TV audio too low with converter box
Audio has dropped so low that it can hardly be heard sitting close to it - in particular, NBC. This is true whether I use volume on TV or remote.
  • 3 more comments
  • Barbra Richman
    Barbra Richman Jan 09, 2009
    electech1 - Thank you very much for your comment. I feel very negligent that I didn't mention or notice this before - I got a Magnavox brand converter box from the gov. The remote has a button called "audio" that I don't know how to use or what its for. That could be my problem! I cannot seem to raise or lower the sound with the remote. As far as I know, I can only do that with buttons on my TV. This sounds crazy - can you still help me?
  • Barbra Richman
    It's as though you are thinking my thoughts . . . Were there different grades of converter boxes (CB)? I got my CB at Walmart. My CB remote does not have anything marked VOL + or - ; only channel + and -. It has channel up and down; Alt.CH; Display; Setup; Still; Audio; EPG; Return; ok; and Standby-On. I checked the converter box with a flashlight and there are no buttons or levers that deal with audio. I'm at my wit's end! Any further ideas? On yes, there is no mute button anywhere.
  • Barbra Richman
    Oh, I'm so glad you haven't tossed me into the wind! I'll try to answer your questions as best I can. In the "Setup Wizard 2/6", it does give me 2 choices: 1) "Autio Out: connecting STB and TV via Audio Cable; and 2) Connecting STB and TV via RF Cable". I have it setting on the first one for whatever reason. Am connected to box by coax - only the white and yellow jacks came with box - no red . . . which might have worked but I thought the other way would work better. (I might have been wrong). In "my" setuip menu, you cannot select mono or stereo (think I must have a lemon!) The model number on the box is: E175216. Thanks soooooo much for your help!
  • Barbra Richman
    Barbra Richman Jan 10, 2009
    Hi there! Glad to see you back. Everyone needs to rant from time to time. People are rude, and sometimes they just dont' know what to do.
    Which is where I am right now. I can't figure out how I got to the place I got to last nite where I can change to the RF cable! Don't call me a doo doo bird! Can you get me started? Hit "setup" and then what? Oh yes, I am very much wanting your help, and I thank you!!!
  • panette Mar 09, 2009
    Ever since we plugged the stupid box in....I feel like I am hard of hearing. We cannot get the volume to go high
  • 905 Answers
Leave the volume up on the tv to 50% - 80%, then adjust it from the volume on the box's remote control
Posted on Jan 09, 2009
  • 6 more comments
  • jason Jan 09, 2009
    I have mine a little less than 40% of volume up on tv and use the converter box volume control
    ok , look on the converter box remote for up / down buttons that are labled " VOL " short for " volume" should look simular to channel up / down buttons
    the "audio" button is for language option if it is available from the program
    also it is possible that the "mute button" may have been hit on the converter box remote.
    sometimes the volume buttons and the channel buttons will also have a + and - sign on them to indicate up and down
    wow! I have the zenith and digital streams converter boxes and both of these remotes have the volume control buttons
    but ok back to your audio , are you connected to the box by coax antenna or are you using the yellow video jack and red and white audio jacks( RCA jacks) ? also in the setup menu you can check the audio options they have for you in there , ( mono and stereo )
    also could you give me a model number on that converter box ?
    you really seem to honestly want the help and that is why I will help you till you get this setup the way you want it , I was just ready to finish up helping those who I have started to help and then I will no longer be giving my free help here , most people are just rude and act like I am getting paid for helping , when I do this for free , then when I give them the info they need , they just give me a bad rating , here is an example of the many rude http://www.fixya.com/support/t1509997-no...
    http://www.fixya.com/support/t1495173-rc...
    sorry for the rant , well it seems that your box then does not have the stereo red and white rca jacks( left and right )
    and the setting in your setup menu will need to be changed to the RF cable because you are using the coax cable ( RF ) connection and not the RCA jacks( audio and video jack connection) , so switch that to the RF cable ( radio frequency) and let me know if the audio is better
    electech
  • jason Jan 10, 2009
    well i don't know how all the new boxes(cb's) setup or menus will look like or have for option name discription of the setup names , but they should be somewhat the same , like functions or output,audio/ video , connection type ,
    but you mentioned here ," In the "Setup Wizard 2/6", it does give me 2 choices: 1) "Autio Out: connecting STB and TV via Audio Cable; and 2) Connecting STB and TV via RF Cable". I have it setting on the first one for whatever reason. Am connected to box by coax"
    so in the setup wizard 2/6 , is that 2nd menu choice of 6 choices?
    is where you will need change it to the # 2) Connecting STB and TV via RF Cable".
    the audio cable to tv selection from your box means that you would have to use the video cable also and your tv would have to be set to the video input , and not channel 3 for the RF cable
    let me know if that helps to find that setting ,
    and thank you for the rating, I thought I will probably still help every now and then here , just not as much and i will not care about the rating , just the fact that i am helping someone .
    if you need to , let me know some of the setup names , so i can point you to that option you were at
    oh I also wanted to say that if you have the RF cable connected then don't have the( audio and video) white and yellow RCA jacks plugged in
    and if you decied to have the yellow video and white audio , then the white audio should be in the white audio input on the tv and the tv audio will be mono out both speakers ,( if your tv has two speakers in it ), also the RF cable should be disconnected
    the reason for a video and audio RCA jack connection ( and other types of connection that seperate Audio and Video ( A/V ) , is that seperating the video signal from the audio signal will give you better quality of video and audio
Go to menu on your tv and find audio and make sure its on audio not something else.
Posted on Feb 17, 2009
LG TV volume drops usually on NBC why
If you're on cable, their audio levels can be adjusted by them. If it's an off air broadcast, the stations level is at fault
Mar 13, 2017 | LG Televison & Video
These answers do not fit my question. One day, on three different sets in my home, where I have received NBC for years just quit working. Did NBC quit broadcasting? It is not snowy, etc, it is just no
Ok This is what I found out and hopefully found your solution..
Have you heard of Double Rescan?
The Federal Communication Comission Designed a Process called double rescan.
Double Rescanning erases and thenreprograms the channels in the converter box an digital TVs memory.
To Double Rescan, you will first need to disconnect the antenna from the converter box or antenna.
Then disconnect the converter and or digital tv power supplies from the wall. Wait a minute before plugging them back in. The antenna should still be disconnected.
With the antenna disconnected run the channel scan function on the coverter box or digital tv. When the scan completes you will have completely removed any channel data the converter box or digital tv, had in its memory.
Now it's time to rescan for real.
Do this by reconnecting the antenna to the converter box or digital tv and running the channel scan function again.
Thus the double rescan is born.
If the double rescan doesn't work, then try some tips and tricks to get your converter box up and running..I will have to look up the url again that has the tips and tricks...
If the double rescan doesn't work let me know and I will look up more options..
I really hope this works..
Dec 18, 2014 | Samsung Televison & Video
How should I connect my Technics SA-AX730 receiver to my Panasonic TC-40A420U that uses HDMI?
I assume the Panasonic is a TV. I have never heard of green audio outputs. Audio outputs should be red and white (for RCA plugs). There are adapters available that convert the yellow, red and white component outputs to HDMI. You can get them at GameStop (I bought one recently to connect a game system for my daughter). If you have a TV converter box from your cable or satellite provider you might be able to connect the audio out on the cable box to your Technics receiver and run a HDMI to the TV (be sure to turn off the TV's internal speakers through the TV's menu) for video.
Oct 15, 2014 | Technics SA-AX730 Receiver
I have a CRAIG 13 INCH HIGH DEFINITION LCD TV MODEL #CLC503 I PURCAHSED AT CVS / PHARMACY I GET CBS AND ABC STATIONS GREAT BUT I CANT GET NBC??????? PLEASE ADVISE OF THIS ISSUE
NBC antena broadcasting signal is weak and it sit in pretty low ranges on the mountains tops call mountain Wilson.The broadcasting antena is weak and ur receiving antena is weak too.Tries websites like Amazon.com Ebay.com to buy a Digital antena and used it,will boot up ur tv antena receiving signal stronger and longer ranges.Than.U will able to get the NBC tv channel.
Dec 03, 2010 | Televison & Video
I have an orion sdtv mts stereo tv that works great. We live in a very rural area of montana and receive cabl television. I assume the tv is digital so I'm wondering why i cn't get the digital broadcast...
M2TS is a Sony high definition video file type. While it can’t supported by various PMPs. [b]
[url=http://www.topsevenreviews.com/aiseeosft-m2ts-converter.html]M2TS Converter[/url][/b] can convert M2TS video files to AVI, MPG, MP4, ASF, MOV, RMVB, WMV, DivX, Xvid, 3GP, RM, H.264/MPEG-4 AVC with excellent output quality. You can playback converted files on your Apple TV, Zune, PSP, Pocket PC, Creative Zen and suchlike PMPs. And at the same time, there are also a [b][url=http://www.topsevenreviews.com/aiseesoft-mts-converter.html]MTS Converter[/url][/b]
[img]http://www.topsevenreviews.com/guide/mts-converter/m2ts.jpg[/img]
[b]Key Features of M2TS Converter:[/b]
[b]1. Support MTS, M2TS and other HD video formats [/b]
M2TS Converter for Mac supports all popular HD videos including AVCHD Video (.mts, .m2ts), H.264/MPEG-4 AVC (.mp4), MPEG2 HD Video (.mpg; .mpeg), MPEG-4 TS HD Video (.ts), MPEG-2 TS HD Video (.ts), Quick Time HD Video (.mov), WMV HD Video (*.xwmv), Audio-Video Interleaved HD Video (.avi) etc.
[b]2. Convert video to various output formats and all PMPs[/b]
Popular formats are all supported, and M2TS Converter for Mac converts videos to iPod, iPhone, Apple TV, PSP, Xbox 360, Wii, BlackBerry, MP3/MP4 players like Archos, Creative Zen, iRiver, Pocket PC, PDA, etc.
[b]3. Provide Deinterlacing function[/b]
Using this M2TS Converter, it helps you to convert interlaced video to the progressive video, this function can optimize the video effect..
[b]4. Powerful editing function[/b]
M2TS Converter helps you diversify your video in the way of a wide variety of video editing functions such as crop video, trim movie and set the video Brightness, Contrast, Saturation.
[url=http://www.topsevenreviews.com/aiseesoft-ts-video-converter.html]TS File Converter[/url]
[url=http://www.topsevenreviews.com/]DVD Converter[/url]
[url=http://www.topsevenreviews.com/]Best DVD Ripper[/url]
Jul 11, 2010 | Televison & Video
Trouble with volume on certain channnels
If you get good audio on most and then low or very low audio on certain channels then call you cable company and have them inspect this problem. It is their business to get both good video and audio to you.
Sep 10, 2009 | Insignia Digital-to-Analog Converter for...
Archos TV Plus and Converter Box
The installation may be corrupt .Go to www.intel.com and again download & install the high definition audio driver from there
May 20, 2009 | Archos TV Plus, 80GB 80 GB Hard Drive
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
VCR HOOKUP PROBLEM
you will need to hook your signal to the converter box then into your vcr and then into your TV. Now if your vcr has signal out then you will not have any problems hooking your tv up to the vcr. You may have to use the audio out to get the right sound with your tv.
Feb 10, 2009 | Hitachi Televison & Video
Converter Box Problem
What type of antenna are you adjusting? If it is not a UHF then you will have to try another such as a Smart Antenna or one from Wal-Mart for digital TV.
Feb 05, 2009 | Televison & Video
Televison & Video Logo
1,432 people viewed this question
Top Televison & Video Experts
