Question about Kenmore 24032\24036 Top Load Washer
Clothes are still too wet at the end of wash and rinse cycle
Kenmore 80 series
  • djmcw Jan 09, 2009
    I sympathize with you. I have just set an appt for Sears to come out for the fourth TIME! They cannot figure out this problem evidently. They will order a bunch of parts and install them and say it is fixed - and then it is not. At the end of the spin cycle there is a SOGGY bunch of clothes and I have to turn it to spin again to get the water all wrung out.
Did anyone check the outlet tube to make sure it is clear of any debris and not tangled? I had this problem on another washer and it ended up being a crimped hose.
Posted on Jan 10, 2009
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Rinse cycle doesn't work
Your cold water valve is clogged. Most likely needs to be replaced or at least cleaned.
www.oc-repair.com
Feb 09, 2010 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer clothes are still dripping wet
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 16, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine 80 series
hello Lady you will need to give us some more information. Does it stop at the rinse cycle?
Jan 19, 2009 | Kenmore 23812 Top Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Lent on clothes
Not familiar with this model but it sounds like too little water is being used (small, medium, large load) or a rinse cycle is being skipped.
With enough water and normal rinse cycles, the lint should be suspended and pumped down the drain. If this is happening with every load, then it isn't working properly.
Dec 15, 2008 | Kenmore 24032\24036 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
65 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
