Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
When turn on the printer there is no display in the screen
And tthe printer is not copying , justb beeping if I hit any button
    President:
  • 8,637 Answers
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
Touch screen stops working
common problem. might need tho be calibrated. turn off front power switch and then the rear main power switch. turn on the front switch, hold down energy save button and copy button, turn on rear switch and continue to hold energy and copy buttons until the screen displays an X in the top left of the display. immediately release the buttons and touch the X with a pen/pencil/pointed object. the X will move to the center and them to the bottom right of display. touch the X as it moves position. the copier will reboot and the display may work. if not, replace the touch screen. part #n2baayy00771.
Sep 13, 2014 | Panasonic WORKiO DP-C322 Printer
Tip
HP LaserJet 4250n: How to print a config page
Almost all modern printers have the ability to print out a configuration page -- a pre-formatted page with all sorts of information about the printer and its status. The items found on a config page will vary from printer to printer, but typically they include the network address and other network settings, a list of optional features that have been installed, the printer's page count (number of pages printed), and possibly the current ink levels. For color printers, the page count is typically broken up into black and white (or monochrome) and color.
To print a config page on an HP LaserJet 4250n, follow these steps:
A. If the printer is not already powered on and warmed up, turn it on now. Then hit the Menu button (the gray button to the left of the display screen.)
B. Using the down arrow button, scroll down once to Information and hit the Select button (the green button with the check mark on it).
C. Hit the down arrow button again to scroll down to Print Configuration and hit the Select button again.
The config page -- which might actually be two pages if you have a JetDirect print server -- will print out immediately if the machine was at the Ready screen when you started, or it will print out as soon as the printer warms up if you just turned it on. The display screen will automatically return to Ready.
If the printer is currently in an alert state -- because of a paper jam, empty ink cartridge, lack of paper, or other problem -- it won't be able to print the configuration page. Remedy the problem shown on the display screen and try again.
on Jun 17, 2010 | HP LaserJet 4250n Printer
Tip
Fix the 80010514 error on your PS3
If your Play Station 3 (PS3) gets the 80010514 error somewhere, you can try this to resolve the problem:
1. Make sure that the power indicator on the Play Station 3 system is solid red. To do this, press and hold the power button until the PS3 beeps and the light blinks. Once the light has turned solid red, turn the power switch in the back off.
2. Turn the switch back on, then press and hold the power button.
3. Keep holding the power button even after you hear a short beep after 5 seconds.
4. After 10 seconds, you will hear another short beep and the system will shut down (release the button at this point).
5. Press and hold the power button again.
6. Continue holding the power button even after you hear a short beep after 5 seconds.
7. Release the button when two short beeps are emitted after 7 seconds.
8. As instructed by the on-screen message, plug in the controller and press the PS button
9. Select restore Play Station 3 system.
This should not affect any of your save games, demos, etc. but just to be safe you might want to back up to an external USB hard drive.
To backup saves, go to the Play Station 3 Save Data Utility, select the save you wish to copy and hit the Triangle button. Copy should come up as one of the options. If it does not then the save game is copyright protected and can’t be copied. If you can copy it, make sure you have a USB drive attached and copy it to that.
on Feb 02, 2010 | Video Game Consoles & Games
My m2727nf will not allow me to do manual faxing or copying. When I hit the copy button on the machine nothing happens. The same for the fax button.
This could be due to a formatter failure.
Try an nvram
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp, if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Eliteprintersolutions@gmail.com
Sep 23, 2009 | HP M2727NF Laserjet Printer
My printer won't scan. Neither the ADF nor platen work. I put the paper in, and hit the black and white button to sart it and it just beeps.
There must be an error code on the display, unless the main pcb is bad, it tells you what it needs. You need to go to the copy mode in the main display before you can copy also.
Jul 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
HP 7410 all in one-will not copy displaying warming
The display came back on and continues to print ok, but will not copy. Continues to say warming up when you try to copy. I read somewhere that we might have to change some board. We did not wany to put any money into it if we didnt know we could even get it working so we bought a new all in one by Brother. I own 3 HP laptops and the HP printers and have had many problems and their customer service is poor. Thank you for your help and your great site.
Filis
Nov 26, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Brother MFC-8440 will not print or copy
YOU HAVE TO RESET.
TURN OFF THEN PRESS THE STOP /CLEAR BUTTOM THEN TURN ON KEEP PRESS ABOUT 10 SECOND THEN IT WORK .
Oct 15, 2008 | Brother MFC-8440 All-In-One Laser Printer
Xerox 5665 beeping for all functions
  1. Press the [Log In / Out] button on the left side of the Control Panel. The System Administrator Login screen will be displayed.
  2. Enter the System Administrator Login ID using the numeric keypad on the Control Panel, and then select the [Confirm] button on the Touch Screen. The System Administrator Menu screen will be displayed.
    NOTE: The System Administrator Login ID and UserID is '11111' by default. If an error is made, press the [Clear (C)] button and re-enter the ID. To cancel the operation, select [Cancel]. If the administrator has a problem with changing or has forgotten the ID, a service call must be placed.
  3. Select the [System Settings] button twice. The System Settings screen will be displayed.
  4. Select the [Common Settings] button. The Common Settings screen will be displayed.
  5. Select the [Audio Tones] button.
  6. Select the required option from the list, and then select the [Change Settings] button.
  7. Select the [Save] button to save the settings.
  8. Select the [Close] button several times, and then select the [Exit] button to exit.
Jul 03, 2008 | Xerox 5665 Copier
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
32 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
