Question about IBM PC 300GL PC Desktop
300gl i have a 300gl it was give to me this friday by my brother i bought a monitor for it the moniter worked fine whent i bought it the problem is that when i connect the cpu to the moniter the cpu turns on then it makes this beeping sound but there is no image on the moniter even when i connected it all of it right can anyone help i am desperate i was hoping to use it all day but now my plans are over.
    Problem Solver:
  • 18 Answers
Try to remove your Display Card & install it back & if problem remain same do the same thing with memory module. Best of luck
Posted on Jun 03, 2007
  • 883 Answers
Start system then hit the F8 key and then select "Safe Mode"...if you can successfully get to safe mode, then there is a problem with the screen resolution being too large (video memory or monitor limits)...then restart in standard mode..any change?
When I hook up my moniter it does not work like other moniters.
ok sounds like you have a broken pin on your cable if you look in the end of the cable plug the part thet goes into the box but also check both ends if they are there
failing that take monitor to roof and heave ho away it goes
Jul 25, 2009 | Compaq P 1220 22" CRT Monitor
New moniter too dim.
Good morning! Please review the operations manual of the unit, taking note of set-up settings value requirements. best regards.
Mar 20, 2009 | Samsung SyncMaster 920NW Monitor
300gl
Who ever told you to remove the CMOS battery was wrong, I feel sorry for this instance, do you know of the specifications of the board (processor, bus speed, memory speed/type ((DDR DDR2 etc...))?
Are there any capacitors popped, cylindicular looking objects usually black or diff. color on sides and silver on top, if so, white gunk will be on the outside.
Feb 23, 2009 | IBM Computers & Internet
I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Oct 12, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor goes blank less than a second after turning on.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
Flatscreen didn't have a CD
I bought this monitor brand new and as I recall there was no software in the box.
Aug 03, 2008 | Balance CM2015 15" LCD Monitor
Screen flashes when using dvi input
make sure the cables are tight if they are i would look at replacing the video card.
Feb 06, 2008 | ViewSonic VA2012WB Monitor
Samsung SyncMaster 510N
its time for u poeple to buy a new moniter .....or get it repaired by a prof tecnician.....the electrons which bambard on the picture tube at a point of time they become weak...n they loose there capacity......so the moniter starts dim and after wards when the moniter heats up it get fine !!!!!!!!!!!!!!!
Oct 11, 2007 | Samsung 510N 15" Flat Panel LCD Monitor
IBM PC 300GL PC Desktop Logo
85 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
