Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Buzzing Noise A buzzing noise emits from the back of the TV when it's on but not all the time. I notice that when the picture changes the noise gets stronger then goes down until it goes away. But then it comes back. It is most annoying. Could it be a circuit board that is on its way out? Thanks
  • lagmeson Jan 15, 2009
    Thanks for the response. I did take the back cover off and sprayed the power circuit board with a cleaning solution for circuit boards I bought from Radio Shack. Of course the TV was unplugged & waited for 4 hours to allow the solution sufficient time to dry. However, the noise was still there & I noticed that one of the two big round components on top of the board (oriented with the TV upright) has the top seal buckled (I have a feeling it is breached) and hot to the touch compared to the other one beside it. Also the buzzing noise seems to be coming from behind the cover of what looks like a heat sink. Tried to open the top cover but could not & left it alone before I break it. Maybe I should try and get the board fixed?
    Thanks again.
    Novelist:
  • 140 Answers
It really sounds like your power supply is having problems with heat and not enough cooling inside your tv. You should if you can take the back cover off, also, and blow out all the lint and dust that has been drawn into the tv over time. Usually a couple of years is enough to build up dust and lint that can cause tiny static discharges inside your set. If there is a way of keeping your set cooler by placing it in a different position where there is sufficient room for air to circulate without restriction around it, that would help as well. The power supply the one with the power cord going to it from the inside should be your culprit. Good luck and God bless.
Posted on Jan 14, 2009
TV started making a buzzing noise at start up which gradually got worse ovre time until it would not shut off unless unplugged.
This tv unit have a colors wheel design into it.This tv problems,having loud squeling,buzzing noises or colors pictures are flashes black&white with the pictures.The tv colors wheel it is worn out and it is dying.The tv have a loud buzzing noises because the tv colors wheel it is worn out and warping out of it axis and it is spinning and hitting it steal frame box.The tv colors wheel sit way back of the tv behind many mechanical parts.Have no experience in mechanical works like take things aparts and putting it back again.Hire a tv tech. to change the colors wheel.
May 03, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Hi, I Purchased an LG 50PK350 plasma tv and I am experiencing an extremely loud, annoying buzzing sound even with the amp switched off & the sound muted. The buzzing is not constant ... the brighter...
I have this tv aswell, and yes I will confirm that it does buzz quite alot, but all plasma tvs do, it is to do with how it renders images, the buzzing can be made worse by it being close to a wall and it reflecting back. I found that my tv stand some how amplified the buzzing when i got mine. I dont think its something you can escape.
Mine i notice also when scrolling around menus seems to have lines that follow your selection....not to pleased about that
Oct 18, 2010 | Televison & Video
Hitachi plasma buzzing noise
sounds like bad audio pcb if buzz comes thru
the speakers,
Aug 19, 2009 | Televison & Video
TV EMITTING A BUZZ NOISE
You have a cracked Plasma panel. If u remove the back cover of TV and look in the top left of the plasma panel u will see a small round cylinder tube with glass tip inside. Look with a flashlight and u might see the crack. OH the buzzing noise is from the current going through the panel just not ignition the gases inside the panel to light the phospher cells. Hope this helps.
Apr 15, 2008 | Televison & Video
High pitch buzzing and no picture
Your power supply, I mean the internal power suppy could be faulty, if you know how to deal with it, check it for abnormal oscillation, or get some help from someone who knows how to repair it.
Jan 28, 2008 | Sansui CVDV9000 9 in. TV/DVD Combo
Buzzing loud noise constantly.
I HAVE A RCA 50 HDTV DLP MODEL #D50LPW134 IT MAKE A BUZZING SOUND AND NO PICTURE i CHANGE THE BULB AND STILL NOT WORKING.
cantrin@hotmail.com
Ken
Dec 12, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
121 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
