Question about Starbucks Saeco Italia Digital Barista Coffee Machine
It keeps saying I need to prime.
It sound like it is working but the descaling solution wont get through the machine. It wont rinse or anythingjust says prime and then when I open the wand or hot water it says close the knob. Please help . Thanks Patti
  • Anonymous Feb 03, 2009
  • Anonymous Feb 05, 2009
    keeps saying I need to prime but nothing seems to get past this
Had the same problem and almost took my machine apart. The very simple solution was in the end: the steam wand was blocked. I unscrewed it, poked through it with a long needle, screwed it back on and everything was fine.
Posted on Apr 16, 2009
  • 29 Answers
Http://www.starbucks.com/customer/faq_qanda.asp?name=brewequip
here is a link to troubleshooting and the manual can be downloaded at the bottom of the page
Posted on Feb 27, 2009
Saeco talea giro plus
Yes it sounds like the pump is clogged with scale.
Oct 26, 2016 | Saeco Coffee Makers & Espresso Machines
My keurig b60 says prime
This can go out by draw out some hot water. However if this happens very often then you need to perform a descale.The brewer should be descaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. Descaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend descaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The descaling process involves using 48 ounces of undiluted white vinegar. Learn how to descale your brewer.
Feb 24, 2012 | Keurig B60 Coffee Maker
Needs descaling, I don't have the manual, what is the procedure??
Hi Auto descale: To automatically descale your machine, press the scoop or menu button and hold it down until you enter the menu. Use the arrows on the to scroll up until you come to "Descale". Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and close the open the steam knob again. Let it quit on its own. Refill tank again and prime the machine and your ready. Exit "Descale mode and scroll down to "Reset descale", press the enter button and chose "Yes", then exit and your ready for the next time.
Jul 21, 2011 | Saeco Royal Professional Espresso Machine
How do you descale
Hi
The first thing you need to do is go to your menu. Scroll down to water hardness and push the enter button. Use your up arrow and move the number to 4 if it is not already there. Push the enter button. Once it is on 4, then scroll up to "Descale machine" and push enter. Have your solution (NOT VINEGAR) Citric Acid dissolved in solution and put into water tank. Now open the knob for steam and let the machine do its thing. When it is all done it will say "Finished descaling". Rinse out the water tank and put in fresh water. Close the knob and then reopen it again. When it finished rinsing scroll down to "Reset Descale" Push enter and choose "Yes" with the arrow and push enter. This will bring up a message when it needs to be descaled again. You can also see how many coffee's you have made. It's just above the Descale Machine in your menu. Descale more often than Not Enough will keep your machine working well into the future.
Apr 29, 2011 | Saeco Magic Comfort Plus Espresso Machine
I have a Gaggia Titanium, I did descaling, had difficulty during the process. It shows ventilate. I have tried priming, but it doesn't pump water through the nozzle
Hi.
Disconnect and re-apply power (unplug power cord). After that try doing rinse and descale procedure as from manual. You may need to keep adding water while performing the procedure.
See also: the ventilate error.
Regards.
Ginko
Apr 20, 2011 | Gaggia Titanium Espresso Machine
Magic Comfort Plus Espresso Machine: how to descale saeco magic comfort...
  • The first thing you need to do is go to your menu. Scroll down to water hardness and push the enter button. Use your up arrow and move the number to 4 if it is not already there. Push the enter button. Once it is on 4, then scroll up to descale machine and push enter. Have your solution (NOT VINEGAR) Citric Acid dissolved in solution and put into water tank. Now open the knob for steam and let the machine do its thing. When it is all done it will say "Finished descaling". Rinse out the water tank and put in fresh water. Close the knob and then reopen it again. When it finished rinsing scroll down to "Reset Descale" Push enter and choose "Yes" with the arrow and push enter. This will bring up a message when it needs to be descaled again. You can also see how many coffee’s you have made. It’s just above the Descale Machine in your menu. Descale more often than Not Enough will keep your machine working well into the future.
May 07, 2010 | Saeco Magic Comfort Plus Espresso Machine
Problems Descaling
Hi You have finished the first part of the descale process if that machine is like all the others. Rinse out your water tank and put fresh water in it. Then put it back on the machine and close then open the knob for steam and let it run the whole tank out. When it is finished the descale light will disappear and your green light will blink and the water light will be steady. Refill the water tank and close and then open the steam knob to prime so the water light will go out.
Jun 12, 2009 | Gaggia Syncrony Compact Coffee...
The steam unit is taking FOREVER to steam a cup of milk. I have cleaned out the nozzle but it doesn't seem to help. Also, the ventilate message pops up now and again. I just had the machine serviced less...
Hi The first thing you need to do is go to your menu. Scroll down to water hardness and push the enter button. Use your up arrow and move the number to 4 if it is not already there. Push the enter button once it on 4 and then scroll up to descale machine and push enter. Have your solution (NOT VINEGAR) Citric Acid desolved in solution and put into water tank. Now open the knob for steam and let the machine do its thing. When it is all done it will say Finished descaling. Rinse out the water tank and put in fresh water. Close the knob and then reopen it again. When it finished rinsing scroll down to "Reset Descale" Push enter and chose "Yes" with the arrow and push enter. This will bring up a message when it needs to be descaled. You can also see hoew many coffee's you have made. Its just above the Descale Machine in your menu. Descale more often than Not Enough while keep your machine working well into the future.
Jun 08, 2009 | Saeco Magic Comfort Plus Espresso Machine
"NEED TO PRIME" alert is on. Have run a couple of tanks of water through the wand making hot water, but still says NEED TO PRIME. The pressure on the water seems a little lower than normal. Tried to...
That message indicates that water lines may be dirty. How long ago or how often had you descales your machine? If you have not routinely descaled then the water lines have to be cleaned ( by opening the machine) manually and/or replaced. Another possibility if you have been descaling it regularly, is that a water line may have small crack. And yet another possibility is that the pump may be going bad and/or the flow meter is clogged ( needs cleaning and/.or replacement). Best suggestion at this time is to have an Authorized SAECO Service Center check your machine. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Jun 11, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Incanto -- no coffee coming out
After I posted this I decided to descale the machine again, even though I'd just done it a couple of weeks ago. After descaling and rinsing I tried running water through the brew group by pressing the pre-ground button, then holding down the big cup button. Still no water, but then I turned the little knob on the coffee dispenser counterclockwise, about half a turn. It worked! I rinsed it well, then made a cup of delicious espresso.
Mar 01, 2008 | Saeco Incanto Classic Espresso Machine
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
446 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
