Question about Magic Chef CMV1000B Microwave Oven
Vent fan high comes on automatically with cooking
On my brand new magic chef range top microwave, the vent blows on high with any cooking. Is this an error in installation? is there a bypass?
  • 2 more comments
  • ghwithkids Jan 09, 2009
    It is a Magic Chef MC0160UW. I'm not sure if installation was correct ... I looked at the guide after my friend put it in to see if there were any clues. The instructions gave some options to install ... we didn't remove anything from the back to vent out horizontally, and vertically isn't really an option either. suggestions?
  • toc6 Jan 14, 2009
    when the micro is turned on the fan makes a flepping sound like its hitting someting, have taken the control panel cover off and ran unit again the fan is quiet any suggestions.
  • MWWSF Feb 03, 2009
    I just had a Magic Chef installed today, and the fan is so high that you can hardly hear yourself think. And this is just when it's heating, not when the fan has been turned on. Does anyone know how to make it stop?
  • William Miller
    William Miller May 11, 2010
    What is your model number?
    Does the installation match the installation instructions?
  • Magic Chef Master
  • 9,098 Answers
Right, that would be MCO10UW and the owner's manual is here.
The owner's manual does say this, of course,
"To prevent overheating from taking place, the exhaust
fan is designed to automatically turn on at a low speed if
excessive temperatures occur. Should this happen, the
fan cannot be manually turned off, but it will
automatically turn off when the internal parts have
cooled. The fan may stay on for up to an hour after the
range and microwave oven controls have been turned
off."
That;'s standard on microwaves.
But these models do have a separate internal cooling fan (which should run any time you microwave) plus the hood vent exhaust fan, which should only run when you select it, or if there is an excessive stovetop or under-hood temperature.
So if it comes on whenever you microwave, that is incorrect.
When that happens, it's usually a defective vent thermal switch (a.k.a. hood TCO).
But since it's brand new, I would certainly contact Magic Chef about this. If it's in need of repair, they will fix it free, assuming the oven wasn't physically damaged.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Posted on Jan 10, 2009
Magic Chef over-the-range microwave oven doesn't cook. Clock, inside lights and turntable are fine
If it lights up, the fuse is fine. On all of the recent Magic Chef's I've repaired, the magnetron has been the cause of the problem you described. Another possible common culprit is the high voltage rectifier.
Aug 04, 2017 | Magic Chef Microwave Ovens
Back panel of microwave gets hot while in use
would you not also get hot when in use . if you were heating food to be totally cooked .that is why they have a fan in them
Jun 19, 2016 | Magic Chef Microwave Ovens
MCO153UWT shutting down after 3.5 minutes
it is an internal fan that is the problems, if this is a counter top MW just replace it. if Over The Range (OTR) and under warranty call for service. if out of warranty replace.
Jan 23, 2012 | Magic Chef Microwave Ovens
Microwave won't work, I was cooking on the stove and the fan came on and then everything went out on the microwave suddenly
There is a thermostat which detects when the temperature from the cooktop is too high, and it makes the hood vent exhaust fan come on to cool it to protect the controller.
That's I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Assuming the wall outlet is good, the first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it's still dead, another thermostat may be blown,or the fuse.
You can find links to helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Usually the fuse and magnetron thermostat will be accessible for testing behind the controller.
If those are good, then it may be a bad oven cavity thermostat, and checking that will require you to remove the oven from the wall and take off the outer cover.
Behind the controls in many microwaves is a technical sheet, which helps in locating and testing components.
Nov 02, 2011 | Magic Chef MCO160UQ Microwave Oven
My cooling fan will not engage when I turn on the microwave. I am manually turning on the fan at High to make sure the temperature doesn't overheat the appliance. Sometimes after I'm done cooking if I...
There are typically 2 fans in these units. The fan that cools the magnetron and then the vent fan that intakes from the top of your stove then vents the air out or away from the unit. Are the lights that shine on the top of the stove working?? Sometimes if a bulb blows violently it can blow a trace off of the back of the main circuit board and that trace may also supply power to the fan
Oct 21, 2017 | Magic Chef CMV1000B Microwave Oven
My fan kicked on by itself and won't shut off
The over the range microwave hood has a heat sensor in it. If it senses hot temperatures from cooking below it will turn the fan on. The fan will turn off once it cools down, this is to protect the microwave controls from damage.
May 08, 2010 | Magic Chef CMV1100 Microwave Oven
Shuts down for 5 minutes
I have the same problem with my new magic cheff over the stove microwave oven. I call magic chef and they gave me the 800 number for the service center (1-800-775-0202). When I described the problem they told me to just put a plate under the popper and this wouldn't happen anymore. I haven't tried it yet but here's hoping.
Jan 15, 2009 | Magic Chef MCD1311ST Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Magic Chef CMV1000B Microwave Oven Logo
1,385 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
