Question about Toshiba Wireless Mouse PA3205U-1ETC
Forgot how to turn on wireless mouse
I forgot how to turn on my wireless mouse. it is a toshiba model N745. i dont remember whether to plug the flash drive in first or how many times to press the flash drive button.
  • dr_elizabeth Jan 09, 2009
    batteries are good. but my question is how many times or for how long do i hold the usb button for? (there is an actual button on the flash drive)
  • 741 Answers
Plug in the USB. Look under the mouse for the select button to the "on" position. Ensure batteries are good.
Please rate this solution.
Posted on Jan 09, 2009
  • Randall  Trahan
    Randall Trahan Jan 11, 2009
    If you are still having problems please reply with a step by step process you are following. Not aware nor have I ever experienced a situation with a wireless mouse that needed to "press the flash drive button". Thanks
Hi there, I've got a Toshiba mouse, model number PA3706-1ET1. It's a wireless mouse and each time when I turn on the computer the mouse stops working. So, after a couple of times removing that small...
first check the batteries inside the mouse they might be low, if that didn't work then try that muse on a different pc to make sure whether it is form the wireless mouse or from your workstation (windows problem or driver corruption).
Apr 18, 2010 | Toshiba C99704 Mouse
Acer N745 stuck
The top should have a button to release the receiver (on the lower half). If pushing this does not release it, you can disassemble the mouse fairly easily (you do not even have to break the warranty seal). Removing the cover to install batteries, you should see two screws. Remove them. on the bottom, underneath the upper-left corner of the "Acer" sticker is the third screw. Once disassembled, if you look at the top, you should see two white "tabs" that when depressed should release the receiver. If this still does not release it, you can then remove the bottom half of the mouse and then lift (since it's inverted now) the tabs. Hope this helps!
Aug 27, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Connection procedure for Toshiba N745 mouse needed.
I don't know if this is the same as my mouse. However I have a satellite1955-S803 with wireless detachable keyboard and full sized optical wireless mouse. The original owner said it came with the laptop.
First I tried very hard to get the keyboard working. After a frustrating day of calling Toshiba, I noticed the "detachable" latches. I removed the keyboard to find a battery compartment. 4 days go by with me calling Toshiba trying to get a replacement. Finally found a battery at batteries plus that does work. about half the mAhr of the original but hey it works.
Now to the mouse. Replaced the AA's batteries but couldn't tie the mouse to the computer. I run linux so no M$ driver would help. Finally found a PDF of the manual and it says "if the mouse has trouble activating, press the wireless mouse button on the laptop."
That button is on the front left edge of the laptop (where the "Intel inside", "XP loaded", and "nvidia" stickers are located ) just to the left of the front silver "mode" button. Under the mouse press the connect button. (round near the optic laser but un-labled) then press the wireless mouse button on the computer and there you go. It just connects and works.
2 weeks I looked for this and it was just that simple.
Aug 26, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Put USB receiver in mouse and can't get it out.
Push the back of the middle top center strip down and it should pop out!
Aug 02, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
How do i change the battery in my toshiba N745
if u now on line i can show u .aanjana03@yahoo.com. ther is a two part of mouse . back side of mouse cover pressing we can open mouse . there is a plastick lock cleap on mouse.(nepal)
Jul 11, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
How do i open case to change batery? N745 mouse?
weare looking two part on the above of mouse. one side of scrool and other is only cap add printed( as logetecc). we slould press and pull againast scrool side there is amsall plastick lom.20303231.jpg
Jun 29, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Toshiba N745 USB Adapter Problem
there is a button just behind the scroll wheel, push it and the usb unlock and come out.
May 31, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
There should be an eject button on the lower portion of the mouse. Press that button and the receiver can be removed.
Hope this helps...please share your experience by voting on this solution.
Mar 28, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Can't open toshiba wireless mouse to change batteries model n745
if u look seriously. you can get above side is two part and below side is one part, press above scroll ,'againast side of the cover and pull (there is a plastick lock.)
Toshiba wireless mouse cursor not moving!
Try replacing the batteries or if it has rechargeable batteries, try removing and replacing them. Also clean the red lens on the bottom of the mouse with a cotton swab. Good luck!
Mar 14, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Toshiba Wireless Mouse PA3205U-1ETC Logo
1,874 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
