Question about Dell Inspiron 1501 Notebook
Computer won't start up
I turn on my computer the screen comes on then says switching to power saving mode the screen shuts down and the hard drive seems to be trying to start it just keeps making noise like it is working but nothing happens and i can't get into the hard drive to check the problem I've tried to connect my laptop to the hard drive but still can't gain access to my hard drive
    Problem Solver:
  • 6 Answers
Hmm have you tried taking the bottom off and making sure nothing got hot and melted or ruined anything...???
Posted on Jan 09, 2009
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Keeps shutting down and takes several trys to start again only to shut down later
If the computer is overheating it will shut down to save the hardware from heat damage, the temp is pre set. It may get hot, due to air flow in a minute or and hour. What does the "screen comes up says problem " say? Check the fan and vents for dust and clean, improve air flow around bottom vents and side vents. Perhaps a Laptop Cooler? When the computer shuts down unepectedly, the computer see it as a crash and will load in that option screen. Run a 'Check Disk" on the OS drive buy opening computer in start menu, right click the drive with the OS (C), open properties, Tools, Check now, choose all options, follow instructions, reboot.
Nov 18, 2012 | Computers & Internet
Control button locked. when I turn ooff PC the sleep light will not turn off.
Typically, the computer is defaulted to stay turned off after an electrical outage. To start the computer from scratch again, hold the power button in for several seconds. If it powers off, wait a minute, then hold the button in again to start it. When the screen comes up that says it didn't shut down properly, choose Safe Mode without networking. It will look like it is hanging on several files, normal, let it go. The screen & icons will be large because it is in default VGA mode. Once it stops loading, go to the Start Button & choose Restart. Things will return to your chosen default settings and most things will work again providing you have an EMI/RFI Surge Protector power strip that everything was plugged into. I have had several fail after a power surge, they are supposed to. Some have insurance should you have electrical damage after a power surge that got beyond the strip. Ultimately, $15-$50 is cheaper than your PC &/or monitors damaged by not having one, they are designed to be the Sacrificial Lamb & be the cheap breaking point.
As an added note, people confuse Sleep Mode with Hibernate Mode. Sleep mode means anything you are working on gets suspended into your available memory while it goes into Power Saving mode. On a power loss, all will be lost, save regularly if you use this mode.
Hibernate uses a space on your hard drive to write the information. Power loss, nothing is lost and on waking up or powering back on, your data will still be where you left off, usually intact. To restore from either mode without electrical loss, hit the ESC key. Exceptions will occur if you use Hibernate mode but only have a power strip for your multiple plugs. A power surge can still damage your computer because it wasn't blocked by the EMI/RFI power strip.
How do you know which one you have ? If you only have an On/Off power switch, you have an unprotected power strip. If you have a button on the side of that switch, known as a Reset Switch, you have a protecting one. Even if the Reset Button doesn't restore the power strip, it gave it's blife to protect your computer equipment. Cheap insurance.
Good luck.
DellTech.
Sep 01, 2012 | Dell Computers & Internet
Dell Inspiron 545 wont come out of power save mode - when switch it on it tries to start up but then goes into power save mode this then continues switching between power save and starting up until i
Do a full reset. Press power button down until computer shuts down, this will take more than 5 seconds. After that you can perform clean boot.
Aug 18, 2012 | Dell Computers & Internet
I cant do a factory default
Read the product manual for how to restore factory default for your product.
Jul 09, 2012 | Lenovo Computers & Internet
HP had blue screen and said it would shut down. Problem is that it does turn off, so that it can be re-booted. Have tried to shut off PC, but continues to come on and not start.
Hold the power button in for 10 to 15 seconds for hard shut down if that doesn't work unplug power for about 5 minutes then plug power back in and see what happens
Jan 06, 2011 | HP Pavilion a1000n (PS567AA) PC Desktop
Format laptop lenovo y550
Note: Format would delete all of the data(like pictures, documents.) from the computer. Make sure, you back up all of your important data before formating the hard drive.
1. Insert operating system disk. 2. Shut down and restart the computer.As soon as, you restart the computer, start tapping 'Spacebar' key. Now, this would start loading from disk. 3.Hit F8 to accept the license agreement. 4.Hit enter 5. Enter Enter again and follow the on screen instruction and this would format your hard drive.
Note: once you format the hard drive, you would need to install drivers as well. Make sure you have the drivers and utilities disk as well.
Apr 15, 2010 | ASUS Computers & Internet
My acer computer will turn on but wont come out of hibination mode
Some laptops have issues with Windows XPs hibernation mode. To get the computer back up again you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Once you get the computer back running again you may want to disable hibernation if it seems like its going to keep happening. Go to Start, Settings Control Panel or Start, Control Panel and go to the Power Options icon. Change the hibernation section to never. You may want to try standby as an alternative. Standby saves all your running applications and documents into RAM while hibernate saves them to the hard drive. Hibernate uses less power from your battery, but it will take you considerably longer to get the computer back up. If you always plug the computer in then you may want to disable standby and hibernate since you really dint need them while plugged in.
Let me know if this works.
Aug 16, 2008 | Acer Computers & Internet
Dell Inspiron 1501 Notebook Logo
108 people viewed this question
Alun Cox
