Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Kitchenaid Dishwasher soap door opens as soon as I press the start button.
  • Chad Jones Jun 13, 2009
    I just replaced the control board and it worked fine untill the soap door opened. Then it stopped and the washing,drying, and heavy duty lights all came on and the dishwasher would not work untill i re-installed the old control board. Do you think the new control board was bad? The soap assy is new also.
  • 355 Answers
I think problem is in new control board ...try to check it another board ...and try Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Posted on Jun 13, 2009
  • 679 Answers
Seems some problem withe the botton.
Posted on Jan 09, 2009
  • rockfixya
    rockfixya Jan 09, 2009
    unlucky there is some short in wires that whay your Dishwasher have this problem.
    may be the problem is in the control board.
    Thanks for using FixYa.
  • 124 Answers
Put a latch on put 2screw like a door hinge and see if it will stay held down or a clip that will keep it secure you can pick something up for Lowes to keep it held down but so you can also open it up to put more soap hope this helps
    Sergeant:
    Scholar:
  • 199 Answers
Its some problem with the control panel board giving wrong commands to the other device
Dishwasher control light blinking
1 Press down the overfill protection float on the floor of the dishwasher's tub in the right, front corner near the door. If it cannot move up and down freely, the "clean" light will flash.
2 Make sure the dishwasher's water supply is turned on.
3 Look for suds on the inside of the dishwasher and wipe them off with a wet cloth. If the washer's sensor detects suds or foam, it may not run. Use the correct amount of dishwasher soap, not hand soap or detergent for washing dishes in the sink, to ensure suds and foam do not form. Also, make sure the cap on the rinse aid dispenser is secure--this will keep suds and foam from forming as well.
4 Close the dishwasher door. Push the "normal wash" button, then push the "heated dry" button. Push the "normal wash" button again, and push the "heated dry" button again.
5 Watch for all of the lights on your Kenmore dishwasher's panel to turn on and then turn off. The washer may start a new wash cycle at this point; if you do not want it to do so, press the "cancel" button. Otherwise, allow the dishwasher to run through this cycle.
Nov 25, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
My dishwasher is not cleaning well and is making a lot more noise than it used to. Also, the little door where you put the soap will not open during the cycle so I have to just leave it open when I start...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 22, 2010 | KitchenAid Dishwashers
Kitchen aid dishwasher: When it starts, soap door aways pops open immediately. I do not think that is normal.
No, that is not normal...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
heatman101
Sep 07, 2010 | KitchenAid Dishwashers
Soap door doesn't open and dishwasher stops before completing its cycle.KitchenAid Model #KUD122XX Purchased in 1992
you are in need of a dispenser. you can purchase it online and they will ship it toyou. searspartsdirect.com. you can view it and everything.
if this helps please give me a 4thumbs up post thanks !
Mar 02, 2010 | Dishwashers
Suds coming out of the front
When you have suds rolling out of a dishwasher, you can assume that either that one of the dishes was loaded with liquid soap or that the dishwasher soap dispenser was filled with liquid, manual wash soap or laundry detergent.
After the mess is cleaned up, the quickest way to clean the dishwasher is to start up a new cycle, wait for the hot water to fill the dishwasher and just as the DW starts to pump the water through the spray arms (wash cycle) open the door and poor in two cups of white vinegar.
Hope this helps!
Apr 04, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchenaid kudso1dlss3 clean light flashing cannot do a new cycle
I do not have the same model as you, my model is KUD01ILBS6 but I have the same problem. A service tech told me it was a error code and here is how to fix it.
1 open the dishwasher door
2 hit high temp scrub button
3 then hit energy saver dry button
4 do step 2 & 3 again
5 close the door
6 hit the cancel button
7 you can hit cancel button again then try to start your dishwasher
This works for me, you may have to do this every few months because there is a glitch in kitchenaid where if the water temp is not sensed right it will keep the dishwasher from working. It took me 3 service calls to find this out.
Jan 17, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid dishwasher soap door won't open
I took the door apart and found the degertent door solinoid looking like it over heated and melted to the cover flap and the insulation. See picture. I can't post pic as the max is 150kb.
I applied power and it only got hot and wouldn't operate.
Next I go to Kitchenaid for a replacement - FREE it should be.
Oct 07, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchenaid dishwasher KUDS02SRSS2 start light blinking won't start
I have this same kitchenaid model. It would not start after selecting the wash cycle and pressing start. The light would blink as if the door was open. I did the reset by pushing the sani-rinse, heat dry, sani-rinse, heat-dry and closing the door. You can hear something going on inside. After that stopped (about 3 minutes). I was able to select the wash cycle, press the start, close the door, and it started. Good luck!
Feb 22, 2008 | Dishwashers
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
54 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
