Question about HP OfficeJet 6110 All-In-One InkJet Printer
Scanner failure is holding up the whole printer
We had a power outage yesterday, and when the power came back it seems my printer is now fried... when I try to print, I hear a knocking sound, it tries to initalize, it sounds ok then hear this knocking sound and the result is... "Scanner failure Turn power off then on again" I have tired this a dozen times and the printer again trys to initialize with the same result... I cant copy, print or do anything with out this... HELP!! I love this printer!!!!
    Genius:
  • 2,120 Answers
Sorry, a common HP printer problem....uneconomical to repair.
Posted on Jan 09, 2009
We have an XE-A217W which has decided not to work following a power failure. The printer still scrolls but the screens remain blank
Hi Trevor.
By 'scrolls' I guess you mean 'feeds paper'?
If display screen is blank since the outage, try switching off and unplugging the printer for a minute or so, then re plug.
Unfortunately, a power outage often results in surges and brownouts while power is being restored, which can disrupt or damage electronics and electrical devices.
The board may have fried.
Nov 23, 2017 | The Office Equipment & Supplies
Xerox c2424 fault code 37,008.44:54093
There are two things. I most likely suspect that the print head wiper blade has stuck to the print head. Very common problem after a power failure.
Not sure how I didnt see your post before now. But if your still having that problem let me know, I can tell you how to fix it.
Mar 04, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
After a power outage yesterday, my 24" Pure Flat Tube Stereo TV (TTM-2420) is not receiving power. (the glowing light on front of TV is not on and the TV cannot be turned on) I don't know how long power...
Surge protectors are meant to trip whenever an outage occurs to prevent component damage. If possible remove back panel and check if any fuses were burned. If all looks normal then your component is most likely fried.
Jul 05, 2009 | Televison & Video
HP Officejet 6310 scans once but then says scanner failure
hi,
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Jan 19, 2009 | HP Officejet 6310 All-In-One InkJet...
My printer won't turn on after a power failure.
No, there is no reset button.
disconnect the pirnter from the computer and the power cord. press and hold the power button for 30sec. connect the power cord, and connect it back to the computer.
Dec 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
Scanner failure
replace the scanner or the whole unit. only way I have found is to replace the top half of the machine
Oct 16, 2008 | HP OfficeJet d145 InkJet Printer
HP officejet D135 scanner and copyer
Hi..
if the scanner bulb is not moving, then its an hardware problem.
We can try by resetting the printer.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK/ENTER and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Please let me know after resetting.
Thank U!!
Feb 10, 2008 | HP OfficeJet D135 All-In-One InkJet...
Error message
Unfortunately, if an HP scanner quits functioning, the whole unit is dead. You may want to unplug the printer from its power source and USB cable for about 5 minutes, plug them all back in and then retry. Sometimes, a scanner job can get stuck in the spooler and cause the whole thing to stop working until the job is done (even though there isn't a job to do). I had this issue once and this worked.
Jan 20, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Scanner Failure Message keeps popping up
Here it is all over, with all the steps.
1.Unplug power cable from printer.
2.Hold Cancel and Enter. OR you could Hold Cancel and Black Copy Button. Whichever is easier
3.Then plug back in the power cable, while still holding those 2 buttons.
4.It should turn on, lights blink, then it should say FULL RESET on the little screen thingy .
5.Let go of the buttons, and hopefully, it fixed your problem.
Nov 29, 2007 | HP PSC 750 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
103 people viewed this question
Ben Johnson
