Hi i have ASUS M2N-E Motherboard and AMD Athlon 6400+ x2 when i run CPU-Z it tells me that my core speed is 3200 or around but my BUS SPEED and HT link are only 200 mhz please help
AMD Athlon 6400+ X2 AM2
Crutial Ram Ballistic 4gb ddr2-6400 800mhz
M2N-E Motherboard
thanks
Go into your BIOS setup and find the 'CPU<->MCP55 HT Speed' setting. It should be 5x. If not, change it to 5x, and save and exit.
PLEASE INDICATE WHAT IS YOUR PROBLEM....
oh yes it only give 200mhz bus only.you can get only 200mhz computing prafomance.and not 1000mhz.if bad praformence please comeback i will give few tips to speedup widows xp.(if you are using)
nuwan....
m2ne motherboard
can use .2000 / 1600 MT/s proscesor.
DDR2 800/667/533 ECC and non-ECC, un-buffered memory,
you are using 800mhz ram and your minimum fsb must be 800 mhz.not 200.if it is 200mhz please contact asus helpdesk.
nuwan
My problem is Amd Athlon 6400+ proccesor have to work with 3.200mhz per core and 1000mhz "bus Speed" My bus speed is only 200Mhz Please help I have M2N-E Motherboard maybe she dont support my proccesor 100%
i use 64bit xp. My "bus speed" and "HT Link" were 200mhz . i run 3dmark and i get poor 10 000 points. and this is with
AMD Athlon 6400+ 3.200Mhz
Ati Radeon 3850
4 Crutial Ballistix DDR-2 800mhz
After upgrading the motherboard 5 millions of times i got the "HT Link from 200mhz to 1000mhz. the i run 3dmark and i got 35 000 points and this only from upgrade :)
I still want to get my bus speed 1000mhz maybe with windows vista 64 320$
