Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ge refrigerator gtsz01cncww
Bottom part of fridge dosent seem to be staying cold and i have to keep turning on compressor by turn the dail in the the roof of the refrgerator part it runs for a day or so then cuts off and i have to turn dail on the roof of refrigerator again is this a part issue freon or plug up in back part of fridge
  • 700 Answers
Sounds like a plugged up condenser coil that is underneith the unit. take a shop vac and a long brush and clean it throughly.
Posted on Jan 21, 2009
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
Ge profile Ps27sgra refrigerator and freezef are
Hi, this problem is going to be with the running thermostat2.gif (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge2.gif to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Compressor not comming on somtimes / freezer staying cool not cold / fridge cold
Turn the termostat to high, check the following morning. If unit is not cooling you need to replace the compressor. However, before replacing compressor make sure all the fans are working.
Sep 10, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
My GE Compact Fridge doesn't start up, even though I left it standing upright overnight and turned the temperature dail clockwise. Yes, it's plugged in. :)
Ok so I will assume from your post that you turned the dial completly to the coldest setting and that the compressor does not come on (nothing comes on, no fans no compressor). Did you just plug it in and attempted to start it ? There is usually a delay in starting your compressor, it should come on within 10-15 minutes - if not, try turning the dial back to off and then turn it back towards the coldest - do you hear any "clicking" where the dial is at (thermostat) ? If it does not start you may have a compressor relay problem or control board problem - But for your compact refrigerator I would say more likely a bad compressor or relay / capacitor, etc.
Sep 05, 2009 | GE Refrigerators
Freezer works fridg dosent stay cold
When plugging it back in, check to see if you can feel air circulation (from vents in the top-rear) on the refrigeration side.
Check again after the fridge starts to warm.
There is a fan which is supposed to distribute the cooled air from the freezer to the fridge; this may be failing after the fan has warmed from operation. The bearings in these is primitive and can get sticky impeding the fan's rotation. Replacement of that fan is not covered by the (longer) compressor warranty.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Fridge not staying cold
did you let the fridge stay in it's new place for 24 hours up right before turning it on?
Try turning it off for at least 24 hours and start it back up again.
If you moved it on its side the compressor oil flows into the lines and must beable to drain back down before using it.
If not you'll seeze the compressor.
not good.
Jun 25, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
