Question about Tascam US-122 USB Audio/MIDI Interface Sound Card
Problems recording with Tascam us-122
There are timing issues and dropouts. Really hard to even get one track to not skip.
You dont say what program you are using to record on. If it's cubase sx it's the fault of the program not the soundcard. Contact cubase and they will give you the fix
Posted on Jan 20, 2008
How do you hook up a Tascam 122 cassette deck to a receiver i tried to hook it up to my Nad 7155 receiver and no sound what am i doing wrong please help
cassette decks have line OUTPUTS. If it records there may be line inputs. Connect the OUTPUTS to the appropriate INPUTs on ur amp. Select the correct input on the amp. If it doesn't work u will need to verify the amp inputs work and that the tape outputs r active.
If so chg the cables.
Jun 02, 2016 | Tascam Computers & Internet
Tas cd-rw 900 when recording in church services, it skips tracks. sometimes it only records for a few seconds and starts over.
If A.Track is on it will interpret silence (or near silence that meets user thresholds) as a new track. Disable A.Track with the Jog Dial when setting up to record.
http://audio.manualsonline.com/manuals/mfg/tascam/cdrw900sl.html
Page 26 under Automatic Track Division...
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/55030670_PM_EN.pdf
Jan 28, 2011 | Tascam Cd-rw900sl Cd Recorder/player
Tascam cd-rw750 - while recording from another CD player (using digital coax connection), machine records for some time and then just "jumps out of record mode" and goes back to the beginning like nothing...
1. First problem: "like nothing is recorded". IS something recorded or has it been left in Pause Mode so long (instead of Recording) that it just got impatient and time out?
2. Get yourself a couple of CD-RW Digital Audio discs to play with until you're past this learning curve/problem scenario. That way you can always erase them and start over without having to discard the disc.
3. Dropouts on playback. Are they repeatable - always at the same place, even on different CD players? If so, the data is bad on the disc. If not, the data is probably marginal.
4. If you have a DVD player, try to play the failed recordings in it. Some DVD players can play back unfinalized CDR's. You may be able to recover the data by copying it back to the CD Recorder from the DVD player. Just be advised that an unfinalized CD-RW may not have 'silence' following the last recorded track due to old data remaining from a previous session, so be ready to pause or stop the recorder when the last track finishes.
5. "Scratches near the outside of the CD". Were these NOT present prior to entering the CD Recorder? Do they seem to coincide with about where the recording may have failed?
6. 20 vs 19 tracks: Is this a constant problem or only when there is a failure during CD creation? If the latter, it would make sense as the last track in isn't technically completed.
Apr 09, 2010 | Tascam CD-RW750 CD Recorder
Cracking, skipping, jumping
set the sensitivity of the microphone down or get a new mic.
Sep 03, 2009 | Tascam US-122 Sound Card
Recordings play but skip every other second
you either don't have enough space on your computer for it to find the file and replay it(computers don't record in one solid track ,they take pieces and store them where ever they can.This is why its not good to defrag your comp. once you start a project) or you need to increase your buffer
Mar 19, 2008 | Tascam US-122 Sound Card
Burn CDs from Tascam US-122L
The answer is yes, but it may not work as simply as you think. You can't just save your Cubase file / mix and then send it to your recorder. You'll want to render down the song you have to one stereo .wav file and send that to burner as a wav file. (That's the quick way). Another option is to render each file you have seperately so acoustic guitar, bass, vocal, etc are all seperate tracks. So the answer is yes, a .wav file is the format for audio cds. You'll record your seperate tracks and then you'll have to mix down, render, or export them when you are done. In Cubase, use "export".
Feb 07, 2008 | Tascam US-122 USB Audio/MIDI Interface...
Problem with the Tascam US-122 audio/midi interface
lol ..
i had the same problem..but its not that big of a deal
just switch it to "mono" on your interface
that should do it!!
Sep 17, 2007 | Tascam US-122 USB Audio/MIDI Interface...
Tascam 488 mk II recording problems
Have you taken a look at the edge of the tape? tracks 1 and 2 on a cassette are usually next to the edge and you may have a bad batch of tapes that have the edge damaged. Another possible but not a likley problem might be the tape is out of spec. for the width, and your heads MAY have a little wear from use, and are trying to act like tape guides. If the tape is slightly wider than the grove worn in the head, the tape would be lifted at the edge and not make contact to the head. It is not electronic as you have diagnosed this with other tapes. Give it a try and see!
Aug 05, 2007 | Maxell 109069 Audio Cassette (Type 1)...
Tascam US-122 USB Audio/MIDI Interface Sound Card Logo
109 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
vincent_hear
Level 1 Expert
j m
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
