My Bosch 2005 Integra dishwasher won't latch. It hits in the middle and the door teeters back and forth because it's hitting the latch. It ran the first time i turned it on with water and all no problems no leaks, could even open the door and it would still keep running. Almost like the dishwasher was reading that it was closed. Tried to run it again and the timer turns on but it doesn't run now almost like it reset but still won't close so now it won't run. I am wondering if it's a sensor or if it's the latch. My guess is the latch. I have ordered the part but wondering if there is something else that I should check.
Comments:
Jan 09, 2009
- Thanks, I just wasn't sure if that was common or not. now I hope I can change it out ok. It looks tricky to get out.
No you did good in ordering a latch ,that is a common issue i find with the bosch d/w, for no apparent reason the latch locks itself with the door open. Look at the door where the male part of the latch goes into the door, you will see that is locked. if you take it apart and manually unlock the latch u stand to break it. Again you did good on ordering the latch.
Was this helpful?
Yes
No
Popular Solutions for Bosch 36 Inch Pyramid Chimney
bosch dishwasher (approx. 5 years old), won't close - is it a problem with the latch? What do i do,...
(More)
bosch dishwasher (approx. 5 years old), won't close - is it a problem with the latch? What do i do, i am not a handy guy..help!
do i need to check the drain hose to see if it is plugged up,replace the pump. is their other ways...
(More)
do i need to check the drain hose to see if it is plugged up,replace the pump. is their other ways to diagnose the problem.
i have a bosch dishwasher SGS69L02GB/17.The door handle is broken,got the spare handle but cannot...
(More)
i have a bosch dishwasher SGS69L02GB/17.The door handle is broken,got the spare handle but cannot fix to the machine. Tried taking 4 screws from the back but the old handle refuses to budge. please help.
