Question about Compaq Presario 5000 PC Desktop
Cant finish loading win xp
I reformated hd trying to load xp and it stops @ 19% .changed hardrive,still the same ,changed cd rom ,still the same ,could be the ram ,unless some 1 has another idea please post and tx in advance
  • Angelo Giannopoulos Jan 09, 2009
    i thank u very much will try it and post back
  • Angelo Giannopoulos Jan 10, 2009
    well it took me a while but i figured out the problem i formated in fat 32 instead of ntfs and it works just fine now. i guess anyone with a similar problem should try this before throwing it out the window, like i almost did.....
  • 36 Answers
Is this a new computer (built for vista)? If so, then the most likely culprit is the driver set in XP cannot handle your hardware. so it locks when it gets to that point. Or it could be a read/write error. First try installing again, but delete all existing partitions and make new one, and when you format, do not use quick format. If that doesn't do it, you will most likely need to build a custom windows install cd to make it work. You can slip stream Service Pack 3 in, and that helps. you can also slipstream drivers for your PC into the disc so that the will be available at install time. Check out nLite, at the link below, really good package for doing this.
Posted on Jan 08, 2009
  • Andrew Podner Jan 08, 2009
    nevermind, I see that this is a 1998-2000 era machine, still try the solution I posted, it may help you out, as this still may be a hardware issue that wasn't accounted for in the intial relaeas of XP, but was accounted for in a Service pack. Good Luck
Trying to reformat and load my computer for a fresh start. When I reboot to load Windows the screen goes to a small box saying "input not supported". How do I fix this???
visit my site
it has all details on how to reset to facotry setting.....format and reinstall Win etc
you may have to make changes to BIOS to boot from CDROM a 1st Boot device....
press F1, F2, Del, Esc, F12 key other one that brings up the BIOS screen there look for Boot seq....disable HDD and floppy, enable CD ROM drive and make that 1st boot need to change it back to HDD the1st boot device later after loading Win....
once you boot from CDROM then follow inst from my site to format HD....and install XP
all the best
pls feedback and comment on how u did
Nov 07, 2010 | Acer AL1916W 19" LCD Monitor
The screen loads and says to choose to "start windows normally" or launch somerepair thing, but no matter what i choose it turns off then on and back to that same screeen . what do i doo ?
Windows is corrupt...
if you get the option "Load windows in Safe Mode"
then try that option and let the machine load...
once you get the desktop....just shut down and wait for 5 mins to re-start....
if your still have the same trouble
then i am sorry that Windows files has got corrupt and need to be restored....
if you have the WinXP cd or the Recovery CD then try reapir / recovering the system...
if all these fails then the final method is to reformat and re-install Win OS.....
send me a feedback on how you managed....let me c if i can help you again....
visit my site for details on resetting / reformating / installing Win XP / setting the HD
May 10, 2010 | Acer Aspire 5500 5570-2609 Laptop
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
Replaced HD and CD Rom drive, PC will not boot to disk, Do I need to format HD 1st. before loading OS?
Hi Get to the bios screen using F8 or F9, change the first boot device to CD ROM/DVD, then insert a bootable disk into the CD drive and try installing the OS first by completely formatting the HD during installation Win XP and higher OS editions give you the option to partition the HDD Hope this resolves
Nov 05, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Insataling windows xp problms
i believ ur using 32 bit operating system.change the boot sequence by pressing F12 at restart and select cd/dvd rom option while the windows cd still inside the drive,,format the c drive completely{if possible format the whole hdd} and then reinstall the windows os xp..i hope it will work fine,,just follow the screen prompts very very carefully and u will find everything mentioned,,best of luck
May 14, 2009 | HP Compaq Presario CQ60Z Notebook
Error loading operating system
you'll need to run windows setup again.
Insert the cd restart and when asked to start with cd click enter.
Jan 14, 2009 | Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2...
Error mes
Go to the motherboard's CMOS/BIOS setup, normally by pressing "Del" button to enter setup immediately on powerup before XP boots. Set you PC to boot from the CD ROM and not your HD. Thereafter, go through the installation procedure again. You need to format the HD again to clear all former failed installation.
If your concern has not been corrected after completion of the above procedures, pls post back info on motherboard brand and model.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | Intel Motherboard
How to install XP on pre loaded Vista in HP Laptop what can i do
make sure you have taken all the backup of your data from your system bcoz xp will not overwrite on vista you need to be format your drive which will erase your data. for installing windowx xp you need win xp cd as well as all the driver for win xp bcoz the driver is diffrent for vista and win xp . if you have windows xp bootable cd just place in your cd-rom or in dvd rom .and go to bios setup (bios setup is just press the del button from your keyboard or f2 key it is display whrn you start your system )and change the booting sequnce from hdd to cd rom when it will boot from cd one massage will come press any key to continue just press the space bar and follow the setup instruction . if you need more help let me know bye
Sep 28, 2007 | Microsoft Windows XP Professional With...
Compaq Presario 5000 PC Desktop Logo
61 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
