Question about Vizio L15 Television
Code for digital remote control on Visio L15
We had to switch to digital with our cable company and now I need 2 remotes to work the TV because the codes the installer had for Visio TV's didn't work. What is the right code?
Go here and click on the question about remote codes (they give several three, four, and five digit codes): http://www.vizio.com/FAQ.aspx#
Posted on May 21, 2009
I need instructions and codes for a Philmore PM-RC26 iniversal remote.
Check the slot in TV where the HDMI cable is inserted. On your TV remote control (not Philmore) there will be a Source button or Input button. Press it & on your TV screen select HDMI 1 or HDMI 2. Now take the other remote control i.e. Philmore Universal remote in your hand. Press & release the S (set) button. Immediately enter the code. You have to be extremely fast in doing this.
Following are few codes which you can try:
Check the Visio TV manual for the Brand name, Model no & TV code if any. Then contact your TV manufacturer or retailer for the TV code to enter & synchronize with your new Philmore Remote Control.
Nov 13, 2016 | Televison & Video
How do I get my Sony universal remote to work with my Visio tv!
On your Visio TV remote control there will be a Source button or Input button. Press it & on your TV screen select HDMI 1 or HDMI 2. See the TV to see how the HDMI cable is connected from TV to Set Top Box. Now take the other remote control i.e. Sony Universal remote in your hand. Press mute & Select simultaneously. A blue light will blink twice, Immediately release the buttons & enter the code. You have to be extremely fast in doing this.
002, 000, 011, 080, 111, 006, 071, 128, 1904, 925, 0000, 0834, 0810, 1685, 1786, 1032, 1972.
Check the Visio TV manual for the make of your TV & model no & if code is printed. Then contact Visio TV manufacturer or retailer for the Visio TV code to enter & synchronize with the Sony Remote Control.
Nov 13, 2016 | Sony Televison & Video
Codes for remote control
go to "www.jumboremote control codes.com. Then you need to select either tv codes, dvd controls, cable box codes or other device controls. Then select you device and the codes you need should pop mu. there will normally be more thanone code , so try them each un til one works.
Good luck.
Jul 24, 2014 | Dynex DX-L15-10A 15in Flat Panel LCD HDTV
Remote wont control TV Visio Eco1080
Check and replace the remote sennsor inside your Tv.
Mar 27, 2012 | Televison & Video
We recently purchased a Visio lcdhd tv and the manual that came with our Jumbo uiversal remote doesn't show the code setting for the Visio. Is there a code you can give us.
We can't give you the code without specific model numbers for both the TV and remote control. Try the codes for the Visio models that are listed in the manual. There is a good chance that Visio used the same coding system for more than one model. If that doesn't work, check the Internet support page for your remote control. It may have additional models listed, and one may apply if Visio used one of the other remote control systems on the market at the time your remote control was manufactured.
Oct 27, 2010 | Televison & Video
Have direct tv service, bought a new 37 inch visio flat screen hd tv, need the code number to program my direct remote
could not find your brand at Directv.com but this may work: " You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
Set the "Mode Switch" to the desired mode such as TV for a Television.
Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
Enter the code "991" followed by the "device number"
for Televisions
for "AUX 1" devices - VCRs or DVDs
for "AUX 2" devices - Audio
You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
You can try out each code by pressing one or more function keys such as power, volume or digit keys.
When you've found the setup code that works for your device, press the "Select" key. "
Sep 02, 2010 | Universal Remote Control DIRECTV Universal...
Directv Tivo recorder no remote programming code for Visio 37''
If it were a Tivo series 3 you might have better luck with it.
http://www.tivo.com/setupandsupport/technicalsupport/compatibilityhelp/Using_the_Learning_Feature_of_the_TiVo_Glo_or_Series3_Remote.html
I've had my series 2 Tivo for about 2 1/2 years and never found the correct codes for it. I think it works off of a list of TVs manufactures about 3 years ago.
Nov 22, 2008 | Vizio L37 Television
I'm unable to find a 4 digit device code for my TV remote
Best bet would be to contact the parent company to see about ordering a new remote
http://www.iwsolutions.com.au/contact.php
also if you check the back of newer universal remote cases in any electronics dept and see if your model can be programmed.
hope this helps :)
Nov 16, 2008 | Port Incorporated 2 Port Compact KVM...
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
Visio TV and Direct TV remote
I bought a 42" Visio LCD from Costco and used code 10030 and it worked. It is the code for Goldstar TV.
Nov 17, 2007 | Televison & Video
Vizio L15 Television Logo
613 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
