Question about NetGear RangeMax NEXT WNR834B Wireless Router
Hi i have no wireless from my router. it says i have an available network but will not connect and vista says it is an unknown problem
  • mattwhitcher Jan 09, 2009
    hi sorry am a bit thick how do i get into the router settings?
    thanks
  • eecom May 11, 2010
    Hello
    There could be many reasons why you can't connect. Here are some troubleshooting tips to try:
    1) Can you connect to the internet when you make a wired (ethernet) connection, rather than a wireless connection?
    If you can, this at least narrows down the problem to the wireless connection.
    2) Vista offering you an 'unknown problem' diagnosis might (might) point to a problem with the wireless network adapter.
    You can check the status of your wireless network adapter by going to Start, and type devmgmt.msc into the box you see, to pull up the Device Manager. Go to 'Network Adapters' - click any '+' you see.
    Are there any unusual symbols by the wireless adapter, such as a yellow exclamation mark, or a red X?
    3) If you want to check security settings on the router, here's how to start:
    i) Login to your router, by opening a web browser, and typing http://192.168.1.1 into the address bar. Enter username: admin and password: password at the prompt (or whatever password you have set). You should then see the router configuration screen (user interface)
    ii) If you plan to make changes to the settings, use a wired (ethernet) connection to the router.
    You might want to check the following: under 'Advanced', click Wireless settings: under 'Wireless Card Access List' click the 'Setup Access List' button. If 'Turn Access Control On' is checked, uncheck it. Close the screen and go back to the laptop: try to connect wirelessly again.
    Please check back if anything is not clear or doesn't work, but I hope this will help you/us start to diagnose the problem. Good luck..
  • 55 Answers
You will have to go into the routers setting and set it to allow wireless connections. it may just be set to send out the SSID but not allowed connection. or the saved key has changed from the rougher defalt key
-tg
Posted on Jan 09, 2009
How do I ad another computer to my router
Since you are adding one, it means you do have a computer that is already working with this router. It means you router is been configured already. So if you need to add another one, its very simple.
For wired connection:
-just get an Ethernet cable long enough to reach your computer then connect the ends on the available Ethernet port located on the back of the router and the other end should be connected on the Ethernet port on your computer.
For wireless connection:
Look for a wireless icon on the bottom part of your screen near the clock. For Windows Vista and Windows 7 just click it and will show you the wireless networks that are available. For Windows XP, right click the icon and select "View available wirleess networks". As soon as you see the list of wireless networks, select yours and click "Connect". If your network is secure type the security key that been setup on the wireless router, if not secured it should connect immediately.
May 21, 2011 | D-Link DIR-615 Wireless Router
I got a Netbook, I have been using wireless internet in my home for years but cannot connect to internet with new computer.
In order to connect with the wireless router u need to scan for the available wireless networks in the range .
So if u r using Win XP ,
1. Rightclick on the wireless network connection.
2. U will see view available wireless networks..
3. u will see ur network name
4. enter ur security key
5. Connect
Or if u r using win vista :
1. click on start
2. Connect to wireless network.
5. Connect
In case u need further help , feel free to get in touch .
Nov 24, 2009 | Computers & Internet
Dlink wireless windows vista
Connect an Ethernet cable to one of the 'LAN' ports on the router and to the network-port on your computer.
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER.
You should get output like:
Ethernet adapter Local Area Connection:
IP Address. . . . . . . . . . . . : 124.268.336.448
Default Gateway . . . . . . . . . : 123.456.789.0
Start Internet Explorer.
Type: http://123.456.789.0
to connect to the web-server "inside" the router.
Run the "wireless network setup wizard" to configure the router
with an SSID and a password.
Save and reboot the router.
Disconnect the Ethernet cable.
Your computer should report "Wireless Networks are available".
Choose your network, and enter the password for the network.
Nov 18, 2009 | D-Link DIR-615 Wireless Router
I'm trying to connect vista laptop to d link dsl-604t router wireless which has a mac os 10.5 with password using it
On Vista, when you "view available networks", is the SSID (that you configured into the router) listed as an available network?
If so, click to select that SSID, and click CONNECT.
Nov 06, 2009 | D-Link DSL-G604T Wireless Router
The router is connecting me with an unknown network
your router is not connecting you to a different network.it`s your laptop which is connecting automatically to a preferred network or you can say it is connecting to whichever unsecured network is available.please clear ypur preferred network list or you`ll keep facing the same problem.i can`t explain you how you can do that because you have not mentioned the OS you are using.please use google for the same.thankyou
Jul 16, 2009 | D-Link 802.11g Wireless Router WBR-1310...
2wire312
You may want to double-check if the wireless adapter on your laptop is enabled. If it is enabled, try to view the available wireless networks on your wireless connection and select the name of your wireless network. You may also want to check your wireless router if there is a wireless security enabled. It is important that you know the wireless settings on your wireless router to make sure that the wireless adapater settings on your laptop match the settings on the wireless router.
Jul 02, 2009 | 2wire HomePortal® 1800HW Router...
Fifth computer unable to connect to internet
-- ckeck if you see 'wireless connection' in the network connections, in order to find it, click start --> control panel --> network connections and you must see wireless connection in case of win xp..
start --> control panel --> network and internet --> network and sharing center --> manage network connections and you must wireless network connection under LAN or hi speed connection... in case of win vista
--if you have that ikon that means you have your drivers installed on the computer properly
--right click wireless network connection and click "view available connections" in case of  xp and "connect/disconnect" in case of vista you must find the network and get connected..
letme know if you have problems connecting..
Jan 24, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Acer with Windows Vista does not connect to Internet
You're laptop needs to have a profile for the router. Go to Network and Sharing Center, Manage Wireless Networks. Please remove all the listed networks there. Now click on Add, then Add a Network in Range of this Computer. Select the wireless name of your router and connect. If it asks for a network key, please type your wireless security key then connect. That should do it.
Dec 19, 2008 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Cannot connect to a network that is using D'Link's DIR-615 as its wireless router
Log into your router and in the, I belive is the advanced tab make sure you have the PNP box unckecked, reboot and it shoud be able to connect.
Sep 15, 2008 | D-Link DIR-625 (790069292637) Wireless...
Landline computer internet works but laptops can't log on through the linksys wireless router.
make sure that your wireless is associated to your router you can check that by going to:
in vista:
click the start > connect to a network > then there is a selection window to connect to your wireless network.
in xp:
click the start > settings > network connection >right click the wireless icon then choose view available wireless networks, choose and connect to your wireless network name.
Sep 15, 2008 | Linksys Wireless-G WRT54G Router
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
48 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
