Question about Dryers
Kenmore gas dryer model#110.70982990; s/n MJ4903286 Drive motor shuts down when start button is released. I tried another starter relay but had the same problem. I then shorted the relay's switch. The motor stays on now but the heat does not fire up.
Gas dryer does not ignite. Changed ignitor,still does not light.
Posted on Aug 09, 2010
My electric dryer starts then shuts down after 5 seconds
Centrifugal start switch, built into motor, may not be releasing when motor comes up to speed. A little light oil on sliding part of switch might help.
Dec 13, 2013 | Kenmore 73952 Gas Dryer
I have a Kenmore Elite older model dryer that will fire the burner up when started, but when the burner shuts down and then tries to cycle on again, the glow igniter starts but no gas is released and the...
most likely its gonna be your coil kit, but it could also be ur gas valve,but the gas valve is not common. I would go with the silinoid coil kit first, its much cheaper too
Oct 11, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Runs when PTS held but shuts off when released/no heat
No problem at all.The motor has a start and run winding.Your run winding is bad.The reason you have no heat is the run winding has to run to close the contacts on the motor switch.Replace the motor ,both problems solved. Hope this helps Please rate my response :)
Dec 13, 2009 | Kenmore Washing Machines
Press start button and dryshuts off when start button is released
There is a switch assembly on the motor that activates when the motor is running. Centrifugal switch. It keeps it running when you release the switch. That is where to start. Eric
Jun 11, 2009 | Kenmore 74992 Gas Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Dryer shuts off after releasing "push to start"
this problem sounds like it can only be 1 of 2 problems. the start button or the motor is not going into run winding. i found over the years that the blue wire i believe is burnt at the motor. this can be repaired quite easily .cut the wire and strip it putting a new connector on. if you need to you can buy an assortment at a hardware store. if every thing is good check the start button for burnt wire if ok then you most likely have a bad motor. i'm pretty sure though that a wire is burnt off at the motor
Jan 30, 2009 | Kenmore 67082 Electric Dryer
Kenmore gas dryer will not start model 110 72972109
check your motor relay under your control panel
Dec 23, 2008 | Kenmore 62802 Electric Dryer
Kenmore gas dryer timer? problem
Sounds like your centrifugal switch on your drive motor may be defective. The switch is supposed to "latch" (or stay closed) when the drive motor begins to spin. That...or, you may have a defective start switch. Please post back with your COMPLETE model number so I can determine how your dryer is configured as all dryers are not alike. I need to make sure.
Oct 26, 2008 | Kenmore 73932 Gas Dryer
Dryers Logo
135 people viewed this question
Top Dryers Experts
