Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jan 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Control panel flashing F02
I live in alaska- it's very cold and my washer got cold and it froze up.
i have it thawed out but the control panel is now flashing this code F02
what should i do next?
onthethejob1
Level 3:
  • Master 640 Answers
  • Posted on Jan 09, 2009
onthethejob1
Master
Level 3:
Answers
640
Questions
Helped
208614
Points
1483
The water in your drain pump is still forzen...its taking to long to drain...ckeck drain hoses too...onthejob
Thaw a 22 lb frozen turkey in three days
Unless you live in a tent in Alaska a bird that size should pretty well thaw out in 3 days if left in a warmish invironment. Try a warm oven, lowest temp possible if still unfrozen after 3 days.
1helpful
2answers
Washer won't complete cycle. F02 flashing
F02 = long drain
try this
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filterfor foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
It doesn't finish the cycle and stops and flashes F02
Possible that the drain cycle is not active and so the program trips off. Check the drain for clogging , check the power to the drain from the controller during the cycle, if there is no power the program controller is faulty.
What kind of coolant do i use for a 2004 Kia Ria, 50/50 OR 35/65? I live in Alaska. Need an answer asap.
when you live in really cold climates it is important to run more antifreeze so the water does not freeze and blow out a freeze plug. i live in california where its always warm so i run a 50/50. i would imagine alaska gets pretty cold so i would probably run more antifreeze
1helpful
2answers
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
What does it mean when a duet front loader washing machine flashes F02?
f02 mean that the drain time is to long check the drain pump filter that is behind the lower front panel
2helpful
Hi I have a Hotpoint WDD960 WASHER/DRIER it froze up in the cold spell, and is now flashing f:09. I have unplugged it overnight, but still keeps flashing f:09. Thanks Keith.
F 09 is an incompatible eeprom. It sounds like the frozen episode introduced moisture on to your control board. You can try opeing the control panel area and use a hair dryer to possibly dry off the moisture. The damage may already have been done but you just might luck out. Good Luck Keith
3helpful
Fault problem
F02= LONG DRAIN
off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
or kinked.
4. Check the drain pump filter for foreign objects.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
