Question about Viking VGSC366-6B Gas Kitchen Range
All igniters on my stove top won't turn off - keep beeping
I was cleaning my Viking stove top and all of the igniters are beeping and won't turn off. When I light one of the burners they will go off but when I turn it off, they all come back on again. Help!
  • 59 Answers
Sounds like you might have a grounding or polarity issue with the power supply.
Posted on Mar 09, 2009
Have a 4 burners gas stove top 2 burner gas igniters just clicking an wont come on
did you spill something on the 2 that will not light . that is the usual cause .some can be taken apart and cleaned others not so easy .try lighting with a match .
Dec 18, 2015 | Viking Cooktops
Gas oven won't turn on, stove top works fine.
check if the igniter is getting a 110 volt power if yes replace the igniter
Sep 05, 2011 | Kitchen Ranges
My Viking oven will not lite, the igniter glows, but it will not lite. I have to turn on the 4 stove top burners and then it will lite. Also, when the oven reaches temperature and the therastat shuts it...
That sounds like you have too high of gas pressure which keeps the oven gas valve from opening...turning on the burners lowers the gas pressure enough to allow the gas valve to open. this is a saftey feature on many gas valves.
To stop that you will need to install a gas pressure regulator which will hold back the gas pressure so the valve can open.
Here is a tip that I wrote about regulators and them failing on the low side, but it will give you and idea what I am talking about and what you need to install in the line to your range.
http://www.fixya.com/support/r5849793-propane_lp_or_natural_gas_regulator
heatman101
Apr 22, 2011 | Viking 27" Professional Select Built-in...
Viking gas stove top ignitors sparking incorrectly
all ignitors spark at the same time no matter which burner is turned on. If you are having trouble with one burner not lighting try cleaning around the ignitor with a small screw driver so the spark has a good path to ground.
Mar 19, 2010 | Viking Kitchen Ranges
Viking cooktop gas unit ignition clicks on all burners when I use
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
VIKING STOVE DOOR IS LOCKED AND WILL NOT OPEN , STOVE WAS IN A SELF CLEANING MODE AND DOOR WON'T OPEN AFTER CYCLE COMPLETE
unplug or turn off breaker to stove for 10 minutes...then try to gently open.....the oven has to be completely cool before it will unlock....when cleaning is done release lock before turning cleaning off
Nov 28, 2009 | Viking VGSC306-4B Gas Kitchen Range
Igniter keeps clicking, intermittent
There should be a little switch that slips over the stem of each burner control. Very common.
Jun 02, 2009 | Viking VDSC307-4B Dual Fuel (Electric and...
Ignitor on stove top keeps engaging when all burners are off.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
ioy
Mar 21, 2009 | Viking VGIC485-6G Gas Kitchen Range
Viking Stove electronic ignition keeps sparking
Why suddenly my ignition are not spark and did not light the flame on two burners?
Dec 26, 2008 | Kitchen Ranges
Stove top [gas] JENNAIR
Try carefully cleaning around the ignitors. Also clean hole in burners. Clean the holes closest to ignitors. This can be caused by a crack in ignitor, this requires replacement.
Nov 05, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Viking VGSC366-6B Gas Kitchen Range Logo
865 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
