Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Replacing lamp for a sony lcd Kdf50WE655
Where is the lamp located in the back of tv? Cant seem to locate it please help!!
  • Anonymous Jan 13, 2009
    i checked the set no wing nuts do we just pull off panel of the 50" lcd rear projection sony vega
  • Anonymous Jan 15, 2009
    How do I go about changing the XL2100U lamp on my television
The lamp is at the front of the TV just to the right of the power button. Make sure to unplug the TV. Also, if the TV has been on let it set for awhile because the bulb will be hot for some time after the TV has been turned off. You have to remove the cover that is just below the screen. This cover runs the entire lengh of the TV. You first have to loosen the thumb screws that are located at the back of the TV. One is toward the bottom left. Other is toward the bottom right. Once these are loose the front panel can be carefully removed. From the front of the TV carefully put outward on the cover at the far right. Right side of cover should pop loose. Do the same on the left side. Next pull gently at the bottom of the cover near the center. Cover should come off now. Once the cover is removed you should see a cover over the lamp. Another thumb screw holds on the cover. The lamp should now be held in with two allen screws. Loose these and pull out the lamp. Make sure you replace the lamp cover after replacing the bulb or the TV won't turn on.
Posted on Jan 24, 2009
  • 108 Answers
It is located in the front of the set behind either a long metal strip cover or a plastic cover. some sets have wing nuts hoding the cover in place. they would be located on the left and right hand side of the set near the bottom edges.
Posted on Jan 09, 2009
I have a Sony tv KDF50WE655, the other day while I was watching tv, heard a noise and the tv went off, displying the lamp red light..I ordered and replaced the lamp. I made sure the lamp is ok and the door...
Please make sure lamp cover is fixed properly in its position after lamp replacement as it has to press a safety switch located nearby lamp cover.
3 times red blink problem is related with that lamp cover safety switch only.
Hope this will help.
Thanks.
May 27, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a tv sony wega 50" model is kdf50we655 the screen doesnt show nothing but the sound woks,i wanna buy the lamp to see if it is the problem,but i would like to know if there is another issues...
the lamp always shatters when blown,and go with a bang.remove the front speaker grille via the black coin-taking screws either side at the rear.the lamp is located fairly central.the lights flash red/green red/green when the lamp has packed up...hope this helps
regards,steve
Jan 18, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
I need to replavce the lamp on a KDF50we655 50 " TV. I unplugged all the cables and have turned the TV so the rear is facing me ,, how do I replace the lamp ?
Hi,here's how : http://www.youtube.com/watch?v=b31IYV3IYKs&feature=PlayList&p=B41B05489C4D25D0&playnext_from=PL&index=0&playnext=1 You can find your original lamp xl-2100 right here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?1=1&CartID=0?Click=48173 Have a bless one!
Apr 13, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a 50 " Sony Wega KDF50WE655
Front panel should unscrew with thumbscrews and pop off and there should be an access cover for the bulb in center.
Apr 13, 2010 | Sony KDF50E2010ATNS 50" HDTV-Ready LCD TV
Where is the lamp on Sony LCD Model No. KDF-E60A20 located in back of TV
There are two thumb screws at lower corners of TV, lose them and take off lower front panel of TV, there you will see lamp cover, unscrew and remove it, lamp is in front of you.
Lamp replacement procedure is written in user manual, click Sony Support to download user manual copy of KDF-E60A20 if required.
Oct 19, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Changing lamp
Lamp replacement is not difficult in Sony KDF-E60A20 TV and procedure is written in user manual.
Unscrew two thumb screws at lower corner at back of TV and take off lower front panel, in approx center of lower front of TV, lamp cover is located, unscrew it, remove it and lamp is there, unscrew lamp with hex key (supplied in new lamp box) and take out old lamp, put new lamp and put things back in reverse order.
Click Sony Support if you want to download user manual copy of TV.
Thanks.
Sep 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony screen image distortion.
see this:
http://ciscdb.sel.sony.com/perl/news-item.pl?news_id=206&mdl=KDF50WE655
Looks like your model is covered till December 2008
Please be sure to rate this solution. Thanks!
Nov 07, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
LAMP
Replace the lamp. In rare cases, the lamp power supply or lamp ballast may also need replacing. But, replace the lamp first, and use an original Sony lamp not a cheap aftermarket replacement. If this helps, please be sure to rate the fix! Thanks!
Oct 21, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Replacing Projection Lamp
Read the manual. Instructions are there.
Jun 26, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
145 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
