Question about Acer Aspire One Netbook 8.9" Notebook
Does this laptop reqiure a video card?
Does this laptop require a video card to connect it with a tv? does it come with a video card??? because i tried connecting it to the tv and it said "format not supported"... (ps. its linux based)
  • raisa_irfan Jan 15, 2009
    ok. then wud u know anything else that i can use to connect to my tv?
    Genius:
  • Acer Master
  • 1,102 Answers
They have video cards but i don't believe it is compatible
for television
Posted on Jan 15, 2009
Panasonic omnivision TV VCR combo connected to cable box unable to change channels with either remote . When up or down channel buttons are pressed it goes to "line" when channel numbers are pressed it...
cable box needs connected to the antenna in on the vcr..the setup is ..cable box..vcr combo ..tv ..unless your tv has multiple inputs like ours..most of the new ones require a digital signal..it may reqiure a converter box..
Jan 11, 2014 | Televison & Video
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
Connect Dell Inspiron 6400 to VIZIO E601i-A3 60-inch 1080p LED HDTV using VGA Connector
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
Sep 20, 2017 | Vizio 60" E601I-A3 Full HD LED-LCD TV
I have dell studio 1537 laptop with windows vista home edition & i have recently pruchased a LG lcd 22" tv with HDMI port. I'am trying to connect but tv displays "NO SIGNAL". WHat is the...
i have connect to my laptop to the TV thru' 15-pin VGA video connector and change my graphic card setting. I have sendyou a snapshot of the setting which are similar to the laptop.moseskao_1.jpgmoseskao_0.jpgmoseskao.jpg
Dec 01, 2010 | Dell Studio 1537 Laptop
I m using Windows Vista in My Toshiba Laptop,But nt able to run Spider Man 3 PC Game, It Is Having Every Reqiurements to run the game. Problem-Spider Man 3 Will Close Now, Windows Will Notify You If A...
Have you checked the Game to see if it requires and SPECIAL Sound or Video cards in order to function? Also make SURE the game says it's VISTA Capable AND that you have enough RAM (Random Access Memory). If all of that is met, I'd check with the Game Manufacturer for a Solution or Patch-Update.
Jun 11, 2009 | Microsoft Windows Vista Ultimate Edition
Connecting Laptop to LCD
the following connections available to connect ur computer to an TV:
S-Video output: If you have video card(external u will have this), you require an s-video cable and you connect s-video out of your computer to the s-video int of our TV.
TV-OUT: if you have video card(external u wil have this) you you require an coxial cable and you have to connect TV-out of your computer to TV-IN of our TV(it is place where cable connection goes from your cable operator)
DVI-D: if you have video card(external u will have this) you require an DVI-D cable you haveto connect DVI-D out of your computer(a white 15-pin port which looks like VGA port) ....
VGA: it is the port on your computer which is only used to connect to your computer but not to your TV or LCD(strictly)
Thanking you,
M. Sridhar
Dec 29, 2008 | Gateway GM5442 PC Desktop
I want to hook laptop up to tv
after you hook the cable up to the tv, go into the tv's menu to make sure the input mode is set to s-video. then go into the control panel on your laptop and find the settings for your video card and set the output to "TV" or "Clone"
Let me know :)
Dec 24, 2008 | Toshiba Satellite A35-S159 Notebook
Driver required for SAA7130 TV card
have you tried the manafactures website if not have you tried calling them
Feb 03, 2008 | Philips TV Tuner Video Capture PCI Card -...
Acer Aspire One Netbook 8.9" Notebook Logo
123 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
