Question about Canon FAX-JX200
Setting jx200 to manual and have ansewring machine connected.
I have a new canon jx200. I am tring to set it to maual instead of automatic because I want the phone to ring more than twice before the answering machine picks it up. Is it possible to have the answeing mnachine pick up after 6 or 9 rings and then the fax pick up after that? If not, how do I set up manual mode I don't see the option on the machine and page 28 of the manual is meant to tell me! Will manual mode let the answeirng machime pick up still? Please help me.
Thanks
Tracey
  • 318 Answers
I normaly set all my fax machines on fax only,but I change my incomming ring count to more than 7 rings,but less than 11 rings,this allow you to have time to answer you call before it goes to fax.But you can set it for manual.
Press the "receive mode/resolution button untill it show on the display-manual,fax only or ansering.
Yes you can use the fax and answering machine when you are out of the office.
Set you answering machine to pick up after one ring,the message must not be longer than 15 sec.
If you leave set your receive mode to answering mode
Hope this will help you
Posted on Jan 09, 2009
Please send me fax manual for Canon-JX200. message
Please send me an email to LBrown18062@hotmail.com and I will send you the manual right away. Please put CANON FAX JX200 in the subject line and I will send you the manual right away. Lawrence Brown
Oct 24, 2011 | Canon FAX-JX200
Fax machine will not receive faxes. Sending okay. Comes up with busy signal at sending point.
Check menu settings and confirm the machine is set for automatic answer. If its in manual mode, you have to hit the start/go button when the fax rings to accept the transmission.
May 17, 2010 | Canon FAX-JX200
Our Canon JX200 fax machine will send faxes but not receive faxes
Normaly it is the auto print off setting that is set to off,press the on/off button once less than a second then it will switch to auto print on.All the faxes in memory will be printed out.
Nov 30, 2009 | Canon FAX-JX200
Canon Fax Phone
It sounds like Tel/Fax mode is not set, but that the machine is likely in Fax Only mode. The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which you have indicated is your desire, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically. If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice. (This is the time the machine spends checking for a fax signal before ringing for the call to be answered as a telephone call.)
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 12, 2008 | Canon FAX-JX200
Fax Phone problem
did you set the duration of the fax to"listen " for a fax tone
do you have the manual?
look at page 41of 80 RX Settings
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=e038b5d4145a8a64a055b705acd590bf&q=Canon+JX200
Aug 12, 2008 | Office Equipment & Supplies
Cannon Fax JX200
The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which appears to be your setting, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls based upon the times that are input in the settings of the machine. It would seem that the best thing to do would be to lengthen the times involved - particularly at step 7 below. I would imagine it is set at a low number - perhaps 10 seconds or less - and needs to be increased to give you sufficient time to answer the call.
1. Press [Menu].
9. Press [Stop].
It may take a few rounds of going through these steps to get the settings just right for your situation, but it should definitely solve your problem. If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently, and I will gladly help you until we have reached a definitive solution.Thank you for using and rating FixYa!
Jul 13, 2008 | Canon FAX-JX200
Set up
So what do you need to know, tell me I'll help mate
Dec 09, 2007 | Canon FAX-JX200
Canon FAX-JX200 Logo
167 people viewed this question
old marine
old marine
