Question about Acer Aspire 3690-2196 Notebook
How do i reformat my acer 3690 back to original using backup on d drive
  • Randy Hough
    Randy Hough May 11, 2010
    Restore or Format?
    Scholar:
  • 170 Answers
Did you create recovery dics when you first bought it? If not, than you can order them directly from acer. As for restoring from the D drive.
 I think this is the method you are looking for.
  1. Click 'start'
  2. all programs
  3. accesories
  4. system tools
  5. back up
  6. click 'nest' select the second option 'Restore Files and settings'
Any problems let me know. Tell me how you made out, and please rate my answer.
Posted on Jan 13, 2009
I accidently installed windows 8 pro on my Acer aspire E 15 which already had windows 8.1. Now how do I restore my laptop back to its original windows 8.1?
Once you install other version of windows Operating system without formatting, your Operating System and files before would goes to drive C:\windows.old folder and you can backup your files there by opening users folder, but you cant restore your system to your old 8.1 version once you overwritten it ,But you can fix this by reformatting your laptop/netbook or desktop using your original 8.1 OS installer or contact your acer aspire distributor for genuine installer, but don't forget to backup your files at folder i mentioned above.
Mar 16, 2015 | Acer Aspire Computers & Internet
How to reformat aspire one netbook d150
If acer gives you a cd wherein you can insert it and reformat back to original settings, please make sure you shut down the pc and then press repeatedly F12. Then select Boot to CD. Follow the prompts and select Format C: drive to begin reformatting it..
Jul 19, 2011 | Acer Aspire One Netbook
Hi, I want to do a factory restore on my acer 3690 aspire. where can I get the cd to do it ?
The below procedure will only work if you still have your original hard drive in the PC and have not reformatted or reinstalled windows from another media source.
On bootup you will see a message on the Acer splash screen to get into "SETUP".
This will take to your Acer BIOS and it is accomplished by either hitting the F2 or DEL F2 key.
Once inside the BIOS navigate to the menus and make sure that D2D option recovery is enabled. If you do not see this D2D option then you can exit and should not have to do anything else.
Restart the PC again, hold down the ALT and the F10 key altogether, which allows to start the recovery partition and load your system to factory default.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Jan 23, 2011 | Acer Aspire 3690-2196 Notebook
I want to take my acer 3690 back to when i bought it
There is no way to roll back from Vista to XP. If you still have an XP CD Key you can re-install using a windows disk of the same type using your code. All the drivers should be downloaded first to a CD from the manufacturers web site. Plus any data you would like to keep.
May 13, 2009 | Acer Aspire 3690-2196 Notebook
Reformatting hard drive
there is not 2 drives on your laptop. The single drive is partitioned into 2 parts.
When you re-install XP, be sure to re-install on the first partition (it will ask you during the setup). If you re-format the entire drive all will be lost.
Jan 08, 2009 | Acer Aspire 3690-2196 Notebook
I want to reformat myextensa 2300 laptopanits not working by the method in the booklet on the info disk can you please tell me how to clear the hard drive and restore the system to original
You will still need the original drivers and OS using this method first you need to remove your hard drive, determine wether it is an IDE or a SATA or other connections and get a USB IDE or SATA connection connect this to your hard disk open you HD to another PC like a USB flash Card back up all DAT using this technique then reformat you HD return your HD to you laptop reinstall OS and drivers then you have a fresh laptop. Buying a new Hard disk will also be easier then you can just use your old HDD as a backup. Best of luck read manuals and be careful.
May 31, 2008 | Acer Computers & Internet
I reformat my laptop
dear jhayjerr
you have to install the drivers for the functions you want.please visit the manufacture web-site and download the drivers
Apr 05, 2008 | Acer Aspire 3690-2196 Notebook
Reinstall original acer instalation
you can run recovery using the recovery discs which should have been created by you... or you have to go into the OS to access recovery manager...
Jan 31, 2008 | Acer Aspire 3690-2196 Notebook
Acer 3690
I thing you do not need alt you just press f10 and select the drive you want to boot from.
Acer 3690
Alt is defined in the software to jump to the ACER E Technology software suite. If you have wiped the hard drive clean without saving a backup of the application, you are out of luck. If you saved an applications backup, then re-install the Etechnology software suite.
Oct 06, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3690-2196 Notebook Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
