Question about Kenmore Dryers
Squealing Our dryer makes a loud squealing noise until it heats up and then is gets quieter.
    Problem Solver:
  • 16 Answers
Check your drum slides, drum bearing, guides depending on model.
Posted on Jan 09, 2009
Dryer has very load high squeal at start, lasting few minutes, then high quieter sqeak rest of load. Spins and heats ok
Belt is stretched out and slipping on drum, pulley or both. Time to replace it.
Replacement Belt Part #33002535
http://www.repairclinic.com/PartDetail/Drive-Belt/33002535/791135?ss=c7-x6d646534303030&mr=1
RDU Appliance Repair Washing Machine and Dryer Repair
Jan 02, 2015 | Maytag Neptune MDE4000 Electric Dryer
Our dryer makes a loud squealing noise until it heats up and then its quieter
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 21, 2011 | Dryers
I have a GE dryer that make a very loud screeching noise when turned on. The heavier the load, the louder the noise. The noise gets quieter as the load drys and the dryer barely makes it when turned on...
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 16, 2011 | Dryers
Our dryer was making a loud squeaking noise for a while now it is tripping the circuit breaker as soon as it is started what do you think is our problem.
The drum rides on a bearing in the rear which cause the squeal. The squeal eventually cuts into the bearing and the whole drum begins to rub against the heating element. This causes the breaker to trip.
How it works: GE clothes dryer
Jan 05, 2011 | GE Dryers
After the dryer heats up for a while, it makes a loud squealing noise. It does not stop until the dryer totally cools down. Several certified Bosch repairmen have tried to fix it with no success.
heatman101
Nov 28, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Sep 25, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
LOUD SQUEALING NOISE
Most likely the rear drum bearing is worn. There's a "ball and socket" arrangement that supports the drum at the rear and a repair kit for it. Part #5303281153. Should run around $25.fe7bd93.jpg
Dec 27, 2007 | Frigidaire GLER341A Electric Dryer
Dryers Logo
143 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
