Question about Dell 3300MP Multimedia Projector
Delay/ whitescreen when projecting video from laptop
During powerpoint when I've inserted a Windows Media file video clip, I get a whitescreen and messages such as Analogue RGB searching, Source loss, component searching, then 640x480 85hz.
This is about a 5 second delay during the presentation I'd like to get rid of. Is there a setting on my laptop that I can change that tells the projector right where to go for the source?
robbie
  • 22 Answers
1.
Connect the external display port on your laptop computer to the projection system, and then turn on the projector. For information about connecting external devices to your laptop, see the documentation for your laptop computer.
1.
Set the display resolution of your laptop computer to match the resolution of the projector system. First, on your laptop, open the Display Properties dialog box by using the Display icon in Control Panel, and click the Settings tab. Then, in Screen resolution area, move the slider to adjust the display resolution of your laptop. If you don't know which setting to choose, try 800 x 600 pixels; this is a common setting for many projector systems. YOURS sounds like 640x840.
3.
If you have audio in your presentation, connect a cable from your laptop's audio output jack to the audio input jack on the projector, and then test the volume by playing a file that contains sound.
4.
Start the Player on your laptop. If you want to only display the Player on the big screen, and not the desktop background, maximize the Player or set it to play your video using the entire screen (full-screen mode).
Posted on Jan 09, 2009
The file format is not supported
Hi driddle00...
This information came from the Microsoft WebPage:
"Cannot play back the file. The format is not supported. This behavior occurs because PowerPoint can play back only QuickTime movies (.mov and .qt files) that use compression schemes with corresponding Media Control Interface (MCI)-compatible codecs.
A codec (compressor/decompressor) is an algorithm or scheme that is used to record digital video or audio. For example, when you transmit video over the Internet, the video must be compressed on the sending end and decompressed on the receiving end. A codec can be chosen based upon the user's audio or image quality and image size preferences.
When you read a QuickTime movie, a Video for Windows decompressor decompresses the QuickTime files. If the decompressor does not support the compression method used by the QuickTime movie, the decompressor cannot display the movie on the screen.
To work around this behavior, use one of the following methods. uparrow.gifBack to the top Method 1: Create a hyperlink to the .mov file loadTOCNode(2, 'workaround'); Create a hyperlink to the .mov file, and then let the QuickTime Player for Windows play the file instead. To do this, follow these steps:
  1. Select the object or text that you want to assign the hyperlink to.
  2. On the Insert menu, click Hyperlink.
  3. Under Link to, click Existing File or Web Page.
  4. Select the QuickTime movie that you want to play, and then click OK.
    Note Under Look in, click Current Folder to see a list of files, click Browsed Pages to see a list of recently viewed Web pages, or click Recent Files to see a list of recently used files.
During the slide show, click the linked object or text to play the movie. If a valid player is available, the player starts, and then the player plays the QuickTime movie. uparrow.gifBack to the top Method 2: Convert QuickTime movies to AVI format loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
You can use other QuickTime editing programs instead of QuickTime 4.0 Pro. To do this, see the QuickTime documentation for the relevant steps.
To convert the QuickTime movies to AVI format, follow these steps:
  1. Start QuickTime Pro, and then open the file that you want to convert.
  2. On the File menu, click Export.
  3. Set the Export file type to Movie to AVI.
  4. Click Options, and then click Settings.
  5. In the Compressor group, click the list of compressors, and then select one from the previous list. Cinepak is a popular format. Select the format that you think works best with the movie.
  6. Make sure that you change the extension on the file name to .avi, and then click Save.
uparrow.gifBack to the top Method 3: Recompress the QuickTime movies with compatible codec loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
To recompress the QuickTime movies with compatible codec, follow these steps:
  3. Set the Export file type to Movie to QuickTime Movie.
  6. Click Save.
uparrow.gifBack to the top Verify that QuickTime movies are compatibleYou can use Microsoft Media Player to... loadTOCNode(1, 'moreinformation'); Verify that QuickTime movies are compatible loadTOCNode(2, 'moreinformation'); You can use Microsoft Media Player to verify that a QuickTime movie is compatible with PowerPoint.
Note Microsoft Media Player (Mplayer.exe or Mplay32.exe) is a different program than Windows Media Player. Microsoft Media Player is included with various versions of the Windows operating systems, and is an MCI-compliant device. Windows Media Player, however, is a new technology that does not rely on MCI to play various forms of media. Windows Media Player can play a wider range of video and audio formats than Microsoft Media Player can play.
To determine the compatibility of the movie, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type the appropriate command for your operating system:
    • In Microsoft Windows 98 or Microsoft Windows Millennium Edition, type mplayer.exe, and then click OK.
    • In Microsoft Windows NT 4.0, Microsoft Windows 2000, or Microsoft Windows XP, type mplay32.exe, and then click OK.
    Microsoft Media Player starts.
  3. On the File menu, click Open.
  4. Select the QuickTime movie that you want to verify. Click Open.
If the QuickTime movie is compatible, Microsoft Media Player opens the movie. If Microsoft Media Player opens the movie, but PowerPoint does not, there may be a problem with PowerPoint or with the MCI settings. If Microsoft Media Player does not open the movie, and then you receive an error message in Media Player, the movie is not compatible and cannot be played in PowerPoint. You may be able to make the movie compatible by using one of the methods described in the WORKAROUND section of this article."
Sep 06, 2011 | Philips GOGEAR SA6045 MP3 Player
Tip
HD Video to PowerPoint-AVCHD MTS to Microsoft PowerPoint Format on Windows 7
Aunsoft PowerPoint Video Converter-HD Video Recordings to Powerpoint on Windows 7 <br />Best HD Video to PowerPoint Converter-Deinterlace AVCHD for PowerPoint <br /><br />Microsoft PowerPoint is the most commonly used program for creating slideshows on Windows. There are many formats listed as supported to be inserted to PowerPoint, e.g. WMV, ASF, DVR-MS, MPG, AVI, MP4, MOV. However, you need to install related codec or QuickTime to play MP4/MOV files or AVI movies. <br /><br />If you would like to <b><a href="http://www.aunsoft.com/final-mate/">Present HD videos on PPT</a></b>, such as the AVCHD recordings from your camcorders, you need to convert them to MS PowerPoint supported formats. Aunsoft Final Mate is the recommended <b>PowerPoint video converter</b> for you, as it does not transcode AVCHD MTS/M2TS clips on Windows 7, but also join and cut recordings into a single file. <br /><br />Follow the simple guide for you to get your <b>HD Video Recordings to Powerpoint</b>, and present your PPT with flexible activities. <br /><br />Step 1. Import AVCHD MTS/M2TS files to Aunsoft Final Mate. <br />Run Aunsoft Final Mate as the <b><a href="http://sony-mts-converter.com/2011/06/powerpoint-video-converter-hd-video-recordings-to-powerpoint/">best HD video to PowerPoint converter</a></b> on Windows 7. You can import files directly from camcorder or from hard drive. For videos from camcorder, just connect it to PC via USB cable and follow the wizard. For video on hard drive, just go to the Resource tab, click the Add Path button to browse the folder with AVCHD files. <br /><br />Step 2. <b>Join and cut AVCHD clips</b>. <br />Select the files from the Resource or Camcorder tab, drag and drop to the Movies tab to create a single movie. To get another file as output, just click the drop-down button of the Create New Movie button and choose For Conversion, then drag and drop other clips to the new movie ID. The files are joined/merged automatically. <br /><br />Step 3. Deinterlace 1080i to 1080p. (optional) <br />If your camcorder provides 1080i recordings, you can tick the checkbox for deinterlacing to remove the lines and make video as progressive mode. <br /><br />Step 4. <b>Convert AVCHD to WMV PowerPoint format</b>. <br />Click the Export button, and go to the last tab. Choose Common Video &gt; WMV3 (WMV9)(*.wmv) as output format. Then click the OK button, and the MS <b><a href="http://canon-videoconverter.com/2011/06/best-hd-video-to-powerpoint-converter-deinterlace-avchd-for-powerpoint/">PowerPoint video converter</a></b> will <b>convert AVCHD recordings to WMV for PowerPoint on Windows 7</b>. <br /><br />Wait for a while, and you can <b><a href="http://www.aunsoft.com/final-mate/">Insert/Import the output file to Microsoft PowerPoint</a></b> to create colorful slideshow, and enhance your PPT. <br /><br /><b>Tips:</b> <br />For Mac users with PowerPoint on Mac OS X like Leopard or Snow Leopard, you can try Aunsoft <b>Final Mate for Mac</b> as slideshow presentation helper on Mac.
on Jun 10, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
It's me again! i hade a problem: I would like to make a slide show for a dvd with pictures,and that repeats itself.what program,and how should i use(i have windows xp)!and after i would like put the disc...
Versatile and easy PowerPoint Converter
This PowerPoint Converter is a great Microsoft PowerPoint presentation tool that can convert PowerPoint to video and audio file in almost any formats. All the original elements in PowerPoint can be perfectly retained in this PowerPoint to video conversion, including animation, sounds, movie clips, transitions, internal links, and so on. PowerPoint 2007 is supported.
PowerPoint Converter can convert PowerPoint file to AVI, 3GP, 3G2, MP4, WMV, MOV, FLV, VOB, MPG, MPEG1, MPEG2, DV video and MP3, AAC, M4A, WAV, WMA, AC3, MP2 audio files for you to upload PowerPoint to YouTube, watch PowerPoint on iPod, iPhone, Zune, PSP, Apple TV, Blackberry, Creative Zen, PS3, Xbox, and more MP4, MP3 players.
The PowerPoint to Flash Converter can help you convert PowerPoint slide in to Flash video. You can input ppt, pptx, pptm files and get FLV or SWF videos. Then you can upload these video to YouTube, your Blog, your Space, and other websites to share with others.
Now, with the powerful PowerPoint Flash Converter, your files documents can be shown on the Web not only as a standalone document in a separate window but also can be embedded in a web page and shown inside it altogether with other web page content.
Here, the PowerPoint to PDF Converter can help you create PDF file from documents including ppt, pptx, pptm. It is easy-to-use software which can translate different doucment formats to pdf in batches once with ease.
To convert PowerPoint to PDF is easier than ever with this powerful converter. And only several clicks are needed to finish all the conversions with high converting speed and super good output quality.
The original style of PowerPoint files can be perfectly retained, and both beginners and pro users will find this PowerPoint to PDFconverter tool quite easy to use.
PowerPoint to DVD Converter mentioned in this part is an excellent converter from PowerPoint to DVD tool, that can convert PowerPoint to DVD video and burn PowerPoint to DVD, with rich DVD settings, supporting all sorts of DVD discs. Then you can watch PowerPoint on any DVD player.
PowerPoint to DVD Converter can perfectly retain the original music, animation, movie clips, and slide transitions of the original PPT files. And it allows you to insert background music, or record voice as the narrations and instructions for the PPT files.
You can also use PowerPoint to DVD Tool to create delicate DVD menus. It is the best tool to create a DVD from PowerPoint for playback on home DVD players. PowerPoint 2007 is supported.
Moreover, this versatile PowerPoint to DVD Converter also helps convert PowerPoint to all popular video formats like AVI, MP4, FLV, MPEG, 3GP, MOV, WMV, MPEG1, MPEG2, MP3, AAC, etc. Then you can watch PowerPoint on iPod, iPhone, PSP, Apple TV, Zune, Creative Zen Player, Black Berry, etc.
PowerPoint to JPEG Converter can convert PowerPoint to JPEG image file and convert PowerPoint slide to JPG picture file. It is the best PowerPoint JPEG converter and PowerPoint JPG converter, which is both powerful and easy to use.
Microsoft PowerPoint 2007 are supported by this PowerPoint converter, it can convert .ppt, .pptx, and .pptm files to all popular image formats with fast speed and excellent image quality.
PowerPoint Slide Show Converter,
PowerPoint to SWF Converter,
PowerPoint to AVI Converter,
PowerPoint to MPEG Converter,
PowerPoint to WMV Converter,
PowerPoint to MP4 Converter,
PowerPoint to FLV Converter,
PowerPoint to iPAQ Converter,
PowerPoint to iPod Converter
Aug 11, 2010 | Computers & Internet
Downloadin videos
Here is a complete guide for your presentation if you have, for example, you tube video to incorporate in your powerpoint presentation.
http://www.acoolsoft.com/knowledges/embed-youtube-powerpoint.html
Jul 10, 2009 | Computers & Internet
Photos to slideshow converter
you can install windows movie maker software. then you can create slideshow movie.
Mar 03, 2009 | HP Pavilion dv6000z Notebook
Powerpoint video problem
Does the videos play well in Windows Media Player? If not, it deciates that there are not proper codec installed on your computer.Try to download and install some new codec from official: http://www.microsoft.com/windows/windowsmedia/forpros/format/codecdownload.aspx. Go for codec references at: http://www.codecguide.com/
If the video plays well, please try the following methods:
Method 1.
1. Put video files and the PowerPoint presentation in a same folder.
2. Re-insert these files to PowerPoint presentation.
Method 2.
Insert -> Hyperlink, choose the video file you want to insert, and then click ok. After do this, you can click the hyperlink to view the video when present the slide show.
Method 3.
 1. Display the slide you want to insert video.
 2. Click the View menu in the menu bar, and then choose Toolbars in its child menu, later Control Toolbox to let Control Toolbox displayed. Choose More Controls which seems like hammer.
 3. In the succeeding dialog box, choose Shockwave Flash Object. Your cursor will change into a cross-hair - draw a rectangle anywhere on screen
4. Right click the inserted Shockwave Flash control, and then click Properties.
5. Click the Movie property > type the full drive path in the value column (the blank cell next to Movie), including the file name (e.g. C:a.swf) or URL (e.g. http://www.a.com/b.swf)
6. To make the Flash play automatically when the slide is displayed, set the Playing property to True;
7. Finally close the Properties window and save your presentation.
Method 4.
Convert your PowerPoint presentation to Flash use some third party presentation tools, PowerPoint to Flash converter, for instance.
BTW, the link: http://www.playsforcertain.com/tutorial.htm may help you.
Nov 04, 2008 | HP VP6121 Multimedia Projector
PC Video Codec
Hi Ron,
Please click on the link below and download full codec its free, Ths should take care of the problem.
http://www.free-codecs.com/K_lite_codec_pack_download.htm
Thank you
Sep 08, 2008 | Microsoft Windows XP Professional
Powerpoint to video
YOU NEED TO ARRANGE 3RD PARTY SOFTWARE LIKE WonderShare PPT2DVD
Jun 21, 2008 | Microsoft Windows XP Professional for PC
Video in GoTo
This is actually quite common when using powerpoint files with online tools. From the guide:
"A current constraint of collaborative software (including
GoToMeeting) and the bandwidth connectivity to sites is that digital video-clips are NOT
transmitted satisfactorily. The sampling frame rate is not adequate for high quality motion.
To overcome this and provide the clips in their original quality to the virtual participants, the
transfer the powerpoint files and the associated video clips is undertaken as a routine
practice. They are then manually played at each site on adequate pausing and cueing from
you the speaker. It is advisable to confirm that they have viewed the clip before proceeding.
Given notorious incompatibility problems with wide variety of video standards, file formats,
proprietary codecs (for compression/decompression) and the main players (Windows Media,
QuickTime & Real), it is essential to have a technical pre-check of the clips completed in
advance at each site. This is scheduled for the inclusion in the technical testing on the
Wednesday immediately prior to your seminar.
NO audio track should be included with the video clips. This avoids the potential problems of
audioinstabilityor‘howl-around’totheconferenceandallowsyoutoprovidethesingle
commentary."
Sorry that formatting is a little sloppy. Hope this helps, and I'm not sure about the last part of what you said, in regard to media player being choppy. Were you saying that you played the source video locally in media player and it was choppy? Cause that would be another issue ;)
Feb 19, 2008 | Citrix GoToMeeting
Dell 3300MP Multimedia Projector Logo
317 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
