Question about M-Audio Omni I/O and Delta 66 Sound Card
Can't record input.
I am trying to hook up my turntables to the omni and fro some reason every config I try doesn't work. Any ideas?
  • 661 Answers
Turntables are not always amplified and therefore they do not supply a suitable input signal, you may need to use an amp to get a suitable line out signal
Posted on Jul 26, 2007
I have a Yamaha RV-V450 receiver. Where can I hook up my turntable. I have tried many different options. I can hear very faintly the record playing but only after turning the volume up. I am having trouble...
Turntables generally do not have a strong enough signal to drive an amplifier. You can check on the back of your turntable and see if it has a switch to change from phono to line level. Most do not, but a few will.
If your turntable does not have this switch, you will need to purchase a phono amplifier to boost the signal to standard line level. You can get these on ebay for around $15.
You connect the turntable to the phono amp input and then connect the phono amp output to any of the inputs on the back of your receiver (aux, cd, etc).
NEW BOZAK Phono Preamp Pre Amp Record Player Vinyl LP Album Amplifier eBay
Dec 30, 2017 | Yamaha Audio Players & Recorders
Turntable problems
You need to use this turntable with a receiver with a phono input, as turntables need more amplification than say a DVD input. They also need the RIAA equalization to decode the record correctly. If your receiver does not have an input labeled PHONO, you can purchase a preamp that is designed specifically for this purchase. Any Google search will give you hundreds of places to purchase one; just search phono pre-amp. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 12, 2013 | Audio Players & Recorders
Purchased stanton T.52 Turntable. hooked it up to stereo but volume is very very low. cannot find line / phono switch if there is one on this model.
The only output from the turntable is the low-level signal from the cartridge. Most likely, the receiver you've hooked it to doesn't have a phono input. Many receivers today don't come with one, and if you connect the turntable to a line-level input you get either very low volume or none at all, depending on the cartridge. What you'll need is a turntable preamp to boost the output to line level so the receiver will work properly. Radio Shack still carries a preamp, available online and in some stores. You can also find preamps online (here's one at Amazon). With the preamp connected you can use any free input on the receiver.
Jun 05, 2011 | Stanton T52 Turntable
I have a garrard turntable and I'm trying to hook
Connect the turntable wires into the recievers phono input and you should be good to go
May 16, 2011 | Technics SA-EX110 Receiver
Numark Omni control-iMac Problems
Did you try this turn table on another PC? It is the best way to check for I never seen a NuMark act like yours. A secondary PC is always great to have if you constantly need this turntable
Mar 28, 2010 | Numark ttUSB Turntable
Phono plays lower in volume than cd and tuner. Sounds ok i guess but is about a quarter to one third lower in volume. Is this normal ? Can I plug phono into cd jacks to check if any better ?
Hello. As per the post before me, if you have a receiver with a Phono input(many receivers don't have one anymore) the output of a phono cartridge is around 30 millivolts, vs 300 millivolts for a CD(10 times the amount) or any other line level device. A Phono preamp, also has RIAA(recording engineering standards)Equalization that provides the proper equalization for a Phono cartridge. As per the other post, yes, it will sound very low, and unnatural sounding. If the input you are plugging the turntable input into, doesn't say Phono, you can purchase an inexpensive Phono preamp made just for this very issue. You can try Radio Shack, or find something of better quality on the Internet.
Regards,
Dave
Jan 11, 2010 | Pioneer VSX-453 Receiver
Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Mar 10, 2009 | Technics SL-1210 Turntable
I have Pioneer Amplifier with Phono Inputs. Also I have an Akai stereo Equalizer. I want to connect my Turntable to the pioneer amplifier through Akai stereo Equalizer to have a better sound quality. Is it...
hook the turntable "directly" up to the "phono" inputs. if it sounds normal this way, and not loud and distorted, then you have to plug the turntable up that way, directly to the reciever's phono input.
you can hook the eq up through the "tape in/out" jacks.
take the tape record out jacks, and hook them up to the input of the eq, and take the tape play input jacks and hook them up to the output of the eq. then, to use toe eq, select whatever input you want eq'ed, while also selecting "tape monitor"
Mar 07, 2009 | Kenwood Audio Players & Recorders
No Amplified Sound Coming Out...
http://www.mcmelectronics.com/product/MCM-CUSTOM-AUDIO-40-630-/40-630
Turntables need a preamp due to their very low output compared to modern components. The link above is the one I use. Try connecting to your receiver's phono input if you have one, also try the aux input. If neither of those work, obtain a preamp and you will soon be scratching with the best of them.
Jan 02, 2009 | Audio Players & Recorders
How to hook up my turntable to my RCA home entertainment system
http://www.htfr.com/more-info/?catno=MR155277.
please buy the item above -----connect your turntable to input and take the output and connect it in line in in receiver.
Aug 11, 2008 | Audio Players & Recorders
M-Audio Omni I/O and Delta 66 Sound Card Logo
85 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
