Olympus DS-4000 Digital Voice Recorder Logo
Posted on Jan 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Intermittent ds4000 detection
When unit plugs into machine, player pro software only open 50% of the time.
Tried removing the adobe photo application, no improvement.
Randy Morton
Level 2:
Sergeant:
Champion:
  • Olympus Expert 479 Answers
  • Posted on Feb 17, 2009
Randy Morton
Olympus Expert
Level 2:
Sergeant:
Champion:
Answers
479
Questions
0
Helped
118978
Points
522
When unplugging the device from the computer, make sure to safely remove hardware icon
Adobe acrobat x pro configuration error 16
you need to uninstall and re-install before install download it again from main site again it will work.
Adobe Acrobat 7.0 Pro Error
Adobe has disabled the activation server for CS2 products, including Acrobat 7, because of a technical issue. These products were released more than seven years ago, do not run on many modern operating systems, and are no longer supported.
Download the New Copy of Acrobat and activate it with the new serial Number .
Click this Link CS2 downloads
1helpful
4answers
How to remove date and time stamp from photos
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There is a special tool that can easily remove date stamps, watermarks and other unwanted objects from your digital photos: http://www.softorbits.com/photo-stamp-remover/
2helpful
Can't scan for viruses: sony WALKMAN NWZ-B133F.
Avg scans a portable drive every time you access it . If you still feel that your player is infected , try Avast or the lesser known Removeit Pro (antivirus softwares )
2answers
The DS-4000 digital voice recorder is a product that is sold exclusively through authorized retailers.
Since this product is designed for professionals and is somewhat complex, the retailer will provide you with personalized sales and support please refer to your dealer for assistance.
1helpful
2answers
I have the following message and I understand the problem may be with Adobe Photoshop Elements 6 The appplication has failed to start because connAPI.DLL was not found. Re-install may fix the problem
Hi there.
Do one of the following solutions: Solution 1: Remove the NOKIAManager.mox file.
  1. Exit Photoshop Elements.
  2. Open the C:\Program Files\Adobe\Photoshop Elements 6.0\moxplugins folder.
  3. Move the NOKIAManager.mox file to the Recycle Bin, or another location such as your desktop.
  4. Restart your computer.
Note: The NOKIAManager.mox plug-in file is required for Adobe Photo Downloader to download photos from a Nokia mobile phone. If you use a Nokia mobile phone, use Solution 2. If you later decide to use a Nokia mobile phone, either move the NOKIAManager.mox file back to the original location or reinstall Photoshop Elements.
Solution 2: Install or reinstall the Nokia PC Suite software.
Note: Only use this solution if you connect a Nokia mobile phone to your computer.
In order to communicate with a Nokia mobile phone, your computer must have the Nokia PC Suite software installed. Install the software to allow Adobe Photo Downloader to communicate with the phone and download photos from it. If you have previously installed Nokia PC Suite but are still getting this error message, uninstall and reinstall the software or upgrade to a newer version. For more information about Nokia PC Suite, contact Nokia or visit the Nokia web site.
Solution 3: Disable Adobe Photo Downloader.
  1. Open the Organizer in Photoshop Elements.
  2. Choose Edit > Preferences > Camera or Card Reader.
  3. Disable the Auto Launch Adobe Photo Downloader On Device Connect option.
  4. Click OK.
Note: This solution will prevent Adobe Photo Downloader from starting when Windows starts, and it will not appear automatically when you plug in a camera, card reader, flash memory drive, or other memory device. When you plug in one of these devices, and in order to download photos into the Organizer, you will need to start Photoshop Elements and choose File > Get Photos or Videos > From Camera or Card Reader.
Good luck and thanks for using FixYa!!
I can't figure out how to get adobe premier pro 7 to capture!
FIRST INSTALL ANY FIRE WIRE CAPTURING CARD & THEN CONFIRM THAT IT IS PROPERLY INSTALLED & HARDWARE IS DETECTED. AFTERWARDS WHEN U WILL ATTACH UR HANDYCAM WITH YOUR CAPTURING CARD YOUR CAMCORDER WILL BE DETECTED AUTOMATICALLY & THE WINDOW WILL OPEN & WILL ASK YOU THROUGH WHICH SOFTWARE YOU WANT TO CAPTURE THEN SELECT ADOBE PREMIERE THEN OPEN ADOBE PREMIERE GO TO FILE MENU & THEN SELECT CAPTURE THEN U CAN PLAY , REWIND OR FORWARD TOTAL FULL CONTROLL OF CAMCORDER WITH SOFTWARE ,TO CAPTURE CLICK RED BUTTON,IT WILL START UR CAPTURING,GIVE THE FILE NAME & DESTINATION WHERE U WANT TO SAVE THE FILE THEN START CAPTURING.
Help! Devices show as working, but "not detected" when opened
You could try to go into the registry and remove the usb enumeration folder "USB" .HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USB\ change permissions for it to be able to remove it. When you restart your computer all usb devices will be recognized and installed again. Let me know if this helps or not.
5answers
How to download adobe photoshop cs3 trail version
The 'trial' version of CS3 is no longer available for download from Adobe. The new version (CS4) is available: http://www.adobe.com/downloads/
I would suggest downloading Photoshop CS4, and trying it first, before spending time downloading the other applications. If Photoshop CS4 runs on your computer, the others probably will. Premiere Pro is the biggest resource hog, but will run fine on a dedicated graphics computer.
Click <HERE> for Adobe Photoshop CS4 system requirements.
Click <HERE> for Adobe Premiere Pro CS4 system requirements.
1helpful
Starts to open, then fails and closes
You need to delete the PS Preferences file (Adobe Photoshop 6 Prefs). It will be re-created when you restart Photoshop. # Windows 2000: Documents and Settings\\Application Data\Adobe\Photoshop\6.0\Adobe Photoshop 6 Settings.
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
