Question about Acer Aspire 5610-4648 Notebook
My acer laptop light is weak the light starts for 1min when I swich on then become dim & dark I can see when I come more cloth to the screen but its weak,I have tried all the Fn how can I fix it? can you pls send me the answer on my e-mail
    Genius:
  • 1,019 Answers
This will be in the Display settings. Which will be set to reduce the power for display properties. Also Check that your charger is plugged in and working Correctly. Laptops automatically dim on Battery Power to save Power.
Thankyou For Using Fixya.
Mike @ Compurepair.
Posted on Jan 09, 2009
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
My acer 5220 is dim
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Oct 02, 2012 | Acer Computers & Internet
Dark laptop screen inverter and lamp ok
It might be necessary to send it in to Acer for their technicians to look at it as they have parts there. The damage of the display panel many have damaged other parts as well I would suspect the ribbon cable that feeds the display from the main body section. Is power getting to the inverter? Look at the items you have not compared with the other unit such as a ribbon cable- what else is there?
Sep 26, 2012 | Acer Aspire 5630 Notebook
THE SCREEN FLICKERS ALL THE TIME, HOW CAN I FIX IT
The screen flickering could be the screen inverter starting to fail. The inverter sits under the screen behind the bezel, it takes the low voltage DC power from the power adapter and converts it to high voltage for the screens backlight. If the inverter starts to fail, you either get a dim display that finally goes dark or get flickering like you see in some store lighting fixtures when the flourescent bulbs are failing.
Jan 15, 2010 | Acer Aspire One AOA150-1570 Notebook PC
My laptop is very dark and holding fn and the sun
The Back-light on your LCD screen is bad, your crystals aren't illuminating, so it is dark.... very dark.
You need a new LCD screen.
Sorry.
Sep 24, 2009 | Acer Aspire 5500 5570-4421 Laptop
Acer screen looks dark?
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 23, 2009 | Acer Aspire 5315 Notebook
Acer 6930 won't light?
You could have an inverter problem, it supplies high voltage to the CCFL backlight lamp or you have a faulty CCFL lamp.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 18, 2009 | Acer Aspire 6930-6455 Notebook PC
Screen of my acer 3680 turns off and the laptope power off
try system recovery.or try recovering windows through a Rescue disk.
Feb 28, 2009 | Acer Aspire 3680 Laptop
Acer Travelmate LCD screen went dark
The same thing happened on my HP. I ended up buying a LCD screen off ebay. That corrected the problem. New screens cost $150+. You can get one off ebay for half the price.
Jan 16, 2009 | Acer TravelMate 270XV Notebook
Dim Screen
there is a monitor brightness that is usually a combination of Fn(lower left of keyboard) and F5..try that to see it it raises the level
May 13, 2008 | Acer Aspire 5002WLMi Notebook
Acer Aspire 5610-4648 Notebook Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
