Question about Brother MFC 7420 All-In-One Laser Printer
Machine on FAX, will copy, but won't print from computer
All connections seem to be in place. Have spent too much time trying to find instructions in my husband's office. He is in hospital and unable to tell me how / where. Am working to a deadline. I know this will be a simple matter, but am unable to find the way.
    Champion:
  • 320 Answers
You need the sey up cd that came with the machine, it will automaticly set up the machine or you can manualy do this from my computer printe set up
Posted on Jan 13, 2009
How do I install connect fax and scanner to my computer
There are a minimum of 3 cords:
power
phone
computer (likely USB)
Power to the wall.
Phone to a phone line.
USB cable to the computer.
Computer should recognize the machine is there. Load software.
Sep 11, 2014 | Copystar REFURB HP Office jet 6500...
Toshiba estudio 255 Cannot usefunctions
you must connect the machine with you're computer.you want the fax you must check the you're photocopy machine have a fax board.you want the scan & printing connect the photocopy machine to the computer.(network cable)
Jan 27, 2014 | Toshiba estudio 255 Copier
Lexmark 5250 won't fax. I have installed everything several times but says something about OCR not working. It will scan & print instead of sending document to Fax. I can open Fax window, but...
Use the Lexmark All-In-One Center application to send faxes from your computer (make sure your computer is connected to a fax modem). From the Creative Tasks section of the All-In-One Main page, click Fax using PC modem. Follow the instructions on the computer screen.
Jul 25, 2011 | Lexmark X5250 All-In-One InkJet Printer
I got the OfficeJet 4500 (not the wireless) and there isn't a phone jack near my computer. Could I set the machine up in the other room and still have the print/scan/copy features work properly?
well yes but you need to connect it to a computer to print,,
by itself with the phone line, you can fax and copy but not scan and print..
Why not just purchase a Phone extension (50'' or what ever length you need and extend the line to a place close to the computer ??
Mar 30, 2011 | Office Equipment & Supplies
I have an SCX-4521F and suddenly I cannot send or receive a fax. There is notification that a fax has been sent to me, but it does not print. When I send a fax, it tells me there is "no answer"...
Hi, I am Steve and I and going to help solve your issue.
I am going to start with the 2 simple things that may be causing this. Please accept my apologies if you have tried both of these solutions. If you have please let me know and we can go on to more advanced troubleshooting.
As the machine has suddenly stopped sending or receiving faxes I am assuming it was working prior to this issue.
The first thing to check is whether the machine is still setup to enter fax mode. the best explanation for this is directly from the Samsung support - click here for the instructions on ensuring automatic fax mode is enabled.
alternatively the memory could be full. again I am going to use the Samsung support site instructions to help you clear the memory - click here for the instructions and you want to clear the fax memory (option fax feature) if this does not work it may also be worth using fax setup and advanced fax - these will reset the fax machine to its factory defaults.
Please let me know if these solve your issue, if not we can move onto further troubleshooting?
Jan 13, 2011 | Samsung SCX-5115 Fax Machines
How do i print out the recieved memory?
It appears the feature you are looking for is called Print Local Copy.
The Print Local Copy option allows you to
set the machine to print the fax on your machine, if fax
forwarding is completed without any error
The instructions are not clear, but they seem to indicate that you find this under Menu, reports.
Here is a link to the complete user guide.
Dec 18, 2009 | Samsung SCX 4521F All-In-One Laser Printer
My hp printer fax does print when recieving a fax but doew print normally when coming off computer. Fax machine sya low on ink should I check both cartridges and get new ones
Yes , if the fax machine says low ink or toner , then it needs it alos check the drum corona wire, It may need cleaning, and you can clean it using a #2 lead pencil eraser, Gently in the wire, then replace wire and try receiving a fax.
Jul 10, 2009 | HP 920 Plain Paper Fax
Drum error message
check the silver spring loaded contacts inside the drum cavity make sure they casn be pushed in and spring back out. Also clea them with a dry cotton swab
Jun 10, 2009 | Brother IntelliFax-2820 Laser Fax
IntelliFax 4100 suddenly slow to print
If the dial tone sounds NOISY or SCRATCHY there probably is a phone line problem. Try changing the phone cord first. Are you using DSL phone service?
You have a very reliable fax machine.
Nov 13, 2008 | Brother IntelliFAX 4100 Laser Fax
Ink cartridges, recieving fax
It sound like your machine is receiving but as soon as it tries to prints the fax it has this problem.
Rewind the ink ribbon so it is nice and tight in the housing. Clean the black roller above it with some cleaning alcohol or equivalent (nothing too harsh).
See how that goes if you are still having problems replace the whole cartridge (not the refills) PC-401.
Feb 19, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Brother MFC 7420 All-In-One Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
