I have an error code Eooo578-8001. On my 7095 canon imagerunner.
I pulled a piece of paper out of the delivery while it was running, now the finisher makes a funny noise and it doesn't work. Help me.
  • Christoph604 Jan 08, 2009
    That's an Canon 7095 imagerunner, that I need help with. It has an error code E000578-8001.
    If you can help, I would be very grateful.
  • Office Equip... Expert
  • 316 Answers
Paddel error
Posted on Jun 06, 2010
Canon iR 3300
this error is related with the finisher's delivery tray ascent/descent motor. check possible obstruction of motor malfunction or sensor malfunction
May 16, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imagerunner error code E000024-0001. All I did was replace the empty toner cartridge!
first try to pull out and place it back in toner station, it maybe needs more time to replanish the toner few more times.
By the book, its toner sensor error. did you use force to replace toner? maybe you broke it, or damadged the toner holder and toner isn recognized.
The tube should rotate, when everything is OK,so, open toner cover, insert toner tube, lock it, put piece of paper in sensor hole ( the hole in wich goes plastic nose of toner section door ).
Hope that helped!
Jul 22, 2010 | Canon IMAGERUNNER 2230 Copier
We have a Canon ImageRunner 8500 and we get this error code E000542 0003. How do we fix it?
In this case the finisher motor or motor sensor does not work properly. AS SM Main cause - The tray B lift motor (M12) is faulty. The tray B idle rotation sensor (PI18) is faulty. The tray B lower limit sensor (PI24) is faulty. The tray B paper sensor (PI17) is faulty. Main cause The tray B lift motor (M12) is faulty. The tray B idle rotation sensor (PI18) is faulty. The tray B lower limit sensor (PI24) is faulty. The tray B paper sensor (PI17) is faulty. Try operating copier without finisher or contact an technician to repair finisher.
Jun 10, 2009 | Canon imageRUNNER 8500 Copier
Error code E584 and paper jams
• Feeder motor , • Shutter closed sensor • The shutter closed detecting switch does not turn on even when the feeder motor has been driven in reverse for 1 sec or more.
clear dust from the finisher sensor
Feb 23, 2009 | Canon imageRUNNER 400S Copier
Canon IR c3200 paper jamming
ok you can make it feed out to the tray under the scanner touch add func then common setting then tray designation then follow program to send all prints and copies to that tray
Jan 25, 2009 | Canon imageRUNNER C3200 Copier
Error message on Cannon IR 3300
that is a stack delivery error could be one of the motors or a board do you have the internal finisher or external
Jan 13, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Error Code E000514-0002
514-0002 is a finisher error in the finisher
The delivery belt does not return to home position when the stack delivery motor is driven for 3 sec.
Main problem The stack delivery motor is faulty. The delivery belt home position motor is faulty.
Try to check motor & sensor or operate copier without finisher.
Dec 16, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Ir 2000 system Error E 577 what can I do ?
The return roller does not reach home position when the delivery motor
(M1) is driven for a specific time. (If the same condition is detected while
alignment takes place in the direction of feed, a jam will be identified.)
Possible cause The delivery motor (M1) on the finisher controller PCB is faulty. The return
roller home position sensor (S3) is faulty. The connector is discontented
or has an open circuit. The delivery motor relay harness is faulty.
The return roller is faulty. The finisher controller PCB is faulty.
Dec 09, 2008 | Canon imageRUNNER 2000 Copier
Canon PC 1060 error code E-002-000
A E002-000 is fixing unit error code. It is a power problem with the fixing unit. When you removed the paper jam did you see any piece of a blackish grey plastic pieces. If so you need to replace the fusing unit and or the upper fixing film..
May 09, 2008 | Canon imageRUNNER 5570 Copier
788 people viewed this question
