Question about Sony TC-WE305 Single Cassette Deck
I have two sony tc-355 tape decks with identical problem of left channel dead. No output or input. Purchased schematic and was able to verify power supply ok, but beyond that i am lost. Any ideas?
    New Friend:
  • 111 Answers
Yes,
check the muting circuit.if cannot fing please mail me i will tell the whicharea.
send the diagram.
to roshanw@ccl.lk
Posted on Jan 09, 2009
Where can I find an owner's manual for Sony TC-355 tape recorder
Hi Cloise,
Go to HIFI engine at this link. Sony TC 355 Manual Stereo Tapecorder HiFi Engine .
Here is the TC355 page. Sony TC 355 Manual Stereo Tapecorder HiFi Engine
You must create an ID and Login to obtain the free download.
Fare. Well.
Dec 12, 2014 | Sony Audio Players & Recorders
Sony Stereo Tapecorder TC-355
Contact Sony they will tell you where the nearest service center is there.
Jan 28, 2014 | Sony Audio Players & Recorders
Sound pc d3941 zennox
Yes and no. If you swap the channel leads over the fault should go to the other channel. Still the same, then not the Cassette deck.
There are several causes to one channel going. First the lead to the tape head is off or the head has gone!! Secondly a switch either on the front of the machine or the inside (when it switches to record) is faulty. Lastly an electronic fault. The good thing is that you have one good channel to play with. So as they are both the same any readings should be the same for both channels. The electronics will also buzz when touched with an insulated tool. So if it buzzers in one place in one channel it should do the same in the other in the same place.
Jun 22, 2013 | Sony TC-WE425 Dual Cassette Deck Single...
Hookup soney duel tape deck to onkyo equalizer
If you are trying to equalize the sound from one half to the other ... you cannot, unless there are separate INPUT and OUTPUT jacks on the back. Otherwise you will need a second cassette deck.
Sep 23, 2012 | Sony TC WE435 Stereo Dual Cassette Deck...
Hookin equalizer to tape deck and recever
The equalizer I have seen have Line in, line out, tape in, tape out and that is how you utilize a unit like this. The line IN goes to the receivers tape record out. The line out goes to the receivers Tape play in or monitor, The tape deck hooks to the equalizer. The record or input of the tape deck hooks to the EQ record out, the Tape decks output hooks to the EQ's Tape in connectors. All these are stereo so there are left and right sides which you need to keep consistent. Red on a cable means Right, the white or black on cables mean Left or the top RCA connector on most equipment.
When playing back a tape the tape monitor is turned on with the receiver and left on. The way you record on tape from any source of the receiver is to select that source and it should go to the equalizer. Then the deck should record that source. To play a tape of the deck hooked to the equalizer then just press the tape monitor button on the EQ otherwise the Equalizer will just act as a loop and equalize any signal source that is coming from the receiver and the tape monitor on the receiver should stay on most of the time. Some equalizers have two tape inputs so you would hook another deck to that input and the owners manual of the equalizer should say how to select buttons to transfer tape signals from one to the other. If you master the concept of inputs and output of audio equipment then this hookup becomes another easy thing to do.
Sep 22, 2012 | Sony TC WE435 Stereo Dual Cassette Deck...
What kind of amplifier to use?
Anything that accepts its common standard Line Level RCA inputs and outputs.
In case you don't have the manual. http://www.retrevo.com/support/Sony-TC-WE475-Tape-Decks-manual/id/268dj378/t/2/
Aug 25, 2011 | Sony TC-WE475 Single Cassette Deck
Sony TC-530 hum in internal amplifier left channel.
Electrolytic capacitors are good at causing hum. You could try replacing some of them, they are not expensive. Otherwise you might have damaged the left channel amp semiconducter, whatever that might be.
Nov 25, 2009 | Audio Players & Recorders
Sony tape decks model tc-355
Follow the left channel lead to where it joins with the PCB. Use a pointed tool and prod connections if you get a buzz then that stage in the amp is working. I suspect you will find it leads to a IC that might cause the fault. If you find it buzzers on the right but not left, then it's gone. PS don't short pins. If you can get hold of a signal injector it will make things easy.
Be careful and good luck.
Jan 08, 2009 | Sony TC-WE305 Single Cassette Deck
Sony TC-WE305 Single Cassette Deck Logo
298 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
