battery then my last suggestion would be to take it to a store where you can have an authorized tech check out the equiptment. Good luck
Nov 19, 2007 | MTX Thunder 895 Car Audio Amplifier
Feedback/maxing out speakers.....
starting from amp,what is the rca connected directly to. headunit or adoption?
May 05, 2007 | MTX RT202 Car Audio Amplifier
Subs will go off the wall with bass, but not in tune with music.
hi, first disconnect the rca input, then switch on headunit and if the amp produces a constant bass thump it then means it has an internal fault. if the amp idles quietly then replace the rca cable, or try connecting the headunit lineout feed directly to the bass amp, in this way you cud find out if your fault is coming from the headunit or the equaliser. cheers
Nov 23, 2006 | MTX Thunder 8302 Car Audio Amplifier
MTX RT2200 Car Audio Amplifier Logo
184 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
hoyzee1
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
