Question about Dell Latitude D600 Notebook
Update BIOS for memory upgrade
I installed new memory cards to upgrade my dell c640 ram from 512 mb to1 gb (2 512 mb cards). However I have not been able to update my BIOS to complete the upgrade. My BIOS needs to be reset to reflect the upgrade but I cannot navigate in my BIOS past the area to change the date. Please advise
  • dyymand Jan 09, 2009
    Thanks for your help----I reinstall the memory and it works now.
    Thanks again U R THE BEST!
    Master:
  • 409 Answers
You cannot change the memory settings in BIOS. All you need to do is go into the bios screen. confim that it has seen your new memory and "save and exit" If it is not showing your new memory try removing and reinstalling the memory confirming it is installed correctly. it should just see it.
Posted on Jan 09, 2009
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Computer beeps six times after installing new game. Precision workstation 670. Ram sticks are a 1GB each. My old ram works fine with the computer.
You need the EXACT speed rated RAM.
Your support page states it needs.....
400-MHz DDR2 SDRAM
NOTE: Your computer supports only registered memory
Memory capacities
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC modules to a max of 16GB
more info here
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/about.htm
Jul 26, 2010 | Dell Precision Workstation 670 PC Desktop
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
I upgrade the memory of a Dell Dimension Desktop 9150 from 512 MB to 2 GB,The machine accept up to 4 GB..In the BIOS appear the 2 GB but on system in Control Panel only shows 512 MB..Can anybody give me a...
No you don't have to install a 64 bit OS. Only if you install over 3 gigs you MUST install a 64 bit operating system. 800MHZ is fine it will just back down to 667MHZ. your 32bit windows OS will see up to 3 gigs (minus graphics card memory). SO 2 gigs will work fine. Install one stick at a time and check in the OS and bios to make sure each stick works. I would say you possibly have a dead ram stick.
Jun 03, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I want to upgrade my HP BA 600 Mother Board`s RAM Capacity
Most likely your MB is too old for this upgrade although there is a chance you could flash your bios (reprogram your computer's brain to accept the new memory providing hp has a flash for it).
here is a link for the latest bios flash for your computer, use at your own risk.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=32895&swItem=vc3903en&prodNameId=20305&swEnvOID=54&swLang=13&taskId=135&mode=4&idx=0
good luck.
Thank you,
agadycom
Nov 27, 2008 | HP Computers & Internet
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Getting access to bios in Dell Inspiron 1300
No, The amount of RAM the integrated video uses is dynamically adjusted depending on the loading of the video and the total amount of RAM installed.
If less than 512 MB RAM, the video is limited to 64MB, 512 to 2 GB max video RAM is 128 MB.
If you want to upgrade RAM to improve performance, check the link below:
http://www.crucial.com/store/listparts.aspx?model=Inspiron%201300
2 GB for $50 + tax, not bad
May 17, 2008 | Dell Inspiron 1300 Notebook
RAM Memory upgrade: 1gb modeles recognized as 512mb
You may have incompatible memory. double check your order and use only recomended name brand memory such as Kingston, you can look up the correct memory on their website, or on newegg.com
Apr 23, 2008 | Dell OptiPlex GX270 PC Desktop
BIOS detects only 128 MB instead of 1024 MB
Does the motherboard support 1 gig ram modules? what kkind of motherboard/video card do you have? sometimes video card onboard ram can ofset motherboard ram, especially with ati video cards.
Mar 17, 2008 | PC Chips M870 Motherboard
Dell Latitude D600 Notebook Logo
322 people viewed this question
Alun Cox
