Question about Kenmore Elite 45986 Front Load Washer
Code F02 in middle of cycle, wont finnish cycle,
If push drain and spin comesup 11 minutes left. Then nothing . Problems with heavy loads
  • 640 Answers
Unit is taking to long to drain brad,,check your drain hose not blocked of kinked,,,clean your pump filter,,check your pump,,onthejob
Posted on Jan 09, 2009
Keeps showing code f 02 and wont completely empty water it never finishes spin cycle?
F02 error means if the drain time has exceeded more than 8 minutes. After four minutes suds will be displayed on the screen and again after 4 minutes the F02 error code appears.
Check the drain line for any clogs or blocks which hinder the draining procedure..Use of more detergent can even cause this condition..
Be sure you are using only 2 tablespoons of HE soap and not more than that. Check your drain filter also and replace them if needed.
Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer. The drain/filter/pump is right in front
Jan 18, 2011 | Kenmore Elite 45986 Front Load Washer
Washer has an F02 code in the middle of the cycle, which has stopped, and I don't have the manual.
F02 = Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and
"F/02" is flashed.
The most common cause is a clogged drain filter. Remove your lower front panel. The filter is located in the discharge hose before the pump (often white in color).
Remove the filter and clean out any debris (socks, nails, coins etc..)
If this is not the problem then here is directly fronm the manual.
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the
pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Dec 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
It stops in the middle of a cycle and gives an F02 problem.
F02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Aug 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Got code F02 after cleaning all drain system and replacing pump.
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%
Jun 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Model GHW9150PW0 shows code F02. The washer did nor complete the spin cycle and water was left in the tub. How do I get access to the pump. How do I remove the panels. Thank you
Potential Causes
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F 02 code is flashing
F02 indicates "Long Drain"
Potential Causes
Jan 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite H3 control buttons - some work some don't
The diagnostic function will not help you if your user interface board (UIB) is acting up because to put into diagnostic you have to select drain spin, then the no spin option, and hit the prewash button 4 times.
It sounds like your UIB is the problem.
Jan 01, 2009 | Kenmore 42822 Front Load Washer
Washer code
the drain sump area is clogged axcess through front panel. F02 is telling you its taking too long to drain the water pretty soon it wont drain at all.
Sep 29, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
145 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
