Question about Black & Decker Black Decker Dualtemp Soldering Craft Iron CI500S
What kind of soder do i need
I Have the black and decker soldering iron. it says it goes from 500/900F so i picked up some aluminum soldering rods workable at 700-750F But nothing happens. Iron is on highest setting and is hot. Any suggestions? I'm trying to repair a xbox 360 Head set, by the way.
  • 104 Answers
Sorry, this iron will not do the job. Yes the temp is higher than the solder, but once you touch it to the work, the heat is gone in Aluminim as it conducts heat at a very high rate. You need more wattage AND the upper heat level. A flame powered tool might be more appropriate. Contact Weller on their web site for recomendation
Good Luck
Posted on Feb 09, 2009
What is this silver piece in my microwave? what is the result of using the microwave without this piece?
"Iron with aluminum soleplate quickly smoothes out wrinkles"
product overview...
- Combining a simple, classic design with an array of modern conveniences, this powerful iron quickly and easily smoothes out wrinkles. The unit's fabric-select dial and convenient fabric guide make it easy to choose the right amount of heat needed for the job, while its aluminum soleplate creates crisp creases and comes with a pointed tip that works well for getting into pleats, between buttons, and along seams. Other highlights include an "on" indicator light, a thumb-activated steam-surge button, an anti-drip system that prevents water spotting at low temperatures, a pivoting cord, and a stable heel rest. For enhanced safety and peace of mind, the iron will shut off automatically after 30 seconds of inactivity if left on its soleplate or tipped over on its side; if left vertically on its heel rest, it will shut off after 8 minutes.
  • Iron with aluminum soleplate quickly smoothes out wrinkles
  • Fabric-select dial and convenient fabric guide
  • Thumb-activated steam-surge button; anti-drip system prevents spotting
  • Dry-iron option; pivoting cord; stable heel rest; 3-way auto safety shut-off
  • Full-range fabric/temperature settings
  • Power indicator light
  • Button groove
  • Pivoting cord
  • 2-year limited warranty
  • Note: Product may vary by store
  • Home Depot Protection Plan:.
Nov 14, 2015 | Black and Decker USA Black & Decker F67e...
How to solder Aluminium and Copper
To solder aluminum and a copper wire? You do not need any special tools or equipment - just use the standard soldering iron, traditional SnPb solder, grease (lubricant) and sandpaper.
Apply grease to the soldered aluminum surface, regrind this "greasy" surface with sandpaper so excite the surface layer of aluminum oxide (Al2O3). Grease prevent air going to the purified aluminum and its rapid re-oxidation to the Al2O3 and lets to adhere molten SnPb solder to aluminum. Once the aluminum surface is covered with a layer of SnPb solder ("tinned"), clean it with a degreasing agent out of grease and may be normal solder to another "solder-tinned" material - for example, a copper wire.
on Feb 12, 2015 | Welding Tools
Need to register new Iron
sorry but think you need to go to their website not fixya
May 20, 2015 | Applica Black & Decker The Classic F67E -...
My 17 yr old sony triniton goes on after about 5 or so min. the picture is great then the screen goes black (audio fine) for about 4 seconds then the pic is back for about five min then the same thing...
U have a soldering iron,a roll of solder and can do a basic soldering work too?Yes,take the tv aparts.Tv have a cold sodering video board,that the board where it is connected to the CRT-(tv tube).Resoldering the sock pins of the video board that connected to the tv CRT-(tv tube).The tv picture,will be stable and work again as soldering work it is done and the tv have to a good connections between the tv video board and connected to the CRT-(tv tube) again.
May 24, 2011 | Sony Televison & Video
Bring the iron to a Hardware store, ask for a set of tools right for the type of screws (maybe Torx, Security Torx, tri-wing, bristol and others).
Once you can open the iron and access to the cord you may change the power cord. it is easy.
Power goes on & off because the power cord is broken. This failure is very common on irons.
Good luck
Apr 19, 2011 | Black & Decker Steam Xpress AS250 Iron...
Good morning, My iron black & decker d2020 overheats, cools down and then goes through the process all over again.
The Thermostat has gone faulty. This can be replaced if you can get the parts. You need to contact, B&D indicate your problem, and exact, make and model, and inquire as to where you can purchase the parts, or if you do not wish to do it yourself, where to send it for repair.
Apr 19, 2010 | Black & Decker D2020 Iron
Where can I obtain a users manual for the Black & Decker AS675 iron?
Please visit or call Black & Decker customer service at 800-231-9786 for the manual you need,
Please post a comment if you need additional assistance.
Jul 12, 2009 | Black & Decker AS675 Iron
Tips are corroding & disappearing
That is normal for a soldering gun especially if you are using acid core solder. I do a lot of soldering with rosin core & have to change the tip about every 6-8 months. Just get a couple of new tips. Rick
Mar 06, 2009 | Black & Decker Black Decker Dualtemp...
Soldering iron problem
Solder contains lead which is a poisonous metal. Wash your hands after woking with it.
Aug 27, 2008 | Black & Decker Black Decker Dualtemp...
Black & Decker SteamXpress 620
Check the cord...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
Jun 11, 2008 | Black & Decker Steam Xpress AS250 Iron...
Black & Decker Black Decker Dualtemp Soldering Craft Iron CI500S Logo
172 people viewed this question
Top Black & Decker Welding Tools Experts
Bill Boyd
Are you a Black & Decker Welding Tool Expert? Answer questions, earn points and help others
